Exhaust Help (GPZ 500)
JackDG
PostPosted: 16:02 - 10 Nov 2016    Post subject: Exhaust Help (GPZ 500) Reply with quote
Hi guys, as seen in photo there are 2 sizable holes where the 2 pipes merge into 1.
I have no experience welding / exhaust repairs but have friends who can help out.
From the photo is there any salvaging this? the metal around the holes is pretty flimsy and any putty just gets blown off.
thanks!
https://i.imgur.com/u4yazGb.jpg%20
1992 GPZ 500
colink98
PostPosted: 16:29 - 10 Nov 2016    Post subject: Reply with quote
don't try to weld over the holes where its all thin and wasted away.
instead get matey to stick a nice triangle over the area and weld to a better part of the metal.
i even did the designs for you in paintUP.
https://i.imgur.com/W2lHklO.jpg
Ride it like you stole it.
pompousporcup...
PostPosted: 17:06 - 10 Nov 2016    Post subject: Reply with quote
what that guy said ^^
They all go at the collector point there Sad you could weld a plate in and it might help for a little while.
Is it the stock exhaust manifold?
edit: probably not as its 2-1
JackDG
PostPosted: 17:18 - 10 Nov 2016    Post subject: Reply with quote
Yeah triangle idea looks good, but there is a dip between the two pipes, so might be tricky to get a good seal :/
Unsure if they are stock - I know stock is a 2-2 config but am unsure if these are modified stock parts or some aftermarket / diff bike exhaust.
1992 GPZ 500
TheManWithThe...
PostPosted: 18:33 - 10 Nov 2016    Post subject: Reply with quote
you could try an exhaust bandage or alternatively foil tape.
I've used the bandage on my ER5 when it went in exactly the same place, and the foil has worked higher up on the downpipes.
Slab a load of putty on, then stick the foil over it, then a bit of steel wool to bulk the area up, then wrap the fuck out of it with the bandage. With the foil tape i just filled the hole in with some putty, then taped over. Only trouble is getting the tape to stick properly, because the area will be very dirty so may not create a seal.
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
PostPosted: 18:49 - 10 Nov 2016    Post subject: Reply with quote
I'm guessing that's an ER5 exhaust. The stock 2-into-2 GPZ500 system goes at the link pipe between the down pipes.
You can bodge it for a while as above. I'd go with plumbers silicon, then a fillet of steel or aluminium over that, then optionally bandage and/or foil tape, then wrap it in something to hold it on. Steel garden wire tightly wound around is my favourite.
But start saving up for a replacement, because once exhausts go, they tend to keep going.
PostPosted: 19:14 - 10 Nov 2016    Post subject: Reply with quote
Just a potential confounding factor.
What make is it?
It might be "stainless" (quotes intentional) which complicates welding.
Despite what the manufacturer insisted on here, the collets on the nexxus system I had on my GPZs were clearly either very inferior inox or simply mild steel and rotted off. Other parts may be similar.
Grade A bodge.
Get it welded properly, the dip is no problem at all to deal with. I'd have that fixed in 20 minutes.
TheManWithThe...
PostPosted: 19:44 - 10 Nov 2016    Post subject: Reply with quote
Pete. wrote:
Grade A bodge.
It's a rolling bodge...ratbike in progress Laughing
ThatDippyTwat
PostPosted: 19:49 - 10 Nov 2016    Post subject: Reply with quote
Anyone that can actually weld* will have a plate over that in half an hour, all prep and cutting included.
*real welding, not your mate from the pub with the £50 Clarke stick unit, that thinks a line of bird shit is actually a weld.
Shinigami
PostPosted: 13:26 - 11 Nov 2016    Post subject: Reply with quote
i've just plugged the holes in my gpz500 zorst with gungum for now Laughing
don't expect the bike to be around for that many years so i'm fine with bodges through MOT new zorst will be expensive (even if I can the the studs out....)
PostPosted: 14:01 - 11 Nov 2016    Post subject: Reply with quote
Where be holes?
The last post was made 9 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 74.08 Kb
