Aprilia rs125 storage
dodgydog
PostPosted: 21:20 - 11 Nov 2016    Post subject: Aprilia rs125 storage Reply with quote
One of my customers, (for reasons only known to him) has decided to buy his son a brand new Aprilia RS125, all fine so far......but the customers son is 2 (two) years old.
The bike will be stored (displayed) on a plinth in his garage, the garage is centrally heated, he has just spent £1000 on floor covering for the garage. He also has a display of erotic art on the garage walls, I like that garage a lot.
Given that the bike will almost certainly never be run on the road in my lifetime, I'm wondering what the best method of storage would be? Drain fuel? remove battery altogether? Or would it be a better option to leave as is and maybe just warm the bike up once a week?
Thanks.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
PostPosted: 21:27 - 11 Nov 2016    Post subject: Reply with quote
For that length of time, regular warming up would probably do far more harm than good (generating a load of moisture in the exhaust, etc). Disconnect the battery. Support the bike on stands to keep the tyres off the ground (although the will be useless in 20 years time, at least they are less likely to crack up over the years).
If I were going to store the bike with no intention of starting it for decades then I would be tempted to over fill the gearbox, and fill the engine crankcases with 2 stroke oil. But need to be VERY certain to remove this oil before trying to crank it over let alone start it.
Also block the exhaust and intake off to stop air getting into the engine.
Katy
Pjay
PostPosted: 21:44 - 11 Nov 2016    Post subject: Reply with quote
I've heard it's also a good idea to block the intake and exhaust holes to minimise any moisture than can build up over the years.
c_dug
PostPosted: 22:02 - 11 Nov 2016    Post subject: Reply with quote
He does realise that in 20 years time all of the rubber will have perished and parts will be near impossible to source?
Also given the push away from petrol who knows what fuel supply/cost will be.
GSTEEL32
PostPosted: 22:16 - 11 Nov 2016    Post subject: Reply with quote
Meh
Fuel drained, battery off. Job jobbed.
Those bikes are stronger than people give them credit for. ive got a few bikes that are older than 20 years old and their as right as rain to be fair.
I've found the worse bikes I've owned are those left out subjected to the British weather.
I'd be more bothered about the fact that in 20 years time, the poor get will probably need a full licence to ride it.....
dodgydog
PostPosted: 23:08 - 11 Nov 2016    Post subject: Reply with quote
I don't think he gives a shit, he's already bought his son two cars. A 1967 Lotus Cortina, and a 1970s Escort RS2000.
Fuck knows what's next on the list. All I know is that when I retire, I'm still going to go and work there for free.
Dog
Robby
Dirty Old Man
PostPosted: 19:07 - 12 Nov 2016    Post subject: Reply with quote
If it's going to be stored to that length of time, then it should be stored properly. The usual method is to roll it into a big vacuum bag with several kilos of dessicant, seal the bag and vacuum out the air.
A bike shop I used to visit (before it was closed down and the owner put in prison for fraud) had stored a CBX1000 in a similar way. No rust, but all of the rubber parts were still perished. Cost a fortune to get it back on the road. Rebuilding 6 carbs multiple times didn't look fun.
PostPosted: 20:38 - 12 Nov 2016    Post subject: Re: Aprilia rs125 storage Reply with quote
dodgydog wrote:
buy his son
Riiiight, suuuuuuure.
If he were a chum, I'd suggest that you advise him to stop being a delusional mentalist and just go and ride his bike and drive his cars.
However, since you said "customer", probably best if you rinse this daftie for every penny you can get out of him for invisible rustproofing and anti-perish coatings.
dodgydog
PostPosted: 18:41 - 20 Nov 2016    Post subject: Re: Aprilia rs125 storage Reply with quote
Rogerborg wrote:
dodgydog wrote:
buy his son
He's really not the type of man you would want to risk that with....me and him get on just fine, but someone else tried it on with him, it didn't end very well (for the other party). My customer was quite lucky to get away with 9 months suspended, (not that he gives a shit about that either).
Anyway, latest news is he's bought two other bikes as well now, a Yamaha HS1 (1970 ish) and an Aprilia Shiver.
Both arriving this coming Friday.
PostPosted: 09:15 - 21 Nov 2016    Post subject: Reply with quote
He sounds charming, and is doubtless a totally legitimate businessman. Whistle
smallfrowne
PostPosted: 12:14 - 21 Nov 2016    Post subject: Reply with quote
Use the vacuum packed method, but go the extra mile and mix up some water+sodium chloride to create a great, cheap preservative. The vacuum bag will help to keep a good covering if you can put the mix in after, though a big jar would be preferable. Works for all sorts of things and it'll taste delish in just a few weeks, but it'll be fine for much longer. Leave the battery in for extra zing.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
stevo as b4
PostPosted: 19:51 - 21 Nov 2016    Post subject: Reply with quote
Oil everything, overfill the transmission oil but label the filler plug to say you have. On the RS125 I'd fill the crankcase with cheap engine oil and leave the piston at tdc, with bungs to block the exhaust outlet and say a rubber glove strapped over the airbox intake snorkel.
I'd throw lashings of silicone oil/spray over all the rubber and plastic part. It sounds weird but I cover the engine casings and exhaust system as well as the rubber and unpainted plasticson my KMX with spray on leather sofa oil, it's properly slippery oily shit that leaves a film on everything and takes weeks or even months to evaporate off.
The last post was made 9 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 75.76 Kb
