Thunderace Electric
brainreyd
PostPosted: 16:09 - 24 Nov 2016    Post subject: Thunderace Electric Reply with quote
Hello
I have a Thunderace and when I plug in an indicator (either of the 4) it just lights up continuously.
I have swapped the relay for the working one in my ZX9R and still the same. Is there a short there somewhere and I think its getting voltage all the time, this is even when ignition is turned off.
Any ideas where to look for a problem or any know issues?
Thanks
jaffa90
PostPosted: 16:18 - 24 Nov 2016    Post subject: Reply with quote
What do you mean "plug in an indicator either of the 4?
Usually it`s switching left or right in pairs.
sickpup
Old Timer
PostPosted: 18:01 - 24 Nov 2016    Post subject: Reply with quote
Is an alarm fitted?
brainreyd
PostPosted: 18:04 - 24 Nov 2016    Post subject: Reply with quote
When I connect the 2 wires of an indicator and its the same for all 4 indicators.
brainreyd
PostPosted: 18:05 - 24 Nov 2016    Post subject: Reply with quote
sickpup wrote:
Is an alarm fitted?
I not 100% sure, I got fob with it and box on the side but starts anyway without problems.
jaffa90
PostPosted: 23:09 - 24 Nov 2016    Post subject: Reply with quote
Indicators work on / off in pairs with the correct bulb wattage,
the relay/flasher switch should only have a live feed when switched/ignition on, unless an alarm has been fitted and is faulty.
SBDJ
PostPosted: 00:19 - 25 Nov 2016    Post subject: Reply with quote
Are they LED indicators? If so perhaps you need a flasher relay to handle the low load of LEDs (or add loading resistors).
1998 ZX9R C1
1998 YZF600R Thundercat
brainreyd
PostPosted: 15:36 - 25 Nov 2016    Post subject: Reply with quote
Standard Indicators
brainreyd
PostPosted: 15:41 - 25 Nov 2016    Post subject: Reply with quote
I only have to plug in one indicator and it comes on and that's with no key in ignition.
Alarm looks like its wired into loom, box has spyball written on it. Is this going to be a nightmare to find the issue?
brainreyd
PostPosted: 18:31 - 25 Nov 2016    Post subject: Reply with quote
I seems to have got some working, I have had to butcher the spyball a bit to get into the plug (some tiny torx bit needed) and unplugged the box.
Will replace the tank tomorrow and see if it actually starts. Got my fingers crossed.
brainreyd
PostPosted: 15:12 - 26 Nov 2016    Post subject: Reply with quote
It now does not start. If I plug in the box it will start but indicators are on. Once running, I can disconnect the box, its still idles and indicators work fine. Once I switch off though, it wont start unless you plug box back in.
Starter motor doesn't even spin without the box connected.
The last post was made 9 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 65.52 Kb
