| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 13:46 - 17 Nov 2016 Post subject: |
Any leaking out? Have a good look under it and where it's parked. Check in the airbox.
If not, it's burning the stuff. They CAN go through it quick but a sudden increase is probably cause for concern.
If it's not actually leaking, keep an eye on it and check for smoke in your mirrors. Or get someone to follow you and see if they can see smoke.
A sudden, large increase in oil consumption could mean it's developed a problem like a cracked oil control ring or a failed valve stem oil seal.
The latter would normally cause puffs of smoke from the exhaust on the overrun or when you change gear. The former would normally be worse under power. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:50 - 17 Nov 2016 Post subject: |
The service manual should give you the exact answer.
Acceptable for me would be 1L per 5000km (the manual would say the oil consumption should not be greater than 1L per 1000km or something like that).
Now, when I had the GPz550, I also was loosing oil. Easy fix = thicker oil.
ALSO, check the oil is not leaking from the engine and check the airbox is not filling with it. If all is clean, then try thicker oil. It helped me a lot, but my GPz was aircooled, so it ran hotter and had greater gaps between all the moving parts. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| pompousporcup... |
| RhynoCZ |
 Posted: 14:16 - 17 Nov 2016 Post subject: |
| sharpe2002 wrote: | Its also difficult to be 100% certain as thats the side stand side so water etc always seems to accumulate on that side of the engine. |
One bit of wisdom, water evaporates, oil doesn't. Check the spot after you ride the bike, all the heat from the engine + ram air should dry it out if it was water.
If you've already checked the spark plugs colour.
Then you could also do a simple test: find a long steep hill, go downhill, with the engine on, in gear, the throttle shut and then, at the bottom of the hill, rev the engine with the clutch disengaged. A puff of blue smoke behind you will tell you if you're loosing oil via the valve stems.
I bet my money on worn piston rings though. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Azoth |
 Azoth Brolly Dolly
| pompousporcup... |
 Posted: 14:55 - 17 Nov 2016 Post subject: |
its only just ticked over to 21k
I've gone out and cleaned the side of the head. Its possible its leaking oil and i'l see after my commute tonight if thats the case. One thing that puzzles me is that if its losing 300+ml of oil every few hundred miles out of the rocker gasket, surely i'd see that accumulate and run down the front of the block(which isnt the case as far as i can see)
sounds like i need to do some further investigation. so generally, 1lt oil every 3.5k miles is probably alright? |
| Azoth |
 Azoth Brolly Dolly
| Nobby the Bastard |
| CaNsA |
 CaNsA Super Spammer
| RhynoCZ |
 Posted: 15:04 - 17 Nov 2016 Post subject: |
Yes, I would say 1L per 3.5k miles is alright, not ideal but alright (some modern cars burn 1L of oil quicker than that and the manufacturer says it's alright). You could try thicker oil, it helped me with the GPz.
Also, if the oil is leaking from the engine, it's actually good news. If nothing is cracked, the head gasket and valve cover seal, etc. are not expensive and are easy to change actually. Way easier than changing the piston rings and valve stem seals etc.
Have you already checked the spark plugs? The colour of them would tell you more. It would certainly determine whether your burn the oil or just leak it on the ground. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| pompousporcup... |
 Posted: 15:07 - 17 Nov 2016 Post subject: |
im fairly meticulous with maintenance but cleaning isnt something i do. Not on this bike I like having a shit kicker of a bike as a daily but im certainly not running it into the ground (oil is changed every 2.5k miles along with clearances and coolant change + more. I've just spent 200 in service and brake parts)
The mileage is genuine. Got it from an old chap who bought it new and MOT history confirms it. It had 12k when i got it
But you're right. Some things like seals wear out with age and made worse when not in constant use. I've only been doing 110 miles a day for the last 2 or 3 weeks which is why this has come to light now |
| pompousporcup... |
| pompousporcup... |
| Nobby the Bastard |
| temeluchus |
| pompousporcup... |
| Nobby the Bastard |
| temeluchus |
 Posted: 17:36 - 17 Nov 2016 Post subject: |
Valve stem oil seals can get hard and brittle with age/disuse.
Kawasakis can (in my experience) suddenly decide to drink a load of oil for no good reason too. Then stop again. So just keep an eye on the levels.
What will knacker the engine is if it runs out of oil. It can be smoking, leaking, burning and dribbling past and through every orifice and seal like the Exxon Valdeez and keep running right up to the point the valves wont close any more due to the build up of soot providing you keep it topped up. If you run out, it'll all go wrong very quickly.
If the oil pressure light comes on. Stop, go no further. On a GPZ500 it's an indicator that the oil pressure is dangerously low and your engine is lunching itself ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| base |
 base Trackday Trickster
| temeluchus |
 Posted: 19:49 - 17 Nov 2016 Post subject: |
Very much depends on the bike and engine. The GPZ500s we have had have not been bad on oil consumption.
Some bikes have a really bad reputation. FZR1000 for one (late FZ750 as well - early ones seemed to be fine for oil consumption).
VW have said that 1L per 500 miles was within tolerance for new cars a few years ago.
Have you changed the oil recently? Used a thinner oil than standard, or one that is the same spec but at the thinner end of the range for that spec.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| kramdra |
 kramdra World Chat Champion
| Nobby the Bastard |
The last post was made 9 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
