Some tacky arts/crafts stuff with the kids (physics help)!
Gazz
PostPosted: 14:26 - 28 Oct 2016    Post subject: Some tacky arts/crafts stuff with the kids (physics help)! Reply with quote
We are currently doing some arts and crafts stuff with the kids and had the idea to put some lights behind a picture to make it more 'realistic'.
Had the idea of maybe a landscape picture with a sun in the background and putting a yellow LED behind it which would look the mutt's nuts at night time! Dance!
However I have no idea or how this could be achieved. Had the thought of using those little bulbs that come behind the dash in a car and wiring it up to a AA battery of something? Would this work? Maybe an engine management light bulb since they are sun-coloured.
Any help much appreciated.
I took Biology and Chemistry at school and the extent of my physical knowledge is wiring the odd plug.
I do however own a soldering iron. Wink And a AA battery.
PostPosted: 14:47 - 28 Oct 2016    Post subject: Reply with quote
Go to the local pound shop/discount store and get some tacky solar-powered garden lights.
Dismantle them, chuck away the plastics and you'll have a battery, a small solar cell and an LED. Put the LED and battery behind the picture, put the solar cell on the front.
ScaredyCat
PostPosted: 15:02 - 28 Oct 2016    Post subject: Reply with quote
In the picture paint a house, make the solar cell look like it's on the roof of the house.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Nobby the Bastard
Harley Gaydar
PostPosted: 15:48 - 28 Oct 2016    Post subject: Reply with quote
You do know that the solar cell has two purposes?
1) charge the battery
2) Tell the electronics it's daytime so that the fucking bulb doesn't light up as it's not needed....
Triumph Sprint ST 1050
duhawkz
PostPosted: 16:38 - 28 Oct 2016    Post subject: Reply with quote
BikeDoctor wrote:
https://www.mumsnet.com
As much of a cunt as CrustySocketBiker is he does have a point.
MahatmaAndhi
PostPosted: 17:05 - 28 Oct 2016    Post subject: Reply with quote
Why not get a clear LED and where the cut out of the sun is, put a yellow transparent film over it?
2008 Aprilia Sportcity 250
bamt
PostPosted: 18:23 - 28 Oct 2016    Post subject: Reply with quote
Buy an amber/orange LED from ebay or Maplin - e.g. https://www.maplin.co.uk/p/3mm-yellow-led-n70kg
https://www.maplin.co.uk/p/5mm-yellow-led-n71aj
Then you'll need a resistor, depending upon what battery you are using.
So, for example, the 3mm LED above says Forward Voltage 2 V
Forward Current 30 mA.
If you run it off two AA batteries, you'll have a voltage of 3V, so you need to drop 1V across the resistor.
Ohms Law - V=IR, or R=V/I
In this case, the voltage drop you want is 1V, the current is 0.03A (30mA), so R=1/0.03
you want a 33 Ohm resistor. I'd be tempted to run it at a bit less current (less bright), so a 47 Ohm would work.
https://www.maplin.co.uk/p/metal-film-06w-47-ohm-resistor-m47r
the 5mm LED above says Forward Voltage 2.8 V, Forward Current 30 mA
As above, you want to drop 0.2V, so you'd want a 6.67 ohm to run it at full brightness.
Again, I'd actually be tempted to run it at 20mA instead, so a 10ohm
https://www.maplin.co.uk/p/metal-film-06w-10-ohm-resistor-m10r
You can run the same calculations for if, e.g. you wanted to run off a 9v battery.
Solder the resistor to one leg of the LED (doesn't matter which) and connect to your batteries. If you connect the wrong way around it won't light up, but won't be damaged.
Total cost about 40p.
Alternatively go to the pound shop and buy some cheap battery powered christmas lights.
PostPosted: 18:39 - 28 Oct 2016    Post subject: Reply with quote
Screw that. If you're going for physics, you need to power the LED by lemons. Get that interest in there early so they're not as crap at it as their Dad when they grow up. Wink
The internet says you'll need 4 lemons to light an LED. Green LEDs use less power.
Stick a bit of copper (thick copper wire, a piece of copper pipe/whatever) and a piece of zinc (galvanised nail) into a 4 lemons. Connect the copper on one to the zinc on the next one until you have a row of them with a piece of copper on one end and a piece of zinc on the other. Connect your LED to these. If it doesn't light up, connect it the other way.
Fuck yeah, science.
Mawsley
PostPosted: 20:43 - 28 Oct 2016    Post subject: Reply with quote
stinkwheel wrote:
Fuck yeah, science.
Science isn't LEDs.
Science is magnets.
Chinaboy
PostPosted: 20:59 - 28 Oct 2016    Post subject: Reply with quote
Mawsley wrote:
Science is magnets.
what colour do they light up then? Shocked
Lord Percy
PostPosted: 21:04 - 28 Oct 2016    Post subject: Reply with quote
Screw that. If you're going for physics, I recommend everything in here - all of it.
Also:
Tut Tut Greens are the worst
Lord Percy
PostPosted: 21:10 - 28 Oct 2016    Post subject: Reply with quote
On the topic of actually getting kids into science:
I just bought one of these: Arduino electronics starter kit
Comes with a 145 page PDF full of lessons right from the basics so anyone can get one and give it a go.
Might be a little too complicated for kids actually but definitely worth a shot for any man-child who wants to have a play. Basically the electronics version of mechano.
WD Forte
PostPosted: 22:34 - 28 Oct 2016    Post subject: Reply with quote
I ran an lcd watch on two spuds for a fortnight
using zinc nails and copper wire
I was going to suggest using CR button cells to power the leds
but they can be horribly nasty, if not fatal if swallowed by little ones
so a pair of AAs ( 3V) may be safer and no series resistors needed
You could probably use a local poundshop to pick up cheap gadgets and toys to hack for battey holders and leds
Pre crumpled baco foil held about 1 cm behind the pic with leds shining up the gap can have a pleasing backlight effect
bikers smell of wee
The last post was made 9 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 84.33 Kb
