Mobile phone shop bullshitter?
PostPosted: 09:21 - 06 Nov 2016    Post subject: Mobile phone shop bullshitter? Reply with quote
My Mrs has had a mobile contract with vodafone for years. She only uses her phone for voice and text and struggles to use a touchscreen.
As such, like me, she uses a simple dumb phone. Currently a Nokia 105. In my oppinion, almost certainly the best thing for her. Long battery life, less chance of breakage, cheaper to replace when dropped down the toilet (twice in the last 12 months so far) and a good signal.
We've recently both noticed the incidence of dropped calls and loss of signal on dialling has increased. Coverage has definately deteriorated over the last 2 years but the showing a full signal then dropping it as soon as you try to make/receive a call is a new one. I also now regularly get a "call not allowed" message when I attempt to make a call with a full signal showing.
Now I think this is all to do with the roll-out of smart meters snarling up the mobile networks. The wife thinks it's her phone.
So she went to the vodafone shop to see what they would do about it. First he changed her SIM card (and lost all her contacts in the process). I'm not clear what this was supposed to achieve.
Then he told her it was because they were rolling out 4G in the area. Then he told her it was because her dumb phone only uses 2G and like nobody uses that any more innit? He went on to suggest that the only way she's likely to get a decent signal in future is if she gets a 3 or 4G compatible smartphone.
Just to confirm this is a load of finest, grade A bullshit in an attempt to upsell her a smartphone?
My understanding is that all normal voice calls by mobile phone are still made using the 2G network? 3G and 4G Are for data only and the only way you'd use it for voice calls is via VOIP?
It's also my understanding that most dumb phones will get better reception than a smart phone due to less power demand and more room for an antenna?
The entertaining bit is what'll happen when she goes back to see the guy. He'll be wishing he'd sold her one of those bumphones.
TL;DR
Vodafone dude says crappy signal is because my wife is using a dumb phone. He says she should upgrade to a smartphone because she needs 3 or 4G coverage to make phone calls nowadays. I say this is upselling bullshit, voice calls all use 2G and it's inadequate network provision that's the problem.
PostPosted: 09:33 - 06 Nov 2016    Post subject: Reply with quote
You're right, 3G, 4G are just to do with the speed of data transfer for emails, internet etc.. Voice calls are on the GSM/2G network (assuming you're not using Whatsapp/Skype etc.)
Might be worth talking to the call centre rather than one of the monkeys with pointy shoes and silly hair in their shops.
recman
PostPosted: 09:36 - 06 Nov 2016    Post subject: Reply with quote
Vodaphone. Laughing
PostPosted: 10:04 - 06 Nov 2016    Post subject: Reply with quote
recman wrote:
Vodaphone. Laughing
Agreed.
However, any other network Laughing Brick Wall
https://i48.photobucket.com/albums/f216/stinkwheel/phonecover.png
That's 2G coverage indoors according to offcom.
bamt
PostPosted: 10:05 - 06 Nov 2016    Post subject: Reply with quote
That's not quite right. 3G and 4G have the capability of carrying voice too - a simple way of thinking about that is that 3 (which launched without a 2G network in the UK) would not have been able to carry voice calls on its own network. If you are sitting on 3G with Vodafone, your voice call will be made over 3G. Handover of voice calls between 3G and 2G (and vice-versa) was a big issue back in the early days of 3G rollout.
If a 2G only phone is showing signal, then it has nothing to do with strength (or otherwise) of the 3G/4G network. However, a 2G cell has much lower capacity for calls so it is easy for a phone to show signal available because it can hear the base station, but when it tries to negotiate a time slot the base station says no. Again, this was an big issue back in the late 90s/early 2000s, when networks were just starting to give contracts with loads of minutes (like Orange's Everyday 50, that gave you 50 minutes off peak every day, compared to an equivalent priced traditional tarrif that gave you 15 minutes a month). That was actually one of the bigger drivers for 3G - increased call capacity - rather than fast mobile data. Now that most people use 3G, there is more investment in that network than the 2G.
So, it could be that the phone is dying (can hear the network fine, but when it tries to transmit the output power is low, so the base station can't hear it properly) or it could be a network issue. Only real way to find out without test gear is to swap out the handset.
CaNsA
PostPosted: 10:22 - 06 Nov 2016    Post subject: Reply with quote
stinkwheel wrote:
recman wrote:
Vodaphone. Laughing
Agreed.
Vodafone have the best coverage it would seem...
https://i.imgur.com/4lBBqxH.png
PostPosted: 10:28 - 06 Nov 2016    Post subject: Reply with quote
And therein lies the proof. My own work phone has exactly the same issues and is on the same network.
CaNsA
PostPosted: 10:31 - 06 Nov 2016    Post subject: Reply with quote
The VF website shows this for Carlisle.
We've fixed an issue in this area recently. Sorry if you noticed any disruption - things should have been back to normal since 9.35am 02 Nov 2016
and
We've been doing some work on our network in this area to improve your calls, texts and data coverage. Sorry if you noticed any disruption - we were working between 8am 04 Nov 2016 and 6pm 04 Nov 2016.
And
Near Little Orton
We're trying to fix a network issue which might be affecting calls coverage. It’s now being investigated. We'll update this page as soon as we know more.
temeluchus
PostPosted: 10:32 - 06 Nov 2016    Post subject: Reply with quote
The masts do take a beating in the wind.
I used to work for orange and had to send out people to repoint antennas in the windier parts of the country quite frequently. Could also be an issue with the gsm kit on their end, lots of people primarily talk over 3g these days so a GSM issue might take a while to be noticed.
Give vodafone a bell and report the issue.
As for quality of signal, that varies phone by phone regardless of it being a feature phone or smartphone etc.
PostPosted: 10:39 - 06 Nov 2016    Post subject: Reply with quote
CaNsA wrote:
Near Little Orton
Interesting, that would probably be one of our nearest masts.
Assuming this issue has been going on for months and they've only just noticed.
In any case, I doubt the solution is to go out and buy a smartphone.
doggone
PostPosted: 11:34 - 06 Nov 2016    Post subject: Reply with quote
I wonder if the TX chip does deteriorate over time as used to happen with CB radios.
I might try another brick phone, Nokia 3510s are widely available for peanuts and the low signal performance is excellent.
I don't think there's an actual conspiracy to make you upgrade but they have been turning some masts off as a result of things like orange and one2one merging.
Some places inevitably will suffer.
The last post was made 9 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 76.4 Kb
