Yes. Its another INDICATOR Problem...
binge
Emo Kiddy
PostPosted: 01:28 - 27 Feb 2005    Post subject: Yes. Its another INDICATOR Problem... Reply with quote
Ok, ive got a speedfight, All standard indicators and bulbs and never had a problem.
Recently ive noticed instead of them going....
on.......off........on...........off..........on...........off.........on.........off........
They go...
on.off..........on.off.........on.off...........on.off............on.off...........
I hope that makes sense... Laughing
What is wrong?
<|Ben|>
Krs
PostPosted: 10:42 - 27 Feb 2005    Post subject: Reply with quote
Most probably you're wiring or the bulb's may not be plugged in right. i was alway's having problom's with them. Somethim's when you get anew part's it mess's up some of the electric's Thumbs Up
PostPosted: 12:24 - 27 Feb 2005    Post subject: Reply with quote
You are probably getting low on blinker fluid or it is getting used up somehow.
You can buy some to top up with here (or maybe just drain down the whole lot and replace it with fresh stuff): https://www.kalecoauto.com/fluids.htm
Minky_monkey
PostPosted: 12:41 - 27 Feb 2005    Post subject: Reply with quote
Laughing Laughing Laughing
TheShaggyDA
Repost Police
PostPosted: 12:49 - 27 Feb 2005    Post subject: Reply with quote
In an emergency, you can use Indian Tonic Water - NOT Soda Water, it needs the quinine to maintain the electrolytic level.
binge
Emo Kiddy
PostPosted: 21:48 - 28 Feb 2005    Post subject: Reply with quote
Confused
Is this some kind of joke. "Blinker fluid"
I really need help because its got an MOT soon and it obviously wont pass with faulty indicators...
<|Ben|>
PostPosted: 22:08 - 28 Feb 2005    Post subject: Reply with quote
Laughing It is probably either the flasher relay or corroded earth points. Clean up the earths and if it doesn't work, replace the relay (they are dead cheap)
Providing your flashers flash at between 60 and 120 flashes per minute, it will pass the MOT. There is no mention of how long they are on and off for in the testing manual, they just have to flash.
binge
Emo Kiddy
PostPosted: 22:42 - 28 Feb 2005    Post subject: Reply with quote
Ok, Ill take a look 2mora. Ive got a spair flasher relay in the garage from my first scooter which was writen off..
Ill have to take a look...
Cheers...
<|Ben|>
Visitor Q
$25 whore
PostPosted: 23:22 - 28 Feb 2005    Post subject: Reply with quote
haha diamond site... Some of it requires some knowledge of engines and it makes sense to me ( Shocked Shocked )
But this cracked me up
Radiator Insulation Bezel-
The weakest part of your car is the likely the radiator. It is a simple matter of physics when we tell you this: Energy is lost through heat. Transmissions, as they lose more and more heat, begin to cause more loss of power. However, that's only a small part - The worst part is the radiator! All sorts of heat is lost through the radiator - in essence - losing the horsepower through heat! Not anymore!! KaleCo brings you the Radiator Insulation Bezel - Simply slip over your radiator and enjoy the power! KaleCo radiator insulation is made from only the finest asbestos, and is guaranteed to trap 90% more heat!
This is a great example of one i didnt get the humour of
-Pilot Wrench-
Most cars suffer from this horrible malady - a loose nut behind the wheel!! But not anymore. Only one company had the foresight and brilliance to bring you this product - The Pilot Wrench. Quickly tighten the nut behind ANY wheel for instant improvements in responsiveness, handling, and braking! Please indicate how big of a bolt head is behind the wheel before ordering! If unsure, ask your friends. Also available in metric.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 63.84 Kb
