Removing a rounded off grub screw?
Itchy
PostPosted: 16:08 - 04 Nov 2016    Post subject: Removing a rounded off grub screw? Reply with quote
I have a grub screw which is slightly recessed into a hole. The allen head is completely rounded off.
Any ideas on how I can remove it?
Thanks
Hawkeye1250FA
PostPosted: 16:20 - 04 Nov 2016    Post subject: Reply with quote
I've done it with a Dremmel before now (once) - bit of a faff but I couldn't think of any other way.
Drilled it out with a drill bit slightly smaller than the diameter and then worked the remaining threads out with needle nose pliers.
Took about 30 mins.
WD Forte
PostPosted: 16:27 - 04 Nov 2016    Post subject: Reply with quote
sacrificial hex key and JB kwik weld
after cleaning out/keying up the hole might do it
bikers smell of wee
Hawkeye1250FA
PostPosted: 16:29 - 04 Nov 2016    Post subject: Reply with quote
I like this idea as well!
PostPosted: 16:54 - 04 Nov 2016    Post subject: Reply with quote
Torx bit and a hammer.
Azoth
PostPosted: 17:05 - 04 Nov 2016    Post subject: Reply with quote
Another trick is to use a small Dremel-type diamond cutting disc to cut an incision into the head, so that you can unscrew it with a screwdriver or impact driver.
Safety in numbers
Itchy
PostPosted: 17:52 - 04 Nov 2016    Post subject: Reply with quote
Looks like it's going to have to be this or drilling Thumbs Up
Can't do this as the grub screw is sunk below the surface by about 2mm.
Itchy
PostPosted: 18:06 - 04 Nov 2016    Post subject: Reply with quote
Ahahaa...
I had a look inside the thing... the grub screw is stuck because it's a not a grub screw. It's a casting that looks like a recessed grub screw and therefore impossible to remove! Laughing
Hawkeye1250FA
PostPosted: 19:33 - 04 Nov 2016    Post subject: Reply with quote
Itchy wrote:
Ahahaa...
Brilliant! Smile Smile hahahaha
tom_e
PostPosted: 09:23 - 05 Nov 2016    Post subject: Reply with quote
Itchy wrote:
Ahahaa...
I was going to laugh and then I remembered all the time I spent trying to get the nuts off the back of my oil cooler mount until I realised the mount was just cast to look like it was nuts and in fact the bolt just screwed directly into the mount Embarassed Laughing
MCN
PostPosted: 09:48 - 05 Nov 2016    Post subject: Reply with quote
Itchy wrote:
Ahahaa...
In that case you need a bigger hammer.
The Technician's Mantra
'If at first you cannot fit it
Pick up a hammer
And f*&kin' Hit it.'
Pjay
PostPosted: 10:35 - 05 Nov 2016    Post subject: Reply with quote
I use a torx bit, hit it home and win.
Never failed me yet.
The last post was made 9 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 74.91 Kb
