Muff making things stiff
SophR so good
PostPosted: 22:37 - 06 Nov 2016    Post subject: Muff making things stiff Reply with quote
Honk.
Ste has just put some tucano urbano muffs on my bike but they've rendered the throttle too stiff to twist, it certainly doesn't snap back.
Does anyone know of any workarounds before we just cut the rubber bit off where it's rubbing on the throttle grip? If I can avoid slightly destroying them that would be nice.
You win again, gravity! - Zap Brannigan, BCF BBQ 2016
ADSrox0r
PostPosted: 22:47 - 06 Nov 2016    Post subject: Reply with quote
tbh I hated the Tucano Urbano neoprene ones for the same reasons, restrictive and interfered with controls and wotnot. I switched to their newer polyamide ones and they're far better.
https://www.tucanourbano.com/gb/polyamide-hand-grip-covers-9268.html
And yes...muff, stiff....titter etc
SophR so good
PostPosted: 22:56 - 06 Nov 2016    Post subject: Reply with quote
Dammit! Couldn't work out which would be better as their website is a pile of poo so went with the ones with the earlier delivery date. Don't think I can send them back and swap now they've been attached.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:05 - 06 Nov 2016    Post subject: Reply with quote
The day that someone puts muffs on the eggcup is the day that I erm....
Anyway. The problem is that the bar end is causing friction. undo the screws for the switchgear and push it towards the light. then do them up a bit.
Triumph Sprint ST 1050
Pigeon
PostPosted: 23:22 - 06 Nov 2016    Post subject: Reply with quote
Excellent thread title. Thumbs Up
Can't comment exactly. But if the bar-end end is rubbing, can you shim it out a bit using washers?
ADSrox0r
PostPosted: 23:42 - 06 Nov 2016    Post subject: Reply with quote
You should be able to loosen the bar end, pull it out a bit and re tighten at that position giving it more wiggle room.
SophR so good
PostPosted: 23:45 - 06 Nov 2016    Post subject: Reply with quote
Three suggestions of budging the bar end weights outward... I'll get up early and see if it can be done. I can't see that they'd design them so stupidly so this makes sense! The rubber overlaps both throttle and bar end weight gluing them together so hopefully this will work. Cheers guys!
Shinigami
PostPosted: 23:52 - 06 Nov 2016    Post subject: Reply with quote
Bar end isn't rubbing, its due to the mounting setup, rubber cap goes through end of muff and over the bar end and is then supposed to also go over the grip, this is causing bat end and grip to basically act as one. I suggested cutting off the rubber that goes over the grip as the muff will still be held on by the bar end bolt and washers I added (original bolt was too mall for the fixing hole of the end rubber)
Soph doesn't want to cut it though.
I doubt moving the bar end out will help much as it will be loose on its bolt and likely fall out, shed also lose an inch of her throttle width...
Hawkeye1250FA
PostPosted: 09:43 - 07 Nov 2016    Post subject: Reply with quote
Had the same problem on mine (for about 8 seconds - before I took the stanley knife to the annoying rubber bit)
Muff and Throttle work as one now and the bar end is left to its own devices.
PostPosted: 10:24 - 07 Nov 2016    Post subject: Reply with quote
Get longer bar ends OR longer screws for current bar ends. Enough to put on the outside of the muff with a large washer and remove the stupid rubber mounty bit.
That is what I did on the triple, it stopped it popping off at 110.
SophR so good
PostPosted: 10:46 - 07 Nov 2016    Post subject: Reply with quote
Think it's going to be a stanley knife jobby then. Changing gear this morning was a clusterfuck, and longer bar ends would need to be seriously longer (plus I don't do 110 as a matter of routine Paddy!)
DrDonnyBrago
PostPosted: 15:37 - 07 Nov 2016    Post subject: Reply with quote
Not sure what the inside of the neoprene jobbies are like, but on the big furry muffs they have a rubber thing which goes over the bar end. If the tip is too deep in to the rubber then it chafes on the shaft when you twist it.
The trick is to withdraw the shaft from the rubber until it is in a good position, then wrap a cable tie around it.
kramdra
PostPosted: 23:09 - 12 Nov 2016    Post subject: Reply with quote
Not used them, but the attachment to bar end looks a shit design. all that is needed, small slot in the bar end for the muffs to sit in. Has worked nicely with tech7 muffs
Yorkshire Geek
PostPosted: 23:26 - 12 Nov 2016    Post subject: Reply with quote
I have no words for how much this sentence pleased me.
dn38416
PostPosted: 14:05 - 28 Dec 2016    Post subject: Reply with quote
sorry for raking this up, but i am about to fit the polyamide R333 model. Now i'm not the sharpest tool in the box, but the instructions seem massively crap.
I got a GPZ500 with stock bar end weights, the short rubber barrel fits over them without reaching the throttle grip, so OK on that front. Do i need to put the metal clamp on as well as take the bolt out of the bar end? Or is it one-or-the-other. I'm a bit reticent to take the end weight apart i'm sure it will screw something else up. This guy (https://www.youtube.com/watch?v=MWisflUEIfY) seems to take the whole end weight apart, don't know why though.
Second question: the inserts that make the muff rigid along the sides - are they worth putting in? I don't see the point, they add nothing to securing it to the handlebars.
The last post was made 9 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.38 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 83.32 Kb
