Here's A Strange One For You!.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
jaffa90
PostPosted: 00:43 - 01 Nov 2016    Post subject: Reply with quote
What happens if you push the bike away from the pumps and tried then?
Teflon-Mike
tl;dr
PostPosted: 02:29 - 01 Nov 2016    Post subject: Reply with quote
Is it a cyclone alarm by any chance?
Are you disarming the immobilizer via a radio fob?
If so are the batteries about kaput?
I ask about the cyclone as had similar trouble, not necesserily on petrol stations; but the key fob design meaning that the battery kept going flat from button being pressed in pocket.
And anomaly you 'may' have in a petrol station is standing over the bike, turning the ignition 'on' before pressing the dissarm button on the fob... this may effect other alarm systems... but took me a few times to cotton on....
'Normally' you are walking up to the bike; you dissarm the remote, then put key in ignition and turn on.
At a petrol station; you take key out the ignition, open petrol cap with another key; fill pay then climb back onto bike, put key in ignition and instinctively turn it on... then remember the remote..... but by THAT time, the alarm has sensed voltage on the ignition circuit, and not having been disarmed FIRST, triggers the 'hot-wire' disable.... which often requires a complicated sequence on the remote to 'clear' OR the alarm being unplugged to wipe its memory and reset....
But, low fob batteries often cause anomalous settings or lack of, and in a petrol station with the tin hat and so much metal work around reflecting radio waves interference could just be swamping a weak fob signal.
mentalboy
PostPosted: 02:46 - 01 Nov 2016    Post subject: Reply with quote
ZX-7R wrote:
Its not a key fob 'bleeper' style immoboliser,but the Datatool one where you press the silver disc against the one fitted to the bike.It beeps and then you insert the key into the ignition.If you don't turn on the ignition within about 10 seconds or so it rearms itself.
Mate of mine had one of those types of Datatool fob thingys, gave him no end of grief. It would play up pretty much every time he went to start the bike. I think he bought a new fob and sensor in the end.
Make mine a Corona.
PostPosted: 09:50 - 01 Nov 2016    Post subject: Reply with quote
ZX-7R wrote:
Datatool
The Oxford of immobilisers.
https://www.sonicsideshow.com/blog/-how-to-bypass-a-datatool-system-3-motorcycle-alarm
mentalboy
PostPosted: 22:32 - 01 Nov 2016    Post subject: Reply with quote
ZX-7R wrote:
Think i might just remove it altogether and hopefully will be okay then.Sometimes certain security is more aggro than its worth.
That was what we were going to do with the 'Blade but trying to get everything out cleanly was going to be a major ballache, don't forget that these things are spliced into the loom and, if I recall correctly, in several places.
Make mine a Corona.
The last post was made 9 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 64.26 Kb
