Does my diagram look ok to use in practice?
macdaddy86
PostPosted: 20:46 - 22 Oct 2016    Post subject: Does my diagram look ok to use in practice? Reply with quote
Hi Bikers,
I'm sick of vacuum issues on my scooter, thought about a manual cut off tap instead of the vacuum petcock, then had a brain wave which i don't know if it will work as I've not seen any how to's online so its either not possible or I'm missing something that nobody is telling me about this setup on a bike. please see the image and let me know if theres any cons about this setup? Costs about £30 to convert it. thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 20:53 - 22 Oct 2016    Post subject: Reply with quote
You could just have a pipe from the tank to the carb and rely on the float....
Triumph Sprint ST 1050
macdaddy86
PostPosted: 20:53 - 22 Oct 2016    Post subject: picture of the 12v valve Reply with quote
Just thought id add a picture of the 12v solenoid valve i intend to use also Very Happy
macdaddy86
PostPosted: 20:54 - 22 Oct 2016    Post subject: Reply with quote
I could but i wouldn't want to chance it, i have bouts of bad luck i think lol.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:19 - 22 Oct 2016    Post subject: Reply with quote
What bad luck? At worse your bike will wet itself and all the petrol will eventually evaporate.
Back in the day before vaccuum taps we all used to leave our fuel taps on with no concerns.
macdaddy86
PostPosted: 21:24 - 22 Oct 2016    Post subject: one pipe Reply with quote
I've heard that it can flood the carbs and cause hydrolock and/or mix with the oil etc if the float fails? basically wreck your engine beyond repair. Would be nice though to not have to worry about switching it off.
kramdra
PostPosted: 21:41 - 22 Oct 2016    Post subject: Reply with quote
Fit the solenoid without the taps. I intend to put one on the 250rr. Vacuum tap is a bastard.
Robby
Dirty Old Man
PostPosted: 21:42 - 22 Oct 2016    Post subject: Reply with quote
So instead of having one fairly reliable vacuum tap, you want a set with three different fuel taps, and lots more pipes to fail.
If you want a manual tap, fit one. If you're worried about overflowing, turn it off when you stop.
macdaddy86
PostPosted: 21:46 - 22 Oct 2016    Post subject: Reply with quote
no i don't want to do it manually, there will be one 12v solenoid valve, and a backup manual switch if that fails.
it will only use the 12v solenoid valve unless it fails (it is electric), then i can simply switch that off and use manual feed until i replace the 12v solenoid.
WD Forte
PostPosted: 22:26 - 22 Oct 2016    Post subject: Reply with quote
Waaay too complicated
What scoot? * , gravity fed I assume?
( some have underslung tanks that need a pump)
Just fit a manual tap and be done with it
OR
Service the vac system properly and be done with it
it aint rocket science, just use decent quality pipe and clips
not aquarium pipe and rubber bands
* why do so many people never say what bike/scoot they have?
bikers smell of wee
kramdra
PostPosted: 23:29 - 22 Oct 2016    Post subject: Reply with quote
Any decent quality solenoid is not going to fail, you do not need a backup. Possibly if you run out of juice it will prevent bump starting, but most modern bikes recommend against it for fear it will fuck the regulator.
Have serviced my vac tap, worked for a year, now is always on. The manual tap part is also dodgy, it is only off in the very centre of the off position. Good thing my floats do not intermittently piss fuel, but I'm aware they could at any time and I probably wouldn't notice.
Solenoid valves are generally made to a higher quality, example of which being brass body rather than die cast zinc Mad
Teflon-Mike
tl;dr
PostPosted: 07:37 - 23 Oct 2016    Post subject: Re: one pipe Reply with quote
As others; that is massively over convoluted.
Tell me, do you spend longer getting kitted up to ride anywhere than riding there? Because that is displaying an AWFUL lot of belt braces and must have spare shoe laces too, 'thinking'.
'Yes', your schematic looks like it could work... it just doesn't need to.
The reason for a vacuum petcock is simply so that if the bike is knocked over, the carburettor float doesn't let petrol over flow and cause a fire risk.
I don't know who you have been listening to, there's some seeds of truth in there, but?
Possibly.. but incredibly unlikely.
Vacuum petcocks are an innovation that have really only been about since the 1980's, and even then they weren't common. In forty years, I don't think I have EVER come across anyone who has wrecked an engine from not turning off their petrol tap.
I've woken up to a puddle of petrol under the bludi-guzzi, on many an occasion though! As our Snowie isn't in the habbit of turning taps off, and she always forgets that bike has two, AND it's a bluddi-guzzi, with notorious Del-Awful carbs, that give four opportunities to piss petrol, from either of the sticky choke valves and or either of the sticky float bowls!!! Most dire consequence of the matter, has been the damn thing running out of petrol!!!
YES, gross flooding, could, see neat fuel wash into the inlet tract and into the cylinder.... BUT...
You have to have more than 'one' failure for that; first the vac tap has to effup. Next, your carb float has to jam open. THEN, the float bowl over flow has to fail to vent the over flow. THEN, the engine has to have 'stopped' on the induction stroke, so that the inlet valve is open, so that fuel has unimpeded access to flow into the cylinder; that is possible and more likely on a twin or four cylinder engine, but on a single, the engine will normally stop half way up the compression stroke, both valves shut. (Turn ignition 'off'; sparks stop, engine spins 'on' until it's lost momentum; little resistance is applied on the other three strokes, so resistance applied by the compression stroke, is usually the one that brings it to a complete stop}
Now, vacuum taps are USUALLY pretty damn reliable; IF they give any grief, it's more common that the vacuum hose to them has been pulled off and pushed back on so many times, or has perished, it doesn't seal vacuum, so the tap doesn't get turned on, or turns the fuel off when you don't want it to... an old vac hose has had me at the side of the road shaking the tank and scratching my head a couple of times... it's not exactly a 'major' danger! Annoying, embarrassing, perhaps? But it's not likely to put your bike or health at much risk!
So, from that fundamental; ripping out a well proven, high reliability component, on the 'fear' it might fail; to replace it with some lesser known quantity, after market device, in a more complicated amateur installation, DOES NOT make sense. You are swapping a proven system for an unproven one.. WHICH should you have more 'confidence' in to not fail?
You are engineering 'in' potential problems.
Now, look at your proposed schematic; you have three taps, therefore three potential failures, instead of one.
Your 'emergency on' tap; makes the other two redundant, and if you forget to switch that 'off', then you are actually causing the 'failure mode' you wish to avoid!
So whilst, your suggested plumbing might 'work', as arranged, it's not doing what you hope, and reducing the risk of a fuel leak; and on many many counts, it's actually increasing the risk...
AND, it's NOT actually tackling the main 'cause' of a leak, IF you had one... which is in the carburetor, float valve, choke bypass and overflow.
It's like being worried about fire, and rather than getting the oven serviced, looking at the fire blanket over the oven, and thinking "That doesn't look very good!" and buying a bucket and filling it with water....
Carrol Shelby, winning sports car racing championships in the 1960's with a buggy-spring hot rod, when every one else was using more sophisticated twin-wish bone and coil-spring arrangements, asked why he didn't adopt the 'better suspension' famous commented "If it aint broke, don't fix it!"
And there's the nub. The 'only' benefit of even a vacuum tap, is the 'easement' of not having to remember to manually turn the petrol tap 'off', which is what generations of riders lived with for decades before vac taps came along.
My advice... leave it the fcuk alone! if it aint broke, DONT fix it!
If it IS broke, before looking for 'more' than standard, make sure you have all you should AS standard (Another racing adage!}
IF the vac tap breaks, fit a new one. IF the carb is prone to flooding, service it! That little nugget even sorted err-bluddi-guzzi's notorious incontinence problem when she forgets the taps!
P.
PostPosted: 18:20 - 23 Oct 2016    Post subject: Reply with quote
macdaddy86 wrote:
no i don't want to do it manually.
Pure laziness then Laughing
The last post was made 9 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 81.78 Kb
