Installing bathroom extractor fan
PostPosted: 19:37 - 07 Nov 2016    Post subject: Installing bathroom extractor fan Reply with quote
Going to fit a SELV type bathroom extractor. Supposedly it needs an isolator (I'm unclear exactly why).
So, where to fit the isolator?
Does it go in the 240V side or the DC side?
Does it go inside the bathroom or can it be up in the loft/outside the door.
Seems stupid to take 240v into the bathroom when there's no need to so I'd preferr to either have the isolator on the DC side inside the bathroom OR on the AC side up in the (floored) loft.
Part P blah, blah. Whatever. It's my house. It was like that when I got here. etc. If it was that much of an issue, how come someone managed to fit non-fireproof, unsealed, 240v halogen spots in the bathroom ceiling then sell the house to me?
faffergotgunz
PostPosted: 20:41 - 07 Nov 2016    Post subject: Reply with quote
Usual practice is to mount the isolator outside of the bathroom on the 230v side. In a place where it can be reached.
The regs have changed in recent years to allow sockets in a bathroom. Provided they are in the correct zone (basically not in the area vertical of the bath/shower or sink) AND they are circuits protected by a RCD upto 30ma. Most households have rcds nowadays. So in you could mount the isolator in the bathroom if you needed to.
I used to mount the isolator and transformer next to each other, directly outside of the bathroom, high level (cables straight from the loft). Then run a 1.5mm cable to the 12v fan in the bathroom (via the loft).
Sent from Samsmums mobile using Tapanarse
faffergotgunz
PostPosted: 20:46 - 07 Nov 2016    Post subject: Reply with quote
Edit: 230v sockets can be installed 3m from zone 1
Here's a drawing with the zones for you:
https://www.lyco.co.uk/blog/wp-content/uploads/2013/02/Bathroom-Zones.jpg
(Been out of the domestic game for a while)
janner_10
PostPosted: 21:11 - 07 Nov 2016    Post subject: Reply with quote
Just pull a live feed from light ceiling rose (or the switched live if you want it to come on and off with the light only), through said isolator and onto the fan.
You can fit isolator above the door on the outside, easy to fit with no dicking about if you have a plasterboard wall.
As mentioned, "It's been there since i moved in"
Wonko The Sane
PostPosted: 21:35 - 07 Nov 2016    Post subject: Reply with quote
if it's any help, the extractor fan isolator in houses I've rented was usually above the bathroom door, 50/50 as to which side of the door it was above
PostPosted: 10:21 - 08 Nov 2016    Post subject: Reply with quote
Outside the door it is. Thumbs Up
hmmmnz
PostPosted: 17:37 - 08 Nov 2016    Post subject: Reply with quote
as an electrician myself,
i say do what the fuck you want, wire it straight to the light, easy as pie, and its dead when the light is, safe as houses
the humans are dead
I kick arse for the lord
J4mes
PostPosted: 18:34 - 08 Nov 2016    Post subject: Reply with quote
As an electrician who fitted my own extractor fan despite never being involved in house bashing....
Isolator in the loft. It has to be close for maintenance of the fan unit, sowhere better than right beside it (I have a 240v fan as the original 12v unit I had couldn't suck a piece of bog roll against the grill, whereas the one I have now could hold a bowling ball)
Fed off the lighting circuit with a 3amp fuse.
Didn't bother with any of the timed bollocks, it's fed straight off the switched live from the light. Light on, fan on, light off, fan off.
PostPosted: 18:37 - 08 Nov 2016    Post subject: Reply with quote
But then you have to leave the light on to clear the stench of death. Sick
J4mes
PostPosted: 18:41 - 08 Nov 2016    Post subject: Reply with quote
That kind of behavior is banished to the downstairs toilet Very Happy
stevo as b4
PostPosted: 20:06 - 08 Nov 2016    Post subject: Reply with quote
I'm upgrading my bathroom extraction fan this weekend and sorry to jump on stinkwheel's thread. But a question though,
I want to fit an in line anti back draft flap valve in the loft in the 4'' duct. What do I do with the outside grille vent then? Can I replace my broken flappy shutter vent with just a meshed grille, or are you supposed to have one of those cheap crap plastic flap vents fitted on the outside wall as well?
The issue with replacing it is that it's high up on the wall, and hard to reach with ladders. Any new plastic flap vent will be cheap and crap enough to fall apart in a few years, and I don't want to get back up there ever again, so I'm thinking a plastic mesh vent would be a better option?
PostPosted: 20:24 - 08 Nov 2016    Post subject: Reply with quote
A plain vent/grill and internal non-return valve is what I'm going for when I find someone man enough to drill a hole in my kitchen wall for it (the local bricks have black lumps in which are notorious for fucking core drills).
It needs to keep birds out.
I intend to use one called a stainless steel bull nose with insect mesh. Easy to use, easy to clean.
https://ecx.images-amazon.com/images/I/51pkTA1zmZL.jpg
I'm using a roof vent for the bathroom though.
stevo as b4
PostPosted: 21:25 - 08 Nov 2016    Post subject: Reply with quote
Cheers stinkwheel!
That looks ideal for what I need on outside wall and being Stainless it would match the porch exterior light too. Thumbs Up
Good luck core drilling the 4'' hole though, I used a 700w drill to core drill a 50mm waste pipe though a double skinned garage wall, and that bloody struggled tbh! I reckon a hard wall and a 4'' hole would need a monster of a drill to get through it though!
Raffles
PostPosted: 22:13 - 08 Nov 2016    Post subject: Reply with quote
Anyone installing/replacing a bathroom fan should not consider fitting anything other than a timer version*. They're not just for removing turd stench, they're also very good at removing the steam generated by bathing/showering.
*Unless of course you don't mind condensation and mould on your walls and ceiling.
J4mes
PostPosted: 22:21 - 08 Nov 2016    Post subject: Reply with quote
3 years no mould.
Just leave the window open while you have a shower and get dried.
light on, fan on, window open, plenty of ventilation, room clears fine.
Monkeywrenche...
PostPosted: 09:59 - 09 Nov 2016    Post subject: Reply with quote
Laughing So why have i Got a fan when I have a window? I feel a right mug now I could have saved a bit there.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
PostPosted: 11:29 - 09 Nov 2016    Post subject: Reply with quote
Opening the window is fine if you like a howling gale while you're having a shower. Also takes a long time to clear the condensation, letting expensive heat out.
Draughts = bad. Air flow = good.
The one I'm fitting has a smart humidistat. So it triggers with a sudden rise in humidity rather than the absolute level. Also doesn't come on if you're up for a piss in the night.
J4mes
PostPosted: 18:14 - 09 Nov 2016    Post subject: Reply with quote
Well you either leave the bathroom door open and get ventilation that way or leave the window open for ventilation.
If you rely on the fan to draw air through the gaps around the door it will take a month of Sundays to clear the air.
If you leave the window open without a fan there is not much force to move the air, so it takes longer to clear.
Obviously I don't mean leave it open as in fully open like you might if it was summer and 40*c inside and out. I mean leave it open enough to allow the fan to pull fresh air in to the room. We have a "top light" window and leave it open about 2 inches.
Works for us.
stevo as b4
PostPosted: 19:07 - 09 Nov 2016    Post subject: Reply with quote
Also most UPVC double glazed windows have those trickle vents built in, and I always leave them open. The fact that on a cold windy day you can feel a blast of air strong enough to move the vertical blinds, to me means that theres enough ventilation to let the fan do it's job?
I am another window open in the shower individual though, but hopefully with my new 260 square metre/hour fan I won't need to much longer?
PostPosted: 19:21 - 09 Nov 2016    Post subject: Reply with quote
Fucking trickle vents.
Mine all got unscrewed and a bit of duct tape stuck over the slot then screwed back on again.
If there's enough air coming through them to move the curtains, it's a draught, not ventilation.
If they are making a really fucking annoying buzzing noise any time it's windy, it's time for them to go!
The guy who did my thermal survey actually recommended I block them, he said they were haemorrhaging a load of heat and doing nothing useful in terms of air flow.
J4mes
PostPosted: 19:27 - 09 Nov 2016    Post subject: Reply with quote
Sealed my trickle vents because they sounded like a fucking Kazoo in the wind!
PostPosted: 19:31 - 09 Nov 2016    Post subject: Reply with quote
Isn't the lack of ventilation if you tape them up going to cause problems?
PostPosted: 19:48 - 09 Nov 2016    Post subject: Reply with quote
In my case, no. Because a draught is not the same thing as ventilation. Mine were introducing a draught and there are enough other places where air is getting in to render them unecessary in terms of ventilation.
If there were more people living in the house for a longer part of the day, it might start to become significant.
That was the direct oppinion of the expert who did my thermal assessment.
The last post was made 9 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 121.62 Kb
