Mame Romsets Woe
Pjay
PostPosted: 10:01 - 05 Nov 2016    Post subject: Mame Romsets Woe Reply with quote
I am trying to get my mame romset to work on a Raspberry Pi running Retropie, Emulation Station and mame4all.
Now...
The mame set I have works wonderful on my old and trusty mame32 on my windows setup, but every time I try to load up a rom in mame4all, it errors with incomplete roms.
I know it's all about having the right romset for each emulator you have (They need to all stick to a fkin standard set that gets updated and work around that) and so you need to scour the web and do some hoop jumping.
So, before I hoop jump and piss about with Clrmamepro, does anyone have a link to a working verified romset that would work for me?
I have the latest build of retropie and mame4all.
UnknownStuntm...
PostPosted: 12:34 - 05 Nov 2016    Post subject: Reply with quote
37b5 should get the right set you need
Pjay
PostPosted: 14:29 - 05 Nov 2016    Post subject: Reply with quote
Didn't work Sad
I am rebuilding them as we speak, they seem to be rebuilding fine, so thanks for making it a little easier Thumbs Up
Pjay
PostPosted: 18:43 - 05 Nov 2016    Post subject: Reply with quote
Fk this!
I have tried rebuilding another set into 0.37b5 no joy running, but builds fine.
I have downloaded 0.37b5 set, no joy running.
I can only assume I need another romset.
The plot thickens.
UnknownStuntm...
PostPosted: 19:02 - 05 Nov 2016    Post subject: Reply with quote
Have you tried the other mame emulator? There's also an experimental one you need to build, works OK on a RPi2 or 3.
Pjay
PostPosted: 19:03 - 05 Nov 2016    Post subject: Reply with quote
Yeah I've tried Mame2003, same issues.
Alan1986
PostPosted: 19:06 - 05 Nov 2016    Post subject: Reply with quote
I am using 0.37b5 romset and a load work,
I was spoilt for choice, can't quite remember what I played them in, it was on the pi 3, some only worked on irmame4all,
And some I had to try in a different mame emulator,
I still have the file, it's a gig in size, if you have a way I can easily upload this I'll be happy to
Can't remember where I got it from, I would have just Googled the Romset I reckon
Not sure of the forum rules so feel free to delete this,
Think thats what I used,
https://archive.org/details/Mame0.37b5RomsAndBios
Cbt Done, Currently wobbling around on a Cbf125 and love it
DAS some time soon
Pjay
PostPosted: 19:41 - 05 Nov 2016    Post subject: Reply with quote
Yeah that's the set I have.
I have no idea why I am getting the errors on launch as everything I have done checks out and I'm not a mame noob, I've been using mame since 98. I have checked them over with Romcenter and they seem fine, same with Clrmamepro.
I have RetroPie 4.0.2 installed and updated.
I know romsets can be a pain, but this is a joke. I have done everything by the book and then some.
I also have the original zips of everything, so I can reset myself to zero easy enough and have done twice already. Maybe I will installing mame4all myself in retropie.
Alan1986
PostPosted: 19:46 - 05 Nov 2016    Post subject: Reply with quote
When I downloaded the set I just dropped all the rom zips into the mame4all folder and they ran,
I didn't mess with any of the files at all,
I have only a few on my card now, if you want I can email the zips over?
A few roms at a time?
I have about ten games that work fine, as I was fed up of a huge list of games,
Want me to send one which I know works for sure?
Might help you fault find if it works fine on mine
DAS some time soon
Pjay
PostPosted: 19:52 - 05 Nov 2016    Post subject: Reply with quote
I have that romset you linked, I dropped them into the folder as is and mame sees them fine but gives the file missing error you get when you have the wrong set installed.
I have checked and they are for sure the 37b5 set, verified by Romcenter.
So you'd only be sending me what I have.
I am going to try Advancemame, see if that sorts it.
If not I will just reinstall mame4all into Raspbian and fuck retropie off.
Edit: can you just name me the roms you know work?
Alan1986
PostPosted: 19:54 - 05 Nov 2016    Post subject: Reply with quote
I am not 100% sure where I downloaded my set from,
I just linked the above as it looked similar,
I know the set I have works 100% ok, might be worth a shot,
Personally I think retropie works well,
Maybe it is a different issue your having
DAS some time soon
Pjay
PostPosted: 19:58 - 05 Nov 2016    Post subject: Reply with quote
Do you have dropbox that you can put them in and link them?
Commuter_Tim
Depends which ROMs are in the pack, a lot are freeware now and couldn't possibly fall foul of forum rules.
MAME is definitely open source, and that pack you linked is in the open source section, but that's if the uploader isn't ignorant.
I ride a Bandit 600... badly.
Pjay
PostPosted: 20:02 - 05 Nov 2016    Post subject: Reply with quote
I 100% downloaded that pack and have checked the crc hashes against the verified romset and they come back correct.
This is baffling me Very Happy
Alan1986
PostPosted: 20:06 - 05 Nov 2016    Post subject: Reply with quote
Try :
baddudes 445kb
dino 4,019kb
mk 5,365kb
mk2 13,315kb
mk3 20,156kb
moonwlkb 2,379kb
outrun 853kb
punisher 3,947kb
wwfmania 18,275kb
xmen 4,144kb
All above zip files
Those are the roms I've kept and working, I did mean to add more but haven't got round to it,
In my folder I do also have:
qsound.bin 8kb
qsound.zip1734104192 3kb this is a zip file
neogeo 261kb this is a zip file
Also there is an artwork and samples folder which is empty,
The q sound and neo geo files may only be in there when I was messing around trying to get other games to work, I'm unsure, they may be needed hence not deleted
DAS some time soon
Pjay
PostPosted: 20:22 - 05 Nov 2016    Post subject: Reply with quote
Cheers, I will give those a shot.
I am just rebuilding retropie from scratch again so I will let you know once it's done.
UnknownStuntm...
PostPosted: 22:32 - 05 Nov 2016    Post subject: Reply with quote
Try a few 0.78 roms, see if they work?
Pjay
PostPosted: 00:09 - 06 Nov 2016    Post subject: Reply with quote
I just rebuilt the SD card with raspbian and then added mame4all and it all works fine.
Retropie didn't play ball at all, maybe the new version needs a different romset.
Everything I am trying runs perfectly, cheers for the help chaps.
Alan1986
PostPosted: 01:26 - 06 Nov 2016    Post subject: Reply with quote
Any recommendations on games to try?
DAS some time soon
Pjay
PostPosted: 09:29 - 06 Nov 2016    Post subject: Reply with quote
Im a fan of the good old top down/scrolling shooter.
Starforce, Twin Cobra, Nemesis, R-Type II and Defender stole loads of my monies when I was a kid. Since then I have reclaimed most of it in enjoyment from mame.
Others:
Galaxians - Old though
Centipede - Old though
Viper Phase 1
Fever SOS
Other types@
10 Yard Fight is aces for simplicity but addictiveness
Double Dragon is ace
Kung Fu Master is frustrating, but rewarding
Donkey Kong and Pacman are wonderfully maddening, but old.
Hours of fun to be had there.
The last post was made 9 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 100.97 Kb
