Jawa 500 884 oil mixed with fuel + oil level banjo broken
PostPosted: 15:27 - 01 Nov 2016    Post subject: Jawa 500 884 oil mixed with fuel + oil level banjo broken Reply with quote
Bit of a niche question, but I can see at least Ariel has had involvement with them...
I've got a Jawa 500 884 in lay down configuration.
First off, due to a gummed carb, methanol got mixed with the oil. It was run a bit like this, but never under load.
I'm flushing it several times cold with cheap oil, then going to do it a couple of times with R40, then another flush or two with R40 with it running.
Should that be ok? I've ordered a USB endoscope and will have a look down the bore.
In the process of looking at the issues, I also managed to snap the (already weakened, I reckon ... my excuse Razz ) upper oil level tube banjo. Got one on the way, but probably won't be with me until Friday and ideally want it running before then. Can I run it without it? Presume it shouldn't cause any problems and they are basically merely two tapped holes in the crank case, so can be blanked?
The last post was made 9 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 15 - Page Size: 28.04 Kb
