Author |
UnknownStuntm... |
 UnknownStuntm... World Chat Champion
 Posted: 12:47 - 05 Dec 2016 Post subject: Home Automation |
So, after mild harassment by Maplin staff at the weekend for merely standing in front of the (4?) manufacturer's displays I have come to the conclusion that home automation is a bit of a warm potato at the moment. None of them look like they work together, and not one system does what I want, entirely.
Particularly interesting for me as I'm soon going to be building a house extension incorporating a kitchen, then also a garage a little bit later. So I'm considering auto opening garage door, swish lighting, perhaps automatic blinds for velux windows, and obviously some kind of security.
So I've googoo'd and see that there's an open source project that aligns to my findings, and aims to stay manufacturer-independent. I like. (OpenHAB, if you're interested).
So, has anyone got any kind of experience with these things? Good or bad points to think about? |
Back to top |
ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 13:12 - 05 Dec 2016 Post subject: |
What sort of stuff are you looking at. Proper automation or just a couple of lights?
I used to do a lot of this in my house in Holland, not so much here. Was quite a bit of a faff back then (wasn't even close to mainstream). Personally I wouldn't want any cloud based home automation going on in my place.
X10 stuff can be a good starter but it does have limitations. If you're looking at C-Bus, you'll need deep pockets. Garage doors should be simple if the opener has momentary contact points. Just a case of triggering it. I did that in Holland, little phone app to remotely open/close the door. Came in handy more than once when forgetting keys.
Look at https://laser.com for some products and https://www.automatedhome.co.uk/ for stuff that's available. - It has a nice little article on Amazon Echo + Raspberrypi.
If you're just looking at stuff like Philips Hue then just buy that. It has a nice API. ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
Back to top |
UnknownStuntm... |
Back to top |
ScaredyCat |
 Posted: 20:19 - 05 Dec 2016 Post subject: |
How much do you want to do yourself and how much do you just want plug in and go?
Unfortunately WirelessThings, who I'd have whole heartedly recommended, shut its doors earlier this year.
Hive is a solution to your heating, but it's going to be using "The Cloud" - if you're happy with that it's a good option. They also have lighting and switches and door/window sensors and motion sensors.
Keep in mind that for lighting you're going to have to leave your light switches in the on position all the time so that you can remotely have them come on/go off. If someone puts the switch in the off position, no amount of bashing the phone app is going to help you - you'll have to get out of your chair.
Personally I'd stay away from Nest stuff. Whilst I'm an Android fanboy I wouldn't trust Google to continue offering and supporting a product beyond their own attention span.
This is the key factor with cloud based stuff. You rely on the company continuing a cloud service for your stuff to work. When they stop, your investment is worth nowt.
If you're not looking for an API so you can do things yourself then something like Hive will do. If you're looking at doing some of this yourself then openhab looks like a great option for bringing it all together.
Heating is pretty simple, you're just sampling the temperature and switching your boiler on and off - you might be doing some calculations based on outside temperature too. You can calculate the heat loss from your house and calculate how long the heating needs to be on so that when you get up or get home, regardless of the outside temp, the house is at the correct temperature.
Knowing the door is open is trivial, using magnetic sensors
The garage door will depend entirely on the opener that you are using and what I/O triggers it has. Most will have a momentary toggle so you could just trigger a relay for a second to trigger open/close - Simple arduino + relay would work (Yun for wifi?) . For my install I also had door sensors attached the the garage door and wall so I could tell if the garage door was open or closed and also where it currently was in the open/close process.
Philips Hue looks interesting for lighting, from a developer aspect. ____________________ Honda CBF125 ➝ NC700X
Back to top |
331X2 |
 331X2 Crazy Courier
Back to top |
dydey90 |
 dydey90 World Chat Champion
Back to top |
331X2 |
 331X2 Crazy Courier
Back to top |
Pjay |
 Pjay World Chat Champion
 Posted: 14:34 - 06 Dec 2016 Post subject: |
I'd look at this kind of thing, all web based and could be converted to control anything.
https://diyhacking.com/raspberry-pi-home-automation/
I'd also look at making it smaller by using a Pi Zero's and adding wifi to them. They would work out incredible cheap for what they could do.
We are talking under £20 each, all boxed and setup for each device. |
Back to top |
trevoriv |
 trevoriv World Chat Champion
Back to top |
Tarmacsurfer |
Back to top |
Jayy |
 Jayy Mr. Ponzi
Back to top |
goto10 |
 goto10 World Chat Champion
Back to top |
janner_10 |
 janner_10 World Chat Champion
Back to top |
ScaredyCat |
 Posted: 18:54 - 08 Dec 2016 Post subject: |
This is an old video of a motorcycle garage door opening system
https://www.youtube.com/watch?v=CQpBUQ-ZSKw ____________________ Honda CBF125 ➝ NC700X
Back to top |
The last post was made 8 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
