| loughy |
 loughy Two Stroke Sniffer
 Posted: 09:50 - 02 Dec 2016 Post subject: Duke 2 issue |
Hopefull you'll be able to provide advice.....
Filled the Duke 2 with Supreme unleaded (for the first time, usually put standard unleaded in), left the garage and rode for approx 2 miles before pulling up at a red and all of a sudden the radiator started pissing white smoke. I hadnt battered it for those 2 miles either, all 30's.
Got the bike home, on the stand, turned the key (didnt start it) and the fan kicked in very loudly (first time thats happened) so I put it down to overheating somehow.
Left the bike for approx 15-20mins, checked the radiator, which was full (it was filled with the proper coolant/de-icer mix KTM recommend), checked the oil and that was fine (maybe a little low - but certainly not below the marker).
Thought I'd leave it til the weekend and have a proper look... until today happened....
Coming into work, got 1.5 mile into the 3 mile journey, riding along in 3rd doing 30pm, dropped down to 20 and into second, the second i let start letting the clutch out the revs slutdropped to less than 1k. Pulled over to the side of the road and attempted to pull away again after a few mins and it was dying instantly. Had a look online and the 2 main suspects seemed to be -
Snapped clutch cable - checked both ends and it wasn't snapped
Side stand sensor - Ive had a CBF with had a side stand issue and when you tried to pull away the bike died instantly, the KTM didnt die in the same way, it dropped revs.
Left it for 15mins, tried again and away I go, not a single issue.
Just went to check on the bike after an hour of sitting at work and theres a few small drops of oil on the ground .
I've had a quick chat with a car mechanic at work and he recommends and oil change, filter and spark fplug change (last service was 4k miles ago).
It seems to me like a temperature issue (i could be wrong) but the bike seems to be overheating. It does have an overheating light which hasnt came on at all yet.
TL:DR bike seems to be overheating, will a service fix it? |
| loughy |
| jaffa90 |
 jaffa90 World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| loughy |
 Posted: 12:25 - 02 Dec 2016 Post subject: |
was 100% petrol
Youve got me slightly doubting myself now though, surely my symptoms would be different if id put the wrong fuel in? |
| Polarbear |
| Nobby the Bastard |
| loughy |
| Loui5D |
 Loui5D Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:37 - 02 Dec 2016 Post subject: Re: Duke 2 issue |
| loughy wrote: | slutdropped |
White smoke out of the radiator? Do you mean steam? If so, I'd imagine it was overheating either because the coolant temperature sensor is on the blink, or there are gremlins in the electrics = no light, and no fan.
I wonder if it's running lean.
Has a hedgehog climbed into your air filter and blocked it?
Or potentially you've swirled some crud up from the bottom of the tank, and/or the detergents have successfully dislodged some gunk from inside your fuel filter / pump / lines and it's partially clogging your carb. I'd be looking to give it a good clean out, after draining that 98/102 RON witch-milk and going back to proper 95 prolejuice. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nobby the Bastard |
| loughy |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:49 - 05 Dec 2016 Post subject: |
You've confirmed Stinkwheel's Law, that 90% of fuelling problems are electrical.  ____________________ Biking is 1/20th as dangerous as horse riding.
| loughy |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:18 - 05 Dec 2016 Post subject: |
Nope, totes srs. A lot of things that feel like they should be fuelling problems turn out to be electrical - I've been fooled on that a couple of times.
A good dose with WD-40 might not go amiss - displacing water and helping electrical contacts is the one thing that it actually does fairly well. ____________________ Biking is 1/20th as dangerous as horse riding.
| loughy |
The last post was made 9 years, 111 days ago. Instead of replying here, would creating a new thread be more useful? |
