Snake oil?
Ariel Badger
PostPosted: 22:24 - 26 Oct 2016    Post subject: Snake oil? Reply with quote
I doubt this stuff works
Anyone tried it?
PostPosted: 02:28 - 27 Oct 2016    Post subject: Reply with quote
As an engineer that goes against anything I was ever taught. I cannot believe it would seal a head gasket or cylinder block crack.
Come on Mr. Badger, you know that as well as I do.
Triumph Trophy Launch Edition
nitrosurf
PostPosted: 06:33 - 27 Oct 2016    Post subject: Reply with quote
It's entirely possible that it would do a good enough job in an emergency situation, like if you blew a head gasket in Rape Forest Tennessee and didn't have time to get the AA (A) in to pick you up. I can't see how you'd want to rely on some partially solidified gunk to keep your engine's fluids where they belong and up to pressure on a permanent basis.
Is the guarantee a gimmick do you think?
"Multiple exclamation marks," he went on, shaking his head, "are a sure sign of a diseased mind."
Raffles
PostPosted: 08:52 - 27 Oct 2016    Post subject: Reply with quote
It does sound like a load of old bollocks but plenty of users' reviews of similar sounding products such as Steel Seal, K-Seal etc. seem to be positive Shocked
Shinigami
PostPosted: 09:17 - 27 Oct 2016    Post subject: Reply with quote
sound like it would knacker/gunk up your cooling system amongst other things? not convinced
Snodvan
PostPosted: 09:24 - 27 Oct 2016    Post subject: Reply with quote
Once upon a time (like 15 years ago) I had a Landrover Freelander (R reg). The 1.8 petrol engines in those were crap. VERY prone to head gaskets blowing. The first "blow" was fortunately just after I bought the thing and was repaired under a warranty insurance - but all they did was throw a new head gasket on.
The root causes were (so I was told)
- Poor design that left very narrow widths of head / block between coolant channels
- Lousy gasket design
- Using nylon pins in the block to locate the head
When the head blew the next time they did a better job ie used an "updated" gasket - and did a proper head skim
That repair lasted a mere 2 years before the dreaded "emulsion in the cooling water" symptom showed there was another head blow looming. Being a bit cash strapped I asked the boss of a local engineering shop for advice to tide me over until they could do a full engine strip that would fix all the root causes listed above.
He have me a couple of packets of summat (forget the name but they were only 50p a packet) but was claimed to be a head crack sealer. I drained quite a bit of coolant water to get rid of the emulsion, threw the contents of the packets in and topped up the water/ antifreeze again
Miracle! No more emulsion problems for the next 2 years, maybe a bit longer --- until the guy did a PROPER engine job
SO, IT WORKED
What was in the packets? Not sure but (as an ex-chemist) I reckon it was sodium silicate in some form ie waterglass. That makes sense. When that stuff gets heated it will break down into silica (silicon dioxide ie sand) and it will block small holes
Think about the common wartinme use for waterglass (yes, I am THAT old) - preserving eggs. It blocks the tiny, tiny holes in egg shells so that the stuff inside does not degrade from oxidation.
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
PostPosted: 09:41 - 27 Oct 2016    Post subject: Reply with quote
I see no reason why it shouldn't work for a small blow into the water jacket.
I did see a fairly funny thread on a forum years back where someone had poured the stuff into their oil instead of the coolant. Utter mayhem ensued as it blocked up all the small, high pressure "leaks" in the engine internals. There were teardown pictures of the oilpump etc.
Shinigami
PostPosted: 09:48 - 27 Oct 2016    Post subject: Reply with quote
sounds like the bloke on the facebook cbf125 group who used rubber cement as a gasket, resulting in an engine full of puffed up goop Laughing
lingeringstin...
PostPosted: 10:52 - 27 Oct 2016    Post subject: Reply with quote
You should take out the thermostat in a suspected cooling fail situation. I have always taken them out of water cooled vehicles as soon as I could anyway because they're just crap waiting to go wrong. As far as I can tell their only purpose is for the water to get hot quicker by stopping up the water circulation which is a stupid idea anyway. It's always been my view that a water cooled vehicle really needs water circulating around the system to cool it. Not rocket science.
Removing the thermostat and taking off the radiator cap would hugely reduce the internal pressure in a cracked cooling system and greatly reduce the problem temporarily at least without resorting to chemical snake oils which may or may not work under pressure. And believe it or not in case the water leaks out from a split hose or steams off from a stuck thermostat most older engines can be run without water at low speeds just fine if you have decent air circulation. With a few tools on an intelligently designed vehicle (probably something like pre 1990) in a pinch you could remove the bonnet and bimble home the last 40 miles at 20mph without destroying the engine.
And yes, I grew up on a farm. And yes all this is totally irrevelant to the modern smartphone world of recovery vehicles and computer encrusted newfangled complicated car engines, but it's worked for me in the past and personally I wouldn't own any vehicle that needed a computer to run anyway.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:18 - 27 Oct 2016    Post subject: Reply with quote
They work, but only for about 6 months. then fail.
I used similar on my punto when I coulnd't be arsed to fix a leak on the water pump.
Back in the day people used to use an egg white in the cold water in the radiator. Works but only for a few days.
Triumph Sprint ST 1050
Azoth
PostPosted: 17:30 - 27 Oct 2016    Post subject: Reply with quote
Quite a radical solution! Not saying it's wrong. I might try it myself. You mean, you just take out the thermostat and throw it away, never to worry about a failed thermostat again? Are you sure it's safe?
I imagine some engineers would say that the engine 'needs' to get to full operating temperature before the cooling system switches on, but what you're saying makes sense. After all, an air-cooled engine always has its air cooling switched on.
Safety in numbers
pepperami
PostPosted: 18:21 - 27 Oct 2016    Post subject: Re: Snake oil? Reply with quote
Anyone tried it?
I think you got it right in the title of this thread.
pouring gooey gunk into your precious engine to fix a problem that you have the ability to fix properly?
You Sir are not Ariel Badger.... what have you done with the real Ariel Badger? Thinking
PostPosted: 18:31 - 27 Oct 2016    Post subject: Re: Snake oil? Reply with quote
As far as I know, Ariel's bikes are all air cooled? So I'd presume he's asking because it's for a c*r.
PostPosted: 18:33 - 27 Oct 2016    Post subject: Reply with quote
The revolutionary product that actually repairs broken gaskets, cracked head gaskets and repairs warped heads.
Save hundreds if not thousands on costly repairs.
Gasket Fix repairs your broken or cracked head gasket quickly and permanently. Gasket Fix is not a temporary solution!
Well, even if it does actually stop a blowing head gasket from blowing, or a leaky coolant system from leaking, it certainly doesn't broken or cracked head gaskets or warped heads. They will still be broken, cracked or warped.
MCN
PostPosted: 19:24 - 27 Oct 2016    Post subject: Reply with quote
It will work as long as it is still in solution in the coolant. If you flush and change it would possibly compromise the 'repair'.
I really depends on what you term a repair/fix/bodge.
But It will 'repair' a leak in a combustion space.
It's not doing anything seriously Special.
Ariel Badger
PostPosted: 19:14 - 28 Oct 2016    Post subject: Reply with quote
I was searching for something else when I came across this stuff.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
Islander
PostPosted: 13:30 - 29 Oct 2016    Post subject: Reply with quote
ZX-7R wrote:
Rat Wax maybe?.
Probably Immodium. Razz
The last post was made 9 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 102.54 Kb
