| 1-up |
 1-up Nova Slayer
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 16:54 - 01 Nov 2016 Post subject: |
Find 3 yellow wires coming out of the stator. Set your multimeter to AC and meassure the VOLTAGE between the 3 yellow wires, all combinations, with the engine running. You should be getting anything between 30V and 60V. All three readouts should be very similar. Preferably, at high revs: 60V-60V-60V.
The out comes:
1) No power at any combination of wires = DEAD STATOR
2) No power at one of the combinations = DEAD STATOR
3) Very reduced power output = SOON TO BE DEAD STATOR, if not alredy
4) High voltage at running engine = THE STATOR IS ALRIGHT, move on to the next thing = the REG/REC.
Charging being present suggests the Rectifier (the AC to DC convertor) works just fine, but there might be a problem with the Regulator. Both being a one unit, try a different Reg/Rec = you may use any Reg/Rec for a short test, that has the same plug/socket.
IF this won't help, then there's a huge short circuit. Find all the earth points, check all the wiring and plugs for oxidation (white and green stuff) and clean them if necessary.
PS: There is a very unlikely possibility, the rotor of the alternator lost it's magnetic properties, but I've never, ever experienced that before. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| 1-up |
 1-up Nova Slayer
| RhynoCZ |
 Posted: 17:00 - 01 Nov 2016 Post subject: |
If you can't do the AC Voltage test, you may also measure the resistance at those wires, when the engine is off. You may also check whether the stator is not shorting to the ground. I'm not going to give you any Ohm values, as that depends on your multimeter. My multimeter reads less than 1 (10ohms, being 01.0 on the display?), so I'm getting numbers like 00.8 - 00.7 - 00.8. Anyway, I preffer the AC Voltage test.
When doing the AC Voltage test, be careful not to electrocute yourself.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| 1-up |
 1-up Nova Slayer
| RhynoCZ |
| 1-up |
 1-up Nova Slayer
| RhynoCZ |
 Posted: 17:11 - 01 Nov 2016 Post subject: |
I'm not sure whether your VFR has a Mosfet type Reg/Rec (2 plugs) or the ''regular'' unit though.
Either Way, the AC Voltage test will give you the answer.
EDIT: You can also come to a conclusion, the charging system is alright. Then you're going to have to check the wiring harness of the motorcycle and I would definitely start at the lights switch. A drop in the voltage this big would suggest a huge short circuit.
By the way, a proper charging system should give you about 14v at idle (could be lower/higher) and no more than 15v at high revs. 14.5v would be ideal. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| 1-up |
 1-up Nova Slayer
| RhynoCZ |
 Posted: 17:51 - 01 Nov 2016 Post subject: |
Cool, yes the PC fan mod was quite popular to keep the VFR's Reg/Rec unit temp down. I'd aim for an Reg/Rec unit with a heatsink and maybe use a PC thermal paste to mount it. I bet it's bolted down to a flat piece of aluminium or steel (part of the frame), just like on any other motorcycle, that doesn't have the unit exposed.
Glad to help.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| P.addy |
 P.addy Red Rocket
| 1-up |
 1-up Nova Slayer
The last post was made 9 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
