| themadatter |
 themadatter Nova Slayer
| Git |
 Git Brolly Dolly
 Posted: 08:54 - 26 Feb 2005 Post subject: |
If the head gasket is leaking yes, you will loose compression and the power output will surely be affected but I guess this depends on the size of the leak. tried a compression test??
You mention goo flows out, Is it definitely the head that's leaking or the cylinder base gasket, this could quiet easily chuck oil out if it's leaking...
If you think the head has an instant gasket head gasket type affair it would be good idea to replace it asap. May also give you a good chance to have a good look at the valves and seats to see if there is a reason for them being noisy, perhaps if the engine oil is a bit old this will not help with the valve noise.
Should be a piece of cake to change a gasket on cg125.  |
| themadatter |
| Git |
 Git Brolly Dolly
| Git |
 Git Brolly Dolly
 Posted: 14:15 - 26 Feb 2005 Post subject: |
Bargain, I'd just dive in there and rip it to bits  |
| themadatter |
| mr.z |
 mr.z World Chat Champion
 Posted: 23:39 - 27 Feb 2005 Post subject: |
I have the haynes manual for the cg but..
A its for the older pre brazil verison
and
B its a a mates house
I can pm you the page with the topend rebuild bits...
To be honest though you really need one if your going to take the cylinder head appart, even just for the torque values (which may be different on mine) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
