Oil change problem
6r4h4m
PostPosted: 14:54 - 19 Nov 2016    Post subject: Oil change problem Reply with quote
Drain plug stiffer than a stranglewanked out politician.
Eventually unscrewed the bastard. Small chunk of metal came off with it: about 4mm worth. The plug head had got stuck fast to the base of the bike, and this small segment of its 'seat' has come away and partly disintegrated. So now I won't have a seal when I screw the plug back in.
(No idea what's happened to the washer, but I guess that's academic at this point).
Any suggestions for a fix? Even a short term one? Is there a product I could use to rebuild the disintegrated section, that's not going to be dissolved by the oil?
Thanks!
PostPosted: 15:34 - 19 Nov 2016    Post subject: Reply with quote
Buy a new sump plug from your dealer. Or get a magnetic one off of eBay depending on which is cheaper. It's just a generic bolt to be fair, so not too tricky to pick another one up. I wouldn't dick around trying to glue it back together.
The crush washer is either mashed onto the sump plug or stuck to the bottom of the sump (or the monkey that last changed the oil didn't use one).
Nobby the Bastard
Harley Gaydar
PostPosted: 15:52 - 19 Nov 2016    Post subject: Reply with quote
Are you saying that a chunk has come away from the engine casing?
Triumph Sprint ST 1050
6r4h4m
PostPosted: 15:56 - 19 Nov 2016    Post subject: Reply with quote
Yup. The plug is fine.
PostPosted: 15:58 - 19 Nov 2016    Post subject: Reply with quote
That sucks. New sump pan for you. Could probably weld it to be fair, but it's still a big job.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:03 - 19 Nov 2016    Post subject: Reply with quote
What bike?
6r4h4m
PostPosted: 16:19 - 19 Nov 2016    Post subject: Reply with quote
What bike?
Kymco Pulsar 125. … I'm just cracking through some test rides for next bike. I wasn't planning on buying until New Year but if the bike is self destructing I'll trade up ASAP! Would need a fix to keep it going for another couple of weeks though.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:24 - 19 Nov 2016    Post subject: Reply with quote
if it's a CG125 copy your fucked. They don't have a separate sump. You can try building up the broken bit with chemical metal (oruse it to glue the broken bit back on) but I wouldn't hold out many hopes.
janner_10
PostPosted: 21:57 - 19 Nov 2016    Post subject: Reply with quote
Replacement engine on eBay £100
https://www.ebay.co.uk/itm/kymco-pulsar-125-engine-/232133366776?hash=item360c3a13f8:g:7wwAAOSw8w1X8-zR
Easiest solution for less time.
After that flog it and get something Jap
Azoth
PostPosted: 22:10 - 19 Nov 2016    Post subject: Reply with quote
I would try drilling out the sump plug hole. Making it bigger but round. Then self-tapping a bolt into there, along with a copper crush washer and an ordinary rubber washer, for use as the new sump plug.
Not saying it would work. Just saying I would try it.
Safety in numbers
RhynoCZ
PostPosted: 10:52 - 20 Nov 2016    Post subject: Reply with quote
I also advise against the magnetic type of sump plug. Although there are many happy owners, there are also quite a lot of cases the ebay plug causing more trouble than benefit.
Sump plugs are not expensive, and it's not like you change them ever year either. Get a original one. Copper crush washers are like 30p per piece.
6r4h4m
PostPosted: 14:09 - 20 Nov 2016    Post subject: Reply with quote
try building up the broken bit with chemical metal … but I wouldn't hold out many hopes.
Looking at it again today, I think this has a fair chance of working. Not if I do it though, I'm really crap at working with fillers and the like. I'll have a word with a local mechanic and see if they'll have a go. I'll give it a week and then go to plan B (cheers Janner)
Dave....
PostPosted: 14:34 - 20 Nov 2016    Post subject: Reply with quote
Use a helicoil insert.You will need to buy kit and correct length of insert.Another one I have used before is https://www.threadrepairkits.co.uk/EZLOK%20inserts.htm which you drill then tap oversize with standard tap, unlike Helicoil which requires specific tap.
The latter is better if hole is way oversized for Helicoil.
Honda Africa Twin
Nobby the Bastard
Harley Gaydar
PostPosted: 14:48 - 20 Nov 2016    Post subject: Reply with quote
A piece of the casing has broken off. a helicoil or similar will nor replace tha mating face for the copper crush-washer.
Dave....
PostPosted: 14:51 - 20 Nov 2016    Post subject: Reply with quote
Updated my post with alternative.
Honda Africa Twin
Nobby the Bastard
Harley Gaydar
PostPosted: 15:01 - 20 Nov 2016    Post subject: Reply with quote
how is this supposed to replace the mating surface?
Dave....
PostPosted: 15:03 - 20 Nov 2016    Post subject: Reply with quote
Another alternative, what size is original thread?
https://www.ebay.co.uk/itm/BGS-Tools-Brake-Thread-Repair-Threaded-Inserts-M12x1-25-12mm-long-for-BGS-8651/291756434666?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38661%26meid%3D039c4df711454225935f4aae8e9125fe%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D381623939461
or reface casing with a counterbore drill?
Honda Africa Twin
Nobby the Bastard
Harley Gaydar
PostPosted: 15:16 - 20 Nov 2016    Post subject: Reply with quote
I'm not convinced that a thread insert is the solution. You're just replacing 1 thread that the oil can leak out of with two threads that the oil can leak out of. Trying to get a good oil-tight seal between the casing and the insert will be down to luck and you'll only get one attempt.
Azoth
PostPosted: 15:31 - 20 Nov 2016    Post subject: Reply with quote
It will work, but it's going to be tricky if the surfaces are aluminium and you're using an ordinary chemical weld like JB Weld. You need to remove every trace of grease and dirt from the surfaces you want to apply it to, and work very fast, as you want to minimise the amount of oxide layer the chemical weld is touching. You can make this work, but it will take a few attempts. JB Weld doesn't like aluminium at all. The next time you drain your oil, the weld will come off and you'll have to go through this whole process again.
Safety in numbers
Beehive Bedlam This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
PostPosted: 17:27 - 20 Nov 2016    Post subject: Reply with quote
This thread is useless without pictures.
The advice contained within this thread is pure guesswork without pictures.
Several possible solutions present themselves to me off the top of my head but I couldn't say if they were feasable without seeing exactly what the damage is.
ajag
PostPosted: 19:14 - 20 Nov 2016    Post subject: Reply with quote
From the post it seems like it is not the thread but the matting that has come off, but pictures are required. if it is the matting, wouldn't one of those washers with the rubber in the middle (dowty/bonded washers) help?
Probably don't have enough rubber to make up for the missing piece of metal.
qarka
PostPosted: 19:36 - 20 Nov 2016    Post subject: Reply with quote
I fixed a bit of crankcase on my chinky 125 with chemical metal and it lasted the life of the bike (another 4 years). However it wasn't in an area that would be disturbed by routine maintenance so I wouldn't be confident in your case.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:52 - 20 Nov 2016    Post subject: Reply with quote
I've had tyres that last longer than that...
The last post was made 9 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.75 - MySQL Queries: 13 - Page Size: 128.26 Kb
