Air filter element/ foam thickness
caprilaser198...
PostPosted: 18:18 - 10 Nov 2016    Post subject: Air filter element/ foam thickness Reply with quote
Hi Everyone:
The air filter foam element on my H100A is holed and falling to bits.
I have bought some replacement air filter foam. However, it measures 20mm thick. It is quite thicker than the original, old element.
Will the new thick foam be ok to use?
My only thought is that with it being thicker it could mess up the running of the engine (air/ fuel mix)
Any advice would be greatly appreciated.
stickybackbob
PostPosted: 21:07 - 10 Nov 2016    Post subject: Reply with quote
It's about how much air flows through it rather than thickness. A more open 'weave' will allow more air through so you may have a weaker mixture.
How does the density of the new foam compare to the old?
Just a thought, the new foam is filter stuff as opposed to furniture foam?
trisers
PostPosted: 21:48 - 10 Nov 2016    Post subject: Reply with quote
The air filter on my H100a was crumbly too...bought some generic filter foam off ebay which wasn't as thick as that...maybe 15mm but certainly thicker than the original that was in there.
Had no running issues at all.
Don't forget to oil it (dunk it in oil then squeeze out the excess)
The last post was made 9 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 34.63 Kb
