The need to tinker
loughy
PostPosted: 12:17 - 02 Dec 2016    Post subject: The need to tinker Reply with quote
Now i've moved into the world of big boy bikes, I want to further my knowledge to be able to complete my own services, fault detections, mods etc.
My knowledge at the minute is fairly basic but I think rather than tinkering with my 625 duke, I think its better to start with a smaller bike as a project.
Just looking for advice on what/where to start and is there a particular type/brand of bike which is a good started project? to buy a cheap old mess and go from there bit by bit, or to start from scratch with a frame (is that too much of a project?
Sable
PostPosted: 13:02 - 02 Dec 2016    Post subject: Reply with quote
Buy a cheap CG, older the better. Use it as a winter hack and keep it running regardless of what breaks. Do all repairs yourself. Cheaper than building a bike.
loughy
PostPosted: 13:14 - 02 Dec 2016    Post subject: Reply with quote
CG?
Teflon-Mike
tl;dr
PostPosted: 14:21 - 02 Dec 2016    Post subject: Reply with quote
A project can be a great way to learn mechanics; to learn how to sort out all the stuff that wears out or breaks though, you would want to pick a bike that is worn out and broken! Ie an old knacker.
A crash repairable, will only teach you how to unbend bits of bike; a 'custom' project how to change the shape.
So you want an old knacker, that's not been bent, nor customized, that you can make look just like it does on the cover of the Haynes manual, following the instructions IN the Haynes manual.
Taking it down to the bare bones, bit by bit, doing all the jobs like overhauling the brake calipers, replacing wheel bearings, overhauling the forks and suspension...
You start with a clapped out old knacker.... and when you have done, you end up with a hopefully slightly cleaner old knacker, that 'looks' almost no better than it did when you started, but contains about 3x it's market value in new parts you cant see.... but, if you followed the instructions right, should start and ride almost like new... but it wont look like it, and it will probably have cost as much as buying new; certainly 'more' than you could buy a 'better' running and riding example of the model for 2nd hand...
WHICH is where the problems start; clapped out old knackers become clapped out old knackers because no one thinks it 'worth' fixing them up... cheaper & easier to just buy something less knackered.
So... doing a project, you are unlikely to turn an old junker into a concourse show bike, that will be worth more than you spend on it. Do NOT do a project for profit. You almost certainly wont make one, especially a first project.
Next up, usual pitfalls; loath to spend money, people don't do the jobs where money needs to get spent; so wheels don't get new bearings, forks don't get new seals, suspension doesn't get new bushes... which means you don't learn how to replace wheel bearings, suspension bushes or fork seals! That rather defeats your original 'object' in the project to learn all these jobs, AND finished product isn't any less knackered than when you started!
Then, after starting to do a bit of work, and being disappointed that it doesn't LOOK any different when done to when you started, the aesthetics start to get more attention than the mechanics, and people will get distracted, polishing and painting and making it all look very pretty... and may even spend a bit of money on that, so they have a prettily painted old junker to look at... but still not learn any real mechanics or make the bike much or any less clunky!
And where 'problems' start to arise; often where more expensive parts are required, the botches start to creep in, and excuses that its being 'ratted' or 'bobbered' start to get offered.... so the end result is a prettily painted bit of butchered scrap!
WHICH eventually will get flogged off as 'Unfinished Project" when its realized its never going to be what was originally hoped, that its costing too much money, or that whats been done, is just so wrong, the bike will never get an MOT.... or it gets left in the back of a shed until its rust on the floor!
THESE warnings observed; IF you really want a project.. think long and hard about how much you want one; how much you really want to learn, and how much you can afford to throw away whilst you are about it.
Then, picking a scruffy old bike as your base; something cheap and common, say an ER5, that has been ridden into the ground over a few winters commuting, could give you a lot of learning, but cost and effort isn't going to give you a bike worth much if any more than you had to start with. Should ride wonderfully... BUT never a particularly inspiring bike, probably not one you will get the value you have put in from use or enjoyment... if you percevere to the bitter end.
On which basis, you may be better off picking something you have more use for, that you might get value from when done; a sunny day show bike or scratcher. And something like an old Triumph Bonaville, or a Ducati, may be little or no more daunting to tackle, probably cost little or no more to see 'done', and likely be worth more of what you have spent on it, as well as be something you can get the value back out of from riding.... For all you will have to spend more to buy one to start with.
BUT, end of the day, a project is whatever you want it to be.... there's no prescription for one, but the one YOU write for it.
But be warned; they nearly always cost far more time, money and effort than you expect; they nearly NEVER are truly 'worth it' at the end, and I do about one a year... its fun.. BUT... ignoring the perverse ecconomics, it really is hard to justify it all when it's done.. let alone if it never gets there.
So start at the back end; what would make a good project bike to choose is NOT one that tries to kid you it will be 'easy' to cut your teeth on; its not one that kids you it will be 'cheap' either to buy or to do; But look at the bikes you would LIKE to own when done. Ones that will give you inspiration to keep going; ones that will encourage you to keep heart and spend the money when and where needed and not cut corners or both or butcher it.
IF you really are convinced that you want to tackle it in the first place... because believe me; they take an awful lot more time and effort than you ever expect, they ALWAYS cost far more than you budget; and the mess and the hassle is always enormous and far beyond expectation, and NONE of it will ever be worth it unless its seen through to the finish, which is usually years up the one, not days or weeks or months!
So you tell US what would be a suitable project bike to go for......
Or count your pennies and ponder how many services you could pay a pro mechanic to do for you for likely cost of a project AND all the tools and crap you will buy along the way.....
Spannering is, no doubt, that added dimension to biking, and great fun... BUT, you have to be at least slightly stupid to do it just for fun!
loughy
PostPosted: 14:41 - 02 Dec 2016    Post subject: Reply with quote
That was literally exactly the kind of post that I was aftering, informative and to the point.
I'm already fully aware that i'll go way over budget on cost and time but I fully accept that. Whatever I choose will definitely get finished, have a bit of OCD for that kind of stuff, can never leave anything half completed.
I'm definitely not expecting to end up in any kind of profit for the first few (if any projects) i'm not doing it for the money, its purely for the experience and to further my knowledge. I personally hate having to go to forums/ask people/pay someone to help fix any of my problems, ill always have a go/try/google first and use someone else as a last resort.
In terms of what I'm looking for, theres a guy on here who build a pitbit/supermoto from scratch - that would be the dream. To get a bike down to the bare frame and add bits piece by piece, along with fixing any faults with specific areas along the way. I fear that may be too big of a first project though as my knowledge of electrics/engines/mechanics is very limited and tbh most of the time will be spent googling and youtubing things and getting my hands dirty.
When i do this, ill go balls to the wall and everything that needs fixed, will be fixed (in relation to bearings/fork seasl etc) as the end goal is to have some form of knowledge on (ideally) every part or as many parts on a bike as possible. Even from the very boring basic stuff, I want to be able to master it from there.
i'll take a look at the rundown (rather than crashed) ER5, unless you (or others) have a better first project idea, bear in mind that itll be getting stripped down to the bare frame and rebuilt from scratch.
TL:DR - i dont care how much a. it costs b. time it takes c. difficult it is, itll get FULLY finished by hook or by crook.
PostPosted: 14:51 - 02 Dec 2016    Post subject: Reply with quote
Buy Body007SocketDoctor's FZS600.
Teflon-Mike
tl;dr
PostPosted: 16:22 - 02 Dec 2016    Post subject: Reply with quote
Aermacchi Harley Monkey; BMW R8GS, Clewes Competition Motors B40 'special', Ducati Bevel Drive single; Enfield /Rickman Interceptor; Flink, Gillera saturno; Honda C7 cub, Indian Chief, '48 model in DuPont yellow; Jawa Speedway bike; Kawasaki KR1S; Laverda SFC, Moto Guzzi Convert; Norton rotary; Ossa MAR; Piaggio {because I have already used L for Laverda!} Lambretta PX200 & sidecar!; Q.. thought I'd get stuck here didn't you? QUASAR! {I'll let you google it!, certainly make for an interesting project, that's for sure!}; Rokon 2WD 'woodsman'; Scott, preferably an early barber shop tank example; Triumph Tigeress, just to be perverse!; U, starting to struggle here, so no, I wouldn't restore a Ural.... BUT you get the idea, I can pretty much go through the alphabet and find 'something' I would consider a 'better' project idea than an ER5.....
Crickey, I have renovated four 125 Super Dreams at last count, and I'd deem even THEM 'better' project ideas.. I'll give you an idea of how high up the list an ER5 might figure amongst the candidates for a 'project bike', I actually loaned our snowie the money to buy 'er bludi guzzi with a smashed gearbox, when she threatened to wheel an MOT failed ER5 someone offered to give her for free into my garden!!!! THAT is how little house room I'd give one!
NOT that they are a particularly bad bike; but they are NOT exactly 'inspiring'... for ANYTHING but cheap every day commuter transport! Simple twin shock suspension and less bodywork than many, they are a bike that is potentially easy to live with as a miser miler, and be reasonably DIY maintainable, BUT, the key word is 'CHEAP', and when you can pick up a near minter for barely a grand, if you can get the value from using one, why on earth would you start chucking £100's at an old junker?
The simplicity isn't 'so' simple with water cooled DOHC engine; spares support isn't better than many other common bikes; there isn't an awful lot that would make one in any way 'atractive' to tackle as a project, let alone a bike worth the effort in potential joy of ownership at the end!
Snowie's Guzzi, with a smashed gearbox; offered far far 'more' for the doing; engine is air cooled, which makes things a bit simpler; its also got pushrod valves, that make it more so; fact that the splay V means you can strip one to the crank without even taking the engine out of the frame is quite nice too! Its a 'nice' bike to work on, which is probably just as well, given how much it seems to demand!, but helps add a bit of joy to a project. Parts supply is as good, and in some ways possibly 'better' than even for my common as much Honda, once you have found the two or three 'specialists' for the marque; AND when 'done', its a bike that stands out from the crowd, and attracts attention at meets, that oozes 'soul' and latin 'charm' {for which you can read is a prima donna attension haw, with plenty of annoying, quirks and foibles to keep you entertained.. like the suicide side stand!}.. but IS actually rather 'nice' to ride. Its 'interesting' and slightly more 'exiting'.
WHICH was why I used the ER5 as an example of a BAD place to start! Its just not a bike that offers very much, either in the starting, the doing or the finishing....
AND said, think about a bike you would LIKE to own and could get value from USING when done.
If pit bikes is what tickles your fancy, then why NOT?
Plenty of trashed chinky examples kicking about.. probably nicked, probably not road legal, and hacked about the rough by sink estate hoods.. BUT little savvy on what you buy, and following the rules to get something 'complete' but run down to fix up, THAT could actually be as good a start as any for you.
The chinky ones are shit.... I usually get them wheeled round to me to "look at" after the first week after getting them 'new' of ebay, the hoods have spent hacking them over the common, with clattering tappets, missing sprocket locks, loose spokes and steering bearings, and occassionally the more dire damage of cracked wheel hubs.. if not before when a loose battery stops them starting! Doesn't have to be particularly 'old' for one of those to present plenty to 'restore'!
Motor is a derivative of the old C70 step-through lump; its very very well supported for bits on ebay; and its a simple enough little thing with just one cylinder and air cooling. Technical data for the batch built chinky shit is a little sparse; enthusiasm and ignorance added to You Tube tutorials tend to have me tearing my hear out and jumping up and down on the doorstep when one of the 'lads' turns up with one with its primary drive on show, and a cracked centrifugal oil filter.. but that doesn't seem to detur them! they still turn up, and ask daft questions like "Where can I get a cheap new one of these?" Showing me a broken rocker or something! BUT, little bit of common sense and some research, and you aught to do 'OK'.
And if you did one conscientiously, good chance that you COULD with a few well considered 'upgrades' where chitty chinky alloy IS a weak link, have a pretty useful and reliable bike for the trouble at the end, as it IS mostly the absolutely bludy DIRE original build quality that seems to be thier down fall.
Funky little things, designed to put a grin on your face; may not earn its keep very well as a daily rider, but could justify it pretty well for the giggle factor on the weeend... provided no one nicks it! and it Is small enough to not take up a huge amount of space in the shed, and there's not SO many bits to have to keep track of when you take one apart.
I WOULD seriousely suggest, IF a pit tickles your fancy, then one as a project, even a horrible cheap chinky one is probably a 'better' starting place than an ER5.. which has so LITTLE to offer in comparison.
But, still YOUR project...... but I think you missed the point a bit on that one!
loughy
PostPosted: 16:50 - 02 Dec 2016    Post subject: Reply with quote
Quite a hard post to reply to, between the information and the sarcasm Wink
The thing is, I already have a daily bike in the duke and have my offroad covered with a dt125, so i wouldnt actually use the bike i dont think. Once the project was fully complete, I'd sell/give it to a mate I dont think I'd actually keep it for myself.
I know even if i sell it i'd be making a loss so its not for the money but more for the experience.
Gonna have a look around flea-bay/gumtree and try and find something thats run down which some single mother needs rid of when her partner has fucked off and left her - hopefully find something there.
Edit - I think ill go for a chink pitbike/sumo for a starter as those types of bikes interest me most.
B5234FT
PostPosted: 16:53 - 02 Dec 2016    Post subject: Reply with quote
For a project, you need something which is simple, has available spares, but isnt so common you can buy a mint one for £100 more than a project.
I bought a non running supermoto 125, did a top end, chain, shock rebuild, sorted half the wiring, engine out and back in and various other bits and sold it for enough to cover my costs. The time was invested in learning.
No you'll never make money from it, but research is free and avoids burning it endlessly.
The other way to go is to buy bikes in sequence. Do a non runner and swap the engine and sell it then do one which needs something else, as opposed to replacing every single part on a single motorcycle.
loughy
PostPosted: 17:05 - 02 Dec 2016    Post subject: Reply with quote
Any recommendations on what to look out specifically in terms on "simple, common, and isnt so common u can buy a mint one for £100 more"?
B5234FT
PostPosted: 17:40 - 02 Dec 2016    Post subject: Reply with quote
Not really, as it's opportunistic.
Mine was a non running Husqvarna SM125 with a seized engine for £700, fixed and sold for £1250.
Problem with an ER-5 is that a basket case is £250 and a mint one is £800 so you're always better to just buy the nicest one you can afford than do something up.
The learner legal market is filled with simple, but poorly looked after bikes, but you'd have to have a look around yourself to see if the numbers stack up on sorting out a YBR125 or something.
Teflon-Mike
tl;dr
PostPosted: 18:21 - 02 Dec 2016    Post subject: Reply with quote
125's do have some merit IF you don't have any use beyond the mechanics, mostly in that they are so sore abused by most learners there tends to be plenty to get your teeth stuck into, and there's a reasonably ready market for them when done, so you need not loose too much.
Trouble is that the cheap chinks put a cap on prices, and a better resto will be rated along side a £1199 brand new Lexmoto, and notion of a brand new reg and a warranty means you will struggle to get sensible money for one; and you will more readily sell a piecxe of pretty painted scrap, than something contientiousely overhauled, showing its 'patina'.
Teenage revival bikes, like old TZR's or RD's or early KMX's or DT's command good money, but again, sell more readily on making them look good rather than work good.
Brings us back to the CG125 and the safety in numbers, fact its a cult bike and so still and does command 'some' premium over other Learner Legals, and is very well supported and more economical to 'do' thanks to the number of Chinese CG copy or copy motor bikes floating about. Mechanics are reasonably light weight, its a very simple air cooled push-rod single that's hardly any more daunting to tackle than an air cooled two stroke; and the rest is all pretty conventional and straight forwards. There will always be someone who will want one or be able to make use of one, at the end.
Other one to ponder, would be a Vespa PX125. Again cult status keeps prices reasonably strong, and there will always be some--one who will want or can make use of it. Mechanics are not directly translateable to a conventional bike though, with a two stroke engine, which has merit in being the simpler to spanner; but not having all the gubbins a 4T does; whilst suspension is of its own unique design, and the frame and cycleparts likewise, with step-through frame and bath-tub enclosure. For a reasonably low risk, 1st time project though, and something 'a bit different' to potentially have a bit of fun with when done, could be another likely candidate. Add some make up mirrors and a squirrel's tail on a wip areal, you could even make money on one.
The last post was made 9 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 101.08 Kb
