| smegballs |
 smegballs World Chat Champion
| Commuter_Tim |
 Posted: 23:05 - 02 Dec 2016 Post subject: |
No I haven't sorry, but I've noticed over past posts, there are a few medical types on here for when you set yourself on fire and need treatment for burns.  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| grr666 |
 grr666 Super Spammer
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 23:31 - 02 Dec 2016 Post subject: |
Not made, but I did score a 9V battery powered vest from Maplin and wired into my 14V+ bike electrics with some scorching of nipples.
https://i.imgur.com/E1yxdua.png
I later wired in a 10V regulator (rather than a resistor, ain't technology marvellous?) bolted to a piece of PSU heatsink, which brought the pain down to merely eye watering.
I mention this to remind you that you don't have to stick to the 12 (or more like 14.5) volts coming out of your bike. ____________________ Biking is 1/20th as dangerous as horse riding.
| BTTD |
 BTTD World Chat Champion
 Posted: 00:13 - 03 Dec 2016 Post subject: |
Yes.
I've made heated gloves using beadalon stainless wire. Been using them for four years or so.
I also made a heated jacket, but used copper strand wire which after 3 years has started to suffer breaks. The copper wire just doesn't last it seems. I'm going to do a new version using beadalon wire with 9 sections. That way if there is break, I only lose one section not the whole jacket. Basically going to follow this guy's version:
https://www.k11og.org/phpbb3/viewtopic.php?f=3&t=8572
I got the wire in the post today, and and waiting on the crimps to come. I'm also going to use a couple of pwm controllers. I did put a switch on the gloves to run them in parallel or series, but really they need to be full power, 3/4 power or off. Half power seems be barely noticeable. |
| BillyJ |
 BillyJ Nearly there...
 Posted: 00:33 - 03 Dec 2016 Post subject: |
I bought 2 pairs of these, one to see how much current i can put through it and one to install.
I'm gonna add a variable constant current module off the bike battery and ta-da, heated feet
However they are from china, so hopefully they arrive before next summer  ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
| Nobby the Bastard |
 - Super Spammer
| M.C |
 M.C Super Spammer
| iooi |
 iooi Super Spammer
| Suntan Sid |
 Posted: 11:25 - 03 Dec 2016 Post subject: |
So, what are you going to call it, "BrassmonkeyPal®" or "ColdPal®". and how are you going to fund it? ____________________ "Everybody needs money, that's why they call it money!"  |
 Posted: 12:16 - 03 Dec 2016 Post subject: |
A friend of mine set fire to both handlebars, while riding, by making his own heated grips out of recovered electric blanket resistance wire. Wrecked a pair of gloves and burned both hands in a really sore but ultimately not too serious way (Mmmm, melted plastic on skin to peel off) and managed not to crash.
He's an electronics engineer. Quite a good one by all accounts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Islander |
 Islander World Chat Champion
 Posted: 12:59 - 03 Dec 2016 Post subject: |
Apparently not such a good one then
I've made dew heaters for telescope and camera lenses, and the principle is pretty much the same although somewhat scaled up.
You'd need to think carefully about how much power you intend to dissipate as heat, a bit of Ohms law and a PWM controller will see you through.
Oxford grips as an example, present a resistance of around 6 ohms. At 12V that draws 2A and that equates to 24W albeit concentrated in a relatively small area, I'd probably be looking to try around 30-40W in total for a vest and the same for trousers - remembering that you're also producing heat and you're wrapped in insulation. Using nichrome wire this should be easily achievable although it's a bastard to work with. Remember that the strands are going to get hot - you'll need to make sure that the pads or clothing enclose the heated areas in heat proof material.
The most important part of this is the ability to control the output and for this you'll need a pulse width modulated (PWM) controller. They aren't difficult to design and build and there are also units available commercially - remember it has to be rated well above the potential maximum power draw.
I used to know a rather eccentric, interesting and friendly old chap in the 80s who made his own heated clothing - proper shed and pipe type of fellow. He had Reynaud's and was forced to develop it out of necessity - he powered it from his old BSA and used to punt it around to despatch riders in London.
Having said all that, by the time you've done all the work, it might well be cheaper to buy commercial clothing.  |
| Hong Kong Phooey |
| kramdra |
 kramdra World Chat Champion
| tactical_pancake |
 tactical_pancake Renault 5 Driver
| grr666 |
| raesewell |
 raesewell Traffic Copper
| BTTD |
 Posted: 20:10 - 03 Dec 2016 Post subject: |
| kramdra wrote: | Would not use nichrome wire. In gloves, if you crash, it will be very good at cutting your fingers off. Would not use even in jacket.
China is churning out a lot of very cheap and good heated clothing, they already make it, and it is cheaper and better than anything you could do. They also sell components for it, carbon printed sheets and carbon fibre string probably the best option.
Controllers are very cheap, either PWM or if lots items in series an xl6009
Just got some heated grips from china, in my opinion much better designed and higher quality than the oxford shit available over here. |
The only carbon heating element I've seen available on ebay or anywhere else is like a webbing tape which seemed to be coming out of Russia, and was too expensive. If you have any links I'd be interested in taking a look.
The benefit of making your own, for me as least, is being able to add it directly into my jackets zip in liner. |
| Islander |
 Posted: 20:48 - 03 Dec 2016 Post subject: |
There's nothing wrong with nichrome wire - apart from being a bastard to work with. It has the advantage of being relatively cheap and very predicatable. It does need enclosing in heat proof material though.
Cutting off fingers? I seriously doubt it.  |
| Freddyfruitba... |
| smegballs |
| BTTD |
The last post was made 9 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
