| owl10 |
 owl10 Could Be A Chat Bot
 Posted: 12:58 - 19 Nov 2016 Post subject: Bath Seal failed - now what? |
Good morning BCF.
Looking for advice-
Late last night i found the landing carpet was a bit damp. Pulling it up, the floorboard (Chipboard type stuff) was soaked.
No pipes nearby, but the otherside of the wall is the bathroom.
Unfortunately we've a tiled bath panel which i havent yet moved, but decided to break one of the smaller tiles and use a hole saw.
Under the bath reveals this:
https://i.imgur.com/sBCgwrZ.jpg
Dammit. (Not supposed to be black mold everywhere...).
Culprit looks like a leaky bath seal.
On the back wall is the bedroom, on the narrow end of the bath wall is the landing, so im guessing the bedroom floorboards will also be wet (not taken up carpet yet)
So.... Usual drill, remove panel, get some heat under there, replace seal etc etc.
But due to the length of time its obviously been leaking unchecked im a bit concerned about the following and would appreciate some advice:
- Problems
Those walls are plasterboard. Unlike normal internal walls, they are simply 3 bit of plasterboard bolted together with no cavity. As yet, its not gone through to the other side.
Bathroom tiles above bath seal are 22kg per square meter. and large tiles..directly on the plasterboard. Will the leak have likely damaged the wall structural integrity? How can i check ?
Same question about floorboards and more importantly, the joists?
Or, even better, which kind of trade is best placed to come and check? Plumber (its not pipe related, I already know the cause)?
Thanks! ____________________ DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
| doggone |
 doggone World Chat Champion
| Nb |
 Nb World Chat Champion
 Posted: 15:23 - 19 Nov 2016 Post subject: |
Had a similar issue in my house, and being as i am tight bastard i just fixed the leak and left a panel off with a dehumidifier next to it for a week. Seems fine now.  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
| Ribenapigeon |
 Ribenapigeon Super Spammer
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 18:14 - 21 Nov 2016 Post subject: |
I have the same issue, tiler fitted new bath in our bathroom then used adhesive to attach it to the tiled wall
He didn't fit the bath properly, so when you fill the bath it sags which has caused the adhesive to pull the tiles off the wall, which in turn has allowed water to run down the side of the bath onto the floor underneath
I really need to rip it all out to assess the damage but cba |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 14:09 - 22 Nov 2016 Post subject: |
bath panel off, de-humidifier (You can get one that's salt / silica based so silent and no power required that should fit under the edge of the bath)
If you don't want to do it yourself then it's a bathroom fitter that you need to do the work (we had ours done not long ago)
The seal he put on is about twice as thick (but nice and neat) than the one I did.
If you do it yourself, fill the bath with water before sealing it, leave water in overnight while the sealant goes off and then drain.
this way the sealant is compressed when not in use and returns to it's natural state when the bath is run. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| MCN |
 MCN Super Spammer
| chris-red |
The last post was made 9 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
