| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 20:32 - 18 Nov 2016 Post subject: Mild tuning discussion |
Ellopeeps.
I've asked on Enfield Farcebook groups where there are some pretty good tuning wizards, but the conversation keeps straying away from the actual question, and although I paraphrase it seems to be a lost cause. So, bearing in mind this is more of a theoretical exercise and I'm just trying to get an actual discussion going (rather than have people post pics of their bikes saying "lolz, i r fast", "buy a Triumph", or "don't bother, the bike is shit"), here goes
Starting with a standard Indian Enfield 350 (with carb, valves, timing etc all dialled in ok), what mods would give the single most performance increase at each stage?
For example (and these figures are purely for comparison rather than actual expectations) :-
Conical free flow air filter, £20, 5% performance increase
Gas flow head, £150, 15% increase
Free flow exhaust, £100, 10% increase
Amal Mk1 conversion, £150, 10% increase
So, working on these examples, it would make sense to do a filter and exhaust for £120, rather than an Amal conversion for £150.
There's a lot more that can be done :-
Higher compression piston
Larger/lighter valves
Lighter springs/rockers/pushrods
Retard inlet cam
Hotter cams
Lighter flywheel
Big bore kit
Sell it and buy a '98 R1
Also, in reality you wouldn't gas flow the head until you've got at least a freer flowing filter and exhaust on, so a lot would go hand in hand with each other. Most owners are happy with an Amal conversion and exhaust and leave it at that, and there's always diminishing returns the more you do when chasing those last extra RPMs or BHPs.
My own starting order would look like (and assume appropriate rejet and reliability changes thrown in like improved oil pump, alloy barrel, oil cooler when applicable) :-
1. Air filter
2. Exhaust
3. Carb upgrade
4. Gas flow head
5. Larger/lighter valves
6. Higher compression piston
with a possible swap round of...
1. Exhaust
2. Air filter
3. Gas flow head
4. Carb upgrade
5. Higher compression piston
6. Larger/lighter valves
So, for a progressive bang for buck, Pareto Principle stylee approach, what order mods would you make, and why? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| The Shaggy D.A. |
| stevo as b4 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:15 - 18 Nov 2016 Post subject: |
in my experience in both push rod and over head cam engines.
cams is where its at.
a cam grind can be done for pretty cheap,
and can get in the 20-30% range of power increase,
especially in mild engines.
even with a decent dohc motor there is still plenty to be had from cams.
id even say you'll get more from a decent grind than a big bore ____________________ the humans are dead
I kick arse for the lord
| The Shaggy D.A. |
 Posted: 21:32 - 18 Nov 2016 Post subject: |
I have nearly "All of the above." on mine and they make very little discernable difference.
I have:
Gas flowed head. (original ate the valve seat)
Higher compression piston.
Alloy barrel (broke the iron one).
Amal Carb.
Noisy pipe.
Pod filter.
Balanced rockers.
Now, all that lot may well have given me a 10-20% increase in power. HOWEVER increase 14bhp by 20% and you have not quite 17bhp. Hard to tell.
Of the above, one thing that really did make a noticeable difference was the balanced rockers. The engine spooled up faster and revved higher with those fitted. If you compare them to the originals, you'll see why.
So I'd say lightening the valvegear is a good starting point. And a louder exhaust because at least it sounds better.
In fairness, the mikcarb was better for cold starting. The thing that made a noticeable difference to that was fitting japanese jets and needle (available as a kit).
Ditching the airbox jiggery-pokery gives you back your toolbox and junks a whole load of sub-standard, perishing Indian rubber parts. Makes it far easier to get at and work on the carb/engine.
So. If it were me with a "virgin" 350 bullet. I'd fit balanced rockers, consider alloy pushrods (I don't actually have these). Loud pipe, conical filter, setup carb to suit (with a different slide as I recall) and Japanese jets and needle.
I'd push the ignition timing as far advanced as I dare too but push it too far and they are latchy as fuck to start. Set it at fully advanced (hitchcocks sell a washer thingy to lock it fully advanced).
Consider an extended reach plug to bump the compression slightly.
The Samrat rockers either need the o-rings junking and a hole drilling to convert them to volume fed or a pressure releif valve fitting if you don't want to risk going over-pressure and stripping the oil pump gear.
TL;DR: Balanced rockers, ligher push-rods, pipe, filter, setup carb, fit japanese brasswork. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| The Shaggy D.A. |
 Posted: 21:40 - 18 Nov 2016 Post subject: |
I've finally had a reply from a Bullet tuner, stating that there's no point in upgrading the carb until the porting work is done. Makes sense. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| The Shaggy D.A. |
| stevo as b4 |
 Posted: 22:53 - 18 Nov 2016 Post subject: |
It's an interesting thread though anyhow!
Now can we get some expert model specific specialists to puke up all the information, on tuning gains, stage order, percentages and costs for my bikes.
Hmmmz, is right I would say with cam timing, but I doubt all modern dohc engines show such good gains as old ohv plodders, as I'd expect combustion chamber design and shape and valve angles to be more important in modern low emissions and efficient engines.
But an Enfield is not really much more advanced than something like a BL A-series, so any port work, valve de-shrouding and more valve lift and timing will generally have good effects and gains.
I know bike engines are different but still with cam in block engines, people are often reluctant to strip a good running engine to put in a big lumpier cam, due to the work and time required to do so. That's why head, valve and breathing gains are often the first port of call instead. |
| sickpup |
 sickpup Old Timer
| The Shaggy D.A. |
 Posted: 09:17 - 19 Nov 2016 Post subject: |
That's the "why" part of the exercise - what would you mod to give you which results? My personal yardstick would be for comfortable 60mph cruising, so wouldn't necessarily have a higher revving engine as the target, but more have an increase over the existing rev range. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Copycat73 |
 Copycat73 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:43 - 19 Nov 2016 Post subject: |
I am reading this thread with interest but have nothing much to contribute from my posh 500 perspective.
The only thing I'd note is that going back to the original airbox rather than a pod filter seems to help with starting and response off of idle. That's with an Amal and a proper exhaust rather than the hilariously constricted stock exhaust. ____________________ Biking is 1/20th as dangerous as horse riding.
| G |
 G The Voice of Reason
| The Shaggy D.A. |
| Copycat73 |
| hmmmnz |
| stevo as b4 |
 Posted: 18:25 - 19 Nov 2016 Post subject: |
Oh I agree completely, and on a basic or inefficient engine design, there's alot of gain to be had for a small amount of work.
The old BL A-series engine is just one example,where by on the older 850cc units you could add 50% more power by improving the head flow, bumping up the compression and installing better inlet and exhaust manifolding, and that's still with a small single SU carb.
On much later 90's engines, probably more car than bike, you could generally get a bit more power with a cam swap, but it depends on the engine and if it was designed to breath well as std. Some 16v modern engines have small valves, narrow ports, lots of swirl etc. A cam swap doesn't see as good a gains as an engine like a Ford/Mazda Duratec engine that has huge excellent flowing CNC ported heads as std, and is as such very responsive to different cams. |
| sickpup |
 sickpup Old Timer
| lihp |
 lihp World Chat Champion
 Posted: 13:23 - 20 Nov 2016 Post subject: |
Couple of things worth noting.
You can't get valve stem oil seals for the hitchcocks "tuned" head which has the lighter, bigger valves. Closest I've found are off a mini (a proper one, not a BMW) which fit but don't stay on because there's no groove on the guides.
Take care with oil pumps. I fitted high flow pumps thinking I was doing the right thing. Turns out all I was doing was filling the rocker box with oil. It runs out along the pushrod tubes and if you pump too much up there, it can't get away quickly enough. Then some (or lots) of it exits down the valve guides.
In fairness, the best thing you could do to improve your touring speed would be to alter the gearing so it'll hold 50mph in 3rd (it'll do 50 in 3rd but you'd be floggin it). Simply altering the final gearing isn't the way to do it, there is an enormous gap between 3rd and 4th. If you simply geared it higher, it wouldn't ba able to pull 4th gear properly and you'd land up slower overall. As they are, if you hit a hill and drop to 3rd and you're stuck there doing 45 until you come off the gradient.
Solution is either a 5 speed box or close ratio gear cluster. Both are expensive. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lingeringstin... |
 lingeringstin... Spanner Monkey
The last post was made 9 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
