Headlight missaligned
Shirodes
PostPosted: 16:19 - 19 Nov 2016    Post subject: Headlight missaligned Reply with quote
Hi everyone
i have a keeway superlight 125 bought it from new had 0 problems with it so far. I went to set off onit one morning a noticed the light beam was well above the right level pointing pretty much straight up. the only problem is i see no adjuster for the light it self just the one for adjusting headlamp up and down which hasn't moved, inside doesn't appear to have moved either or come loose its just randomly one day point up. the full beam is fine as its a separate bulb thats just slap in middle of the lamp.
if anyone has any experience with the keeway and could help id be very grateful ^^
Nobby the Bastard
Harley Gaydar
PostPosted: 16:55 - 19 Nov 2016    Post subject: Reply with quote
Has the bulb come loose inside the light?
Triumph Sprint ST 1050
Shirodes
PostPosted: 18:15 - 19 Nov 2016    Post subject: Reply with quote
doesn't appear to have come loose at all
but tomorrow im going to take the bulb out as iv injured my foot yesterday so been resting it today so ill see for sure then but it doesn't appear to move or anything.
mudcow007
PostPosted: 21:02 - 19 Nov 2016    Post subject: Reply with quote
could the physical headlight have moved up?
I know on mine it has rattles loose enough to move once - even using nylocks Shocked
Shirodes
PostPosted: 21:16 - 19 Nov 2016    Post subject: Reply with quote
from what i have seen it doesn't appear to have moved but ill have a look tomorrow and see if it has but from what i have seen its on full lock so it can only technically move downwards.
ill reply tomorrow with pictures if i haven't fixed it.
jaffa90
PostPosted: 01:25 - 20 Nov 2016    Post subject: Reply with quote
""""""I went to set off onit one morning a noticed the light beam was well above the right level pointing pretty much straight up.""""""""""
Sounds like a right hand side of the road ride model.
Shirodes
PostPosted: 14:01 - 22 Nov 2016    Post subject: Reply with quote
Hi guys
sorry about the late reply but i took the bulb out to check that over and it appears it has blown but full beam is still intact the problem is i carn't see what type of bulb it is since the writing has nearly come off i can figure the 12v out but no idea from there haha
also it has another smaller bulb at the bottom of the light so i can ride it before sun goes down as other people can see me still due to it but after dark i carnt see road
PostPosted: 14:04 - 22 Nov 2016    Post subject: Reply with quote
Pictures are worth a thousand words. Photograph the bulb and someone on here will be able to tell you exactly what to get.
The last post was made 9 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 53.26 Kb
