Permanently bike-mounted videocams?
Freddyfruitba...
PostPosted: 14:44 - 21 Nov 2016    Post subject: Permanently bike-mounted videocams? Reply with quote
I'd like to get myself a mini video camera specifically for the purpose of collecting evidence in a car versus bike situation. I really don't want a helmet cam as I really don't need yet more 'stuff' to prepare every time I go out for a ride - have got enough of that already. Also, I don't want to look like a Tellytubby.
Almost all the bike cameras I can find seem to be aimed at riders wanting to record their adventures for posterity in HD, whereas for car drivers there are plenty of (eg) cheapo rear-view mirror mounted cameras which just loop for 2 or 3 minutes, and capture everything leading up to an 'event' on a memory stick. I can't find anything like that for a bike, other than some really expensive kit intended for racetracks.
What I'm after would need to be small, cheap and reasonably surreptitious, so as not to attract the attention of scrotes when I'm parked up.
Does anything like this exist, or am I asking for the moon here?
bigdom86
PostPosted: 15:17 - 21 Nov 2016    Post subject: re Reply with quote
was gona ask the same question as you after a SMIDSY this morning but I would think a helmet one would make more sense as you will look to where the accident is going to happen like a t-bone, whereas a bike mounted one might not capture the event properly?
Hawkeye1250FA
PostPosted: 15:22 - 21 Nov 2016    Post subject: Reply with quote
In my experience anything that falls into the category of "cheapo" (including the car ones) don't have enough resolution to capture car number plates properly except on perfectly clear days at less than 50mph.
If a car side swipes you are 60 and disappears, you can forget about getting any incriminating video of them - other than "It was a white car".
Remember the car ones don't need to be waterproof / weatherproof either.
I tried all sorts and ended up just biting the bullet and buying a Sena 10c.
- Its perfect quality (if a bit pricey)
- Records in loops the same as a car one
- Doubles as B/T headset for inter-bike chatting
- Small and light enough to not notice it on the side of the helmet
I'm sure with a bit of research you would be able to find something that would be waterproof and small enough to hide on the front / back of the bike... But Id hazard a guess that the footage quality would be poor.
Just my 2 cents.
Hawkeye1250FA
PostPosted: 15:24 - 21 Nov 2016    Post subject: Re: re Reply with quote
Agreed, the situation where you hit something directly in front of you (where the camera is pointing) would be very rare.
noobRider
PostPosted: 16:08 - 21 Nov 2016    Post subject: Reply with quote
I've had an Innovv C3 mounted to my bike just below a mirror for about a year and a half. The camera is small and waterproof and the recorder sits under the seat and loop records onto a memory stick in 1080p. The video quality was pretty good but I think the lens has taken a battering and there's a lot of little square pinprick marks on the playback now that I think are salt / stone chips or something. Also, when I had a low speed off it corrupted the looped segment that was recording at the time, so was useless.
The company does a forward and back looking setup now. If you mount a camera I think you should put it higher up than I did and maybe behind a screen.
Some footage
Going up Stelvio
I think there are other companies making similar things.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
owl
PostPosted: 16:10 - 21 Nov 2016    Post subject: Reply with quote
drift stealth 2, about £80-90
you could mount it on the bike but it would probably get stolen
mount it on your helmet and if something does happen, guarantee you'll be thankful you bothered with the extra 30 seconds it takes to click it in and hit record
Observation is the greatest source of wisdom.
kerr
PostPosted: 16:11 - 21 Nov 2016    Post subject: Reply with quote
Look for techmoan on youtube for cheapy but goody action cams.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
SkyBadger
PostPosted: 17:44 - 21 Nov 2016    Post subject: Reply with quote
I have been thinking about this as well. I found a page where a guy permanently mounts front and rear cameras so he doesn't have to touch them unless he has an incident.
https://www.nc700.co.uk/index.php?/topic/9931-dashcam-review-innovv-k1-2-channel-motorcycle-dvr/
Also, say you had a front mounted camera and you got T-boned - surely the footage of a clear road in front would be enough to prove fault?
TheSmiler
PostPosted: 18:22 - 21 Nov 2016    Post subject: Reply with quote
Where are you thinking of putting it, that is one of your main downfalls right there. This is my bike after the bike car situation. I doubt if it was on the bike at the front it wouldn't have survived in one piece.
On the helmet would be wiser.
https://i.imgur.com/4gbl04U.jpg
PostPosted: 18:29 - 21 Nov 2016    Post subject: Reply with quote
TheSmiler wrote:
I doubt if it was at the bike at the front it wouldn't have survived in one piece.
You don't need the camera to survive, providing you can get the files from the memory card.
Head mounted for go pro style cameras can put extra strain on neck muscles and has the potential to cause an injury if it catches on something, preventing your head rolling, while your body continues to roll.
bugeye_bob
PostPosted: 18:41 - 21 Nov 2016    Post subject: Reply with quote
something like this will record ,if you can find room under the seat or something, it will run off 12v.
https://www.ebay.co.uk/itm/Black-New-PAL-SD-DVR-Digital-Video-Recorder-Surveillance-Audio-100-240V-12V-/262225237984?hash=item3d0dd797e0:g:lQgAAOSwa-dWi8Hd
and then use a numberplate/reverse camera, it will be IP rated for external use,
then add a decent memory card to the DVR.
SkyBadger
Also I think those innov ones save to the unit which is under the seat not in the actual camera units
TheSmiler
PostPosted: 18:45 - 21 Nov 2016    Post subject: Reply with quote
True regarding the extra possible injury I was just wondering if the cheap cams can live up to the punishment and even more if the memory card would survive. That's if you can find the camera in the aftermath could have flown anywhere.
SkyBadger
PostPosted: 18:47 - 21 Nov 2016    Post subject: Reply with quote
Where is the cheapest place to get these from?
£95 seems cheapest on Ebay.
This seems best option for me for now.
Thanks
ThatDippyTwat
PostPosted: 19:02 - 21 Nov 2016    Post subject: Reply with quote
SJCam 4000 (Not the clones of that, they're crap). Crystal clear, numberplates no issue. $79. You get loads of mounting options in the box and accessories, being a Go-Pro style camera, are easily available. You can get a Charging case for it (USB and Hardwire options), and it powers on when you apply power to the case.
https://sjcamhd.com/product/sjcam-sj4000-action-camera/
Mawsley
PostPosted: 19:56 - 21 Nov 2016    Post subject: Reply with quote
TheSmiler wrote:
Where are you thinking of putting it, that is one of your main downfalls right there. This is my bike after the bike car situation. I doubt if it was at the bike at the front it wouldn't have survived in one piece.
Going by the picture of your lid, if you'd had a camera it'd been screwed any which way. Laughing
PostPosted: 19:59 - 21 Nov 2016    Post subject: Re: re Reply with quote
https://i.imgur.com/m402heB.jpg
Hawkeye1250FA
PostPosted: 20:16 - 21 Nov 2016    Post subject: Reply with quote
Is that the newest rainpal?
Hawkeye1250FA
PostPosted: 20:50 - 21 Nov 2016    Post subject: Reply with quote
And it's not as big as a go pro. Smile
owl
PostPosted: 12:21 - 22 Nov 2016    Post subject: Reply with quote
Thanks
curry's is doing them for 89 at the moment
or if you want to order direct from drift voucher code VLOGHIM will give you 10% off
or wait till friday, I believe there's some kind of sale happening Laughing
SkyBadger
PostPosted: 12:42 - 22 Nov 2016    Post subject: Reply with quote
Cheers yeah I can hold out till Friday and see if any are on a further discount.
Amber Phoenix
PostPosted: 18:27 - 22 Nov 2016    Post subject: Reply with quote
Got mine from Currys/PCWorld last Autumn. Camera is good, but have had a couple of issues. First one had led cover loose in box, so it'd nicely leak water in. Replacement lasted 9 months before it refused to charge one day (and yes, I know it must be charged with a decent 2A USB charger). Curry's did swap in both instances but there was a 2-3 weeks turnaround time both times. Drift Innovations weren't interested in helping much beyond 'have you tried latest firmware?' So OP, do consider that epic Curry customer service into your purchase decision, even if they are the cheapest.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
owl
PostPosted: 18:35 - 22 Nov 2016    Post subject: Reply with quote
out of interest was it the stealth or stealth2?
2-3 weeks, fuck that noise, I would have kicked off or just got my money back
only had the ghost for about 6 months, but no issues so far
evilzed
PostPosted: 18:39 - 22 Nov 2016    Post subject: Reply with quote
This happened to my second Drift exactly 9 months after too it would partially charge, my first cam I bought about a year before still works fine....Strange
The last post was made 9 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 128.73 Kb
