| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 12:20 - 23 Oct 2016 Post subject: Battery life vs usage? |
Sorry a long post, please bear with!
I have a battery dilemma.
As some of you may know, I permanently exported my FZ1-N to Cyprus, earlier this year.
In November 2014 I bought a new motobatt AGM battery, this sat in our kitchen until the end of Feb 2015, when I fitted it to the bike. Before I fitted it to the bike I checked the voltage and it was sitting at 12.5v, once fitted, with the bike running it was reading 14.46v.
The reason I replaced the battery was, the one on the bike would not hold a charge, after charging the bike would not start, when I hit the button, all I would get was a clicking from the relay/solenoid. The new battery solved this problem and the engine would spin on the first press of the button.
I took the bike to the TT in 2015, rode it in the UK and everything was fine, although I did have to charge the battery if the bike was left for more than a couple of weeks.
I Sorned the bike at the end of January, got it prepared for an MOT and ready to export. I charged the battery up, took the bike to the shippers, where I had to disconnect the battery for shipping.
When the bike turned up in Cyprus, in April, I reconnected the battery and it started up straight away. I rode the bike a few times, then I disconnected the battery prior to returning to the UK for the BBQ and a couple of other events.
On returning to Cyprus I reconnected the battery, the bike wouldn't start, same clicking as before, disconnected it, charged it up, still no joy, so I suspect the battery's kaput!
I have bumped it and had the bike running, but it still wouldn't turn the motor on the button.
Last night, when I came in from riding, I hooked the charger up via the permanent charging socket, I've fitted to the battery, and the battery didn't pass the retention test, I suspect this is because the factory immobiliser is constantly drawing power.
So, my question is this this, am I expecting too much from the battery?
The bike does sit for long periods with little or no use, (now in extremely hot temperatures), if I leave the battery connected, the immobiliser is drawing power from it. You also have to remember that before starting, the fuel pump primes, the exup valves reset and the headlights can't switched off!
Can I expect more than two years of life from the battery, given my circumstances, or am I just stuck buying a new battery every 18 months?
I know a partial solution is to ride it more, which I will, and leave it on a tender, trouble is I don't fancy leaving it on a tender, unattended, for a couple of months
I can't get my hands on a meter, atm, but should be able to tomorrow, so I can't check any voltages atm. ____________________ "Everybody needs money, that's why they call it money!"  |
| doggone |
 doggone World Chat Champion
| Robby |
 Robby Dirty Old Man
| Copycat73 |
 Copycat73 World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 13:50 - 23 Oct 2016 Post subject: |
Cheap batteries don't seem to like being left on Optimate type chargers (the Sprint batteries seem to die rapidly irrespective of being left on a maintenance charger or not).
Motobatt batteries should be a bit better.
However I suspect that what has happened is you have fried the battery early on its life by leaving it connected and having the immobiliser flatten it.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Copycat73 |
| Suntan Sid |
 Posted: 14:31 - 23 Oct 2016 Post subject: |
Thanks for the replies!
The reason I'm reluctant to leave it on a trickle charger is I won't be here for 3 months!
I could ask my neighbour to put it on a trickle charger once a week, he would be willing to do that. Would that be enough to keep the battery in a good condition?
Hopefully i'll be getting a new battery tomorrow, I can put it on the trickle charger, while I'm here, I'm not bothered about the immobiliser, so I'll probably disconnect the battery while it's charging.
Is, continually, using a trickle charger detrimental to battery life, or is it all for the better? ____________________ "Everybody needs money, that's why they call it money!"  |
| Kickstart |
| Suntan Sid |
 Posted: 15:10 - 23 Oct 2016 Post subject: |
I'll try and get another motobatt, not sure what's available TBH! ____________________ "Everybody needs money, that's why they call it money!"  |
| doggone |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Copycat73 |
| Suntan Sid |
| Suntan Sid |
 Posted: 18:49 - 23 Oct 2016 Post subject: |
I may have just had a light bulb moment, when I got the bike it had a few extras fitted, one of which was heated grips!
I remember the guy at the dealers telling me if I left 'em switched on even with the ignition off they would flatten the battery.
I have used them a few times, but I don't ride this bike in the winter and I've never left 'em on.
However, I've just read this article:-
https://www.ulyssesmelb.com/content/heated-grips-how-avoid-flat-battery-blues
Not sure what make mine are, I need to check, any thoughts?
Anyone had problems with heated grips, not going to need 'em here, so is there anything I should know before I go about removing them? ____________________ "Everybody needs money, that's why they call it money!"  |
| Kickstart |
| Suntan Sid |
 Posted: 19:06 - 23 Oct 2016 Post subject: |
I'll have a look at the wiring tomorrow, and see what's going on! ____________________ "Everybody needs money, that's why they call it money!"  |
| diesel dog |
 diesel dog Renault 5 Driver
| Suntan Sid |
 Posted: 17:27 - 24 Oct 2016 Post subject: |
Ok, I managed to get a new battery today, it's a "DynaVolt", all that was available!
Got home, disconnected anything to do with the heated grips, not going to be needing them here. Fitted the new battery and it started the moment I hit the button!
I'll be using the bike on a regular basis until mid December, then the bike will be left for three months, what will be the best thing to do with the battery for this time?
I'll remove it from the bike, I have an Optimate 2, is it sensisble or even viable to leave a battery hooked up for 3 months?
I can get a neighbour to unhook/hook it up at any time, so what should I do? ____________________ "Everybody needs money, that's why they call it money!"  |
| jaffa90 |
 jaffa90 World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| Suntan Sid |
| Polarbear |
| Suntan Sid |
 Posted: 20:50 - 24 Oct 2016 Post subject: |
Here's the blurb for my charger:-
https://optimate.co.uk/optimate%202.htm
Whaddya reckon? ____________________ "Everybody needs money, that's why they call it money!"  |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 21:31 - 24 Oct 2016 Post subject: |
I wouldn't feel alright leaving it on the charger, unattended. I would just charge it once a month (which is enough) or every 2 weeks with a normal charger. I just wouldn't sleep well, leaving it on a charger 24/7, as chargers may fail and boiling/exploding batteries are nothing nice.
By the way, it's not just draining the battery below 12v that kills it, it's also the starting procedures (electric starter). I can't give you any specific number, but each battery can hanle only a certain amount of starting procedures/cycles, as that is the only time a battery really gets to use in its life. The longest time I've seen a battery being just sat on the shelf (put there with full charge), was 4 months and after that, it still held enough charge for the engine to start. Depends on the capacity, obviously. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
The last post was made 9 years, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
