Tubeless wheels
Fair weather rider
PostPosted: 10:57 - 24 Oct 2016    Post subject: Tubeless wheels Reply with quote
I have recently bought a Virago 535 (it's an age thing) I was wondering if anyone knows if I can obtain Tubeless Alloy Wheels for it?
The rear is a 15" and the front is 19"
Don't like wheels with tubes in.
Thanks in advance.
If it seems to good to be true, then it probably is, but buy it anyway.
doggone
PostPosted: 11:45 - 24 Oct 2016    Post subject: Reply with quote
Being shaft drive will reduce your chances.
There may be ways to do it though, my (gone) BT1100 had cast wheels and similar looking drive set up. Or some other donor ideally Yamaha, XV750 has cast wheels too I think?
Is it really worth it, might be better to trade in as near standard bike once you get over the cruiser phase Razz
Teflon-Mike
tl;dr
PostPosted: 11:52 - 24 Oct 2016    Post subject: Re: Tubeless wheels Reply with quote
Thanks in advance.
Answer is the perennial; if you have the money, almost anything is possible, whether it's worth the money is another matter.
Rim form for tubless tyres is shallower than for tubed tyres; so you can fit a tubless tyre to a tubed rim, it's just a bastard to get over the rim! And if you have wire spoke wheels, it probably wont hold air without a tube in it.
There are a couple of designs of wirespoke rim for tubless tyres that will take a tubless without tube; they are more common on dirt bikes and adventure sports, and you may struggle to get the rim sizes you want, whilst issue of matching them to your hubs may exist depending on the spoke plan.
Last time I had a wire-spoke re-rimmed for my trials bike, (conventional tubed rim) I think it cost me about £200 for new rim, spoke-set, build and true. It's not a cheap game; and to do both wheels, you are likely looking at around £500 and up to get wheels built around your hubs to take tubless rims.
Possible cheapskates using wheels from another bike, you might get 2nd hand? It's a Yammie and they tend to be pretty good on parts compatability between models, but it's also a shaftie.... which limit's things some-what.
Bottom line then... how much is not having tubes worth to you?
End of the day, the little viagra is a lightweight cruiser, with only 40bhp, it's never going to exactly 'burn rubber'; the tubed tyres it has as stock are more than 'adequete' for the performance it has and, for what it is, a useful cruisr-style commuter twin, it's likely that tyre stability and handling has always been compromised by fit of harder compound, high mileage 'ecconomy' tyres anyway.
Difference between tubed and tubless is practically likely to be negligible, other than in cost, and the cost of repair should you get a puncture.
Having tubed tyres on that bike isn't something that would unduly bother me too much.
So back to the beginning; most things is possible with enough money; how much is it really worth to you?
PostPosted: 12:06 - 24 Oct 2016    Post subject: Reply with quote
Save your money, buy a spare tube, tyre levers and recovery.
They'll take you home or somewhere that will fix it. Thumbs Up
WD Forte
PostPosted: 16:05 - 24 Oct 2016    Post subject: Reply with quote
Will early XV 750 wheels fit?
they're cast alloy (and presumably tubeless?)
bikers smell of wee
PostPosted: 17:34 - 24 Oct 2016    Post subject: Reply with quote
You could potentially get someone to build BMW-style rims onto your existing hubs. Would be fairly pricey I'd imagine.
jaffa90
PostPosted: 00:06 - 25 Oct 2016    Post subject: Reply with quote
""Don't like wheels with tubes in.""
Why is that?
Commuter_Tim
PostPosted: 00:54 - 25 Oct 2016    Post subject: Reply with quote
Why is that?
Globophobia
I ride a Bandit 600... badly.
smegballs
PostPosted: 06:44 - 25 Oct 2016    Post subject: Reply with quote
I like tubes for this reason. I've got spanners for the wheel nuts, levers, bicycle pump and tyre repair kit in my topbox.
Fair weather rider
PostPosted: 14:52 - 25 Oct 2016    Post subject: Reply with quote
I'll have a look at that, Thanks.
Fair weather rider
PostPosted: 14:54 - 25 Oct 2016    Post subject: Reply with quote
Commuter_Tim wrote:
Why is that?
Easier to fix punctures with tubeless.
Globophobia
Fair weather rider
PostPosted: 20:50 - 02 Nov 2016    Post subject: Reply with quote
Have found a Maxim rear wheel, which I think will fit rear, £30 on eBay, am waiting for it to arrive.
It's a 16" and not a 15" but I think I will get away with it.
Will probably have to buy forks with wheel to fit front. Very Happy
Nobby the Bastard
Harley Gaydar
PostPosted: 21:17 - 02 Nov 2016    Post subject: Reply with quote
I can think of many thnigs wrong with a virago that I would correct before I'd have a go at the wheels. After all they are doing the job that all wheels do.
Triumph Sprint ST 1050
The last post was made 9 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.1 - MySQL Queries: 13 - Page Size: 78.75 Kb
