CBR600F Sidelight Bulb Dropped In Headlamp Help
ian505050
PostPosted: 10:10 - 27 Oct 2016    Post subject: CBR600F Sidelight Bulb Dropped In Headlamp Help Reply with quote
I have a 2012 Honda CBR600F 2012 and the sidelight bulb has vibrated loose and into the headlight unit. I have spoken to Honda technical who say its a sealed unit and the only way to get it out is to remove the headlight (2 hours Labour easily) and shake the sidelight bulb out of the headlamp bulb slot.
Does anyone have any tricks to avoid removing the headlamp. You cant use grabbers because the bulb has dropped below the reflective section of the headlight.
Can anyone suggest where I can find a copy of the workshop diagram for a 2011 CBR600F so I can figure out how to remove the headlight. I can't find one online.
Many Thanks
UnknownStuntm...
PostPosted: 10:44 - 27 Oct 2016    Post subject: Reply with quote
bendy straw with some warm blutak on the end?
arry
PostPosted: 10:24 - 31 Oct 2016    Post subject: Reply with quote
I'd be pretty amazed if it's anywhere near 2 hours labour to remove headlight.
Different model (mine was older single headlight style) but I remember stripping near every bit of plastic away in less than an hour when I serviced mine.
Kawasaki Jimbo
PostPosted: 10:44 - 31 Oct 2016    Post subject: Reply with quote
Magnet on a stick. Make one or buy one.
PostPosted: 10:44 - 31 Oct 2016    Post subject: Re: CBR600F Sidelight Bulb Dropped In Headlamp Help Reply with quote
Just leave it in there? Is it causing a problem?
UnknownStuntm...
PostPosted: 11:06 - 31 Oct 2016    Post subject: Re: CBR600F Sidelight Bulb Dropped In Headlamp Help Reply with quote
Prolly rust, at a guess.
DrSnoosnoo
PostPosted: 11:44 - 31 Oct 2016    Post subject: Re: CBR600F Sidelight Bulb Dropped In Headlamp Help Reply with quote
OP is trying to sell it, and if someone hears a rattle he'll have to say that the previous owner left it in there.
BTTD
PostPosted: 12:13 - 31 Oct 2016    Post subject: Reply with quote
As suggested, magnet on a stick or bit of string etc.
The last post was made 9 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 55.43 Kb
