Bandit Wiring - where does it go?
mudcow007
PostPosted: 10:50 - 07 Nov 2016    Post subject: Bandit Wiring - where does it go? Reply with quote
On the weekend I lost power to my clocks on my Bandit (600 "nakkid")
So removed the two triangle trim panels to see if i could spot the issue an dont know if its the same on all Bandits but all of the little looms/ connectors are all just sat behind the headstock and are manky...
With the bike not having fairings what's to stop all the wiring getting soaked?
My bike is a P reg so no doubt people have fucked about with the wiring over the years, well judging by the black electrical tape an chocolate block connectors anyways..
Commuter_Tim
PostPosted: 15:34 - 07 Nov 2016    Post subject: Re: Bandit Wiring - where does it go? Reply with quote
Did you mean headlight?
On my Bandit the majority of wiring connectors are in the headlight.
Someone had run oxford heated grips which they had placed connectors behind the little panels below the tank though.
I ride a Bandit 600... badly.
mudcow007
PostPosted: 16:32 - 07 Nov 2016    Post subject: Reply with quote
Nope headlight on mine was empty except for the headlight bulb holder thing, pilot bulb an little bit of wire from/ to indicators.
Everything else was stuffed under the tank/ behind the infill panels
Im guessing this isnt correct then??
Shocked
Commuter_Tim
PostPosted: 18:51 - 07 Nov 2016    Post subject: Reply with quote
Shocked
If I had to guess, some dipshit had trouble fitting the wiring back in and screwing the headlight on. (took me some trouble when I rewired and didn't take a photo beforehand)
Even shit scootehys, 125s, and the 500 I had all had the wiring connectors in the headlight.
Explains why the headlight bulb wiring was still in there, it can't reach further.
MKJ
PostPosted: 19:41 - 07 Nov 2016    Post subject: Reply with quote
Shocked
Which connectors are you talking about? On mine the yellow, green, 2x blue, and black connectors are all kept nicely under the tank. Are you sure all of those are meant to be in the headlight?
Commuter_Tim
PostPosted: 19:50 - 07 Nov 2016    Post subject: Reply with quote
Fair do, in that case relevant info time...
Which year Bandits are we all talking about?
Mine is a '95 (I only understand year models not letter Reg) and the only wiring under the tank was for Oxford grips running to the battery.
MKJ
PostPosted: 20:06 - 07 Nov 2016    Post subject: Reply with quote
Mines a 2000 reg, wiring is slightly different according to Mr haynes. Does the wiring from your switchgear go into headlight casing too?
bamt
PostPosted: 20:43 - 07 Nov 2016    Post subject: Reply with quote
Just a thought - is your Bandit really a naked, or was it faired and has had them removed? If the latter is the case, then the wiring was probably too long to stuff into the headlight. Does it have the original headlight, come to that?
MKJ
PostPosted: 21:00 - 07 Nov 2016    Post subject: Reply with quote
Not sure if your asking me, but mine has always been naked. Recently replaced the loom with an unmolested one. Not sure if this is how it was standard, the 20+ previous owners have changed a few bits lol
Raffles
PostPosted: 21:12 - 07 Nov 2016    Post subject: Reply with quote
mudcow007 wrote:
Nope headlight on mine was empty....Everything else was stuffed under the tank/ behind the infill panels
This is the inside of my 1989 Bandit headlight:-
https://s15.postimg.org/8s1m4p24b/IMG_6007_1.jpg
It's pretty much as it should be apart from the missing grommets and the shit choc connectors.
PostPosted: 21:25 - 07 Nov 2016    Post subject: Reply with quote
Charlottes N reg 600 Bandit had most of the connectors hidden inside the headlight bowl. Lousy picutre but:-
https://www.alfa-pages.co.uk/TempPicture/BanditSwitchgearConnectors.jpg
Katy
PostPosted: 22:26 - 07 Nov 2016    Post subject: Reply with quote
There's a big ground junction in the bandit loom. When people remove the headlight to fit those stoopid looking bates spots there's not enough room for the loom inside them so they do the same and jumble the wires up somewhere. This lets the weather into the loom and the ground junction rots away until you start getting all sorts of electrical failures. First to go is the dash lights normally.
mudcow007
PostPosted: 09:45 - 08 Nov 2016    Post subject: Reply with quote
Cheers all, mine is a P reg (1996?) so would/ should be the same as Commuter_Tim's?
Its possible that the bike was faired at some point but wasnt when i got it.
The fairings (on the tail) say Bandit N. The frame is bright blue if that helps?
Mine still has the mahoosive round headlight with the 3 access holes in the back. Always thought it was a little weird being so big an empty in there
Didnt get a chance to fiddle with the wiring last night but plan to tonight
ta
PostPosted: 13:08 - 08 Nov 2016    Post subject: Reply with quote
Bandit N is naked version.Wiring should be in the headlight nice and dry.
mudcow007
PostPosted: 14:31 - 08 Nov 2016    Post subject: Reply with quote
Cheers Pete
Will have a look tonight, to be fair the loom(s) that are tucked under the tank do seem quite long
Commuter_Tim
PostPosted: 18:38 - 08 Nov 2016    Post subject: Reply with quote
They appear even longer when you're trying to coil them up around the inside of the headlight without anything pinching or crushing! Wink
If you don't have any luck I'll nip out tomorrow and take a photo of mine.
It's a Bandit 600N too, so I don't imagine the wiring will differ.
mudcow007
PostPosted: 13:28 - 20 Nov 2016    Post subject: Reply with quote
Sorry only just getting around to this (been hailstoning for days..)
I can confirm the loom(s) are mahoosive an will easily fit inside the bowl.
Im now wondering if its really a faired bike but made naked?
Will try an stuff it into the bowl an see how it goes
cheers chaps Thumbs Up
Commuter_Tim
PostPosted: 20:34 - 20 Nov 2016    Post subject: Reply with quote
Kind of confusing reply, but as Mr Pete says, if it says 600N on its arse, then it's a naked, or someone put the rear cowl of a naked on it.
Anyway, here's a shit potato phone picture of mine that fits...
Excuse the little white Choc-blocks, I didn't butcher the cables, just not got round to resoldering yet.
Probably not the most conventional of cable routing, but it all works and closes up nicely.
mudcow007
PostPosted: 21:11 - 20 Nov 2016    Post subject: Reply with quote
huzahh!
Got it all back in the bowl, there is still a connector under the tank, but it looks a lot different to all the others so presume its suppose to be there
Cheers Tim, that help, i have put mine as a basic loop around the headlight bulb too
I now have the added advantage of working clock lights too - its a bingo! Thumbs Up
Raffles
PostPosted: 21:18 - 20 Nov 2016    Post subject: Reply with quote
Commuter_Tim wrote:
Anyway, here's a shit potato phone picture of mine....
Tim, what's going on with the RHF (nearside) headlight mounting? It looks like it's about to fail.
Commuter_Tim
PostPosted: 22:23 - 20 Nov 2016    Post subject: Reply with quote
Good eye.
The bolt/nut were cross threaded and mashed on super tight when I bought it, which seemed like it deformed the white plastic washer and rubber bung.
That was the least of my worries, before the choc blocks, it appeared the previous owner had his pet hamster chew on the wires before he wrapped the cable running to heated grips around them.
The last post was made 9 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 115.21 Kb
