Excel Gurus, lend me your lug'oles.
PostPosted: 14:37 - 07 Dec 2016    Post subject: Excel Gurus, lend me your lug'oles. Reply with quote
May be a simple thing, but my Google-fu is weak today, I have the dumb. I have a single spreadsheet with two sheets, the first contains header information with a summary, and the second sheet contains multiple rows with details relating to the header. As a trimmed down example, sheet one has :-
Code:
A      B            C
Item   Description      Active?
Thing1   Name of Thing 1   True
Thing2   Name of Thing 2   True
Thing3   Name of Thing 3   True
And sheet two has...
Code:
A      B
Item   Detail
Thing1   Something about Thing 1
Thing1   Something else about Thing 1
Thing2   Something about Thing 2
Thing2   Something else about Thing 2
Thing1   More stuff about Thing 1
Thing3   Something about Thing 3
Note that these are not in order (they actually have a timestamp, but not relevant for the example). When adding a new row to the detail sheet, I have a validation rule that allows a dropdown from sheet 1, column A. This means that I can select a value of Thing1, Thing2 or Thing3. This works fine and dandy.
My problem is that from time to time, the header items are eventually marked as inactive (column C = False). I'd like my validation dropdown to ignore any of those items in column A that are marked as such, so that if Thing2 becomes inactive, then my drodown will only present Thing1 and Thing3 as a valid selection.
Any pointers?
Evil Hans
PostPosted: 16:58 - 07 Dec 2016    Post subject: Reply with quote
A quick way to do it would be to have an extra column on sheet one that has the name in it, but only if active is true ... something like
=IF(C2,A2,"")
Then use that column to populate your validation list.
Quick 'n' Dirty Wink
Triumph Sprint ST 1050. And it's Red.
PostPosted: 18:12 - 07 Dec 2016    Post subject: Reply with quote
Aye, I tried that, problem was that if (say) Thing2 was inactive, you'd get a dropdown list of :-
Thing1
<blank>
Thing3
Eventually, you'd be scrolling through tons of blanks before getting to a valid value.
carvell
Scuttler
PostPosted: 19:09 - 07 Dec 2016    Post subject: Reply with quote
Thing1
<blank>
Thing3
I've just followed this:
https://www.extendoffice.com/documents/excel/2445-excel-drop-down-list-ignore-blank.html
And it works fine - you can use it to automatically generate a separate list without blanks which you then use to derive the dropdown from.
Remember Ctrl-Shift-Enter.
Yamaha TDM 850
GSTEEL32
PostPosted: 19:46 - 07 Dec 2016    Post subject: Reply with quote
Thing1
<blank>
Thing3
If it got to this stage with me, I'd simply RANK the values & VLOOKUP the top 50 results on a separate sheet, and bobs your erm.. what's a face. ...
Edit: forgot to mention, if your answer is a 0 or 1 answer, stick a cheeky + RAND function in, so it can still RANK a 1 answer . Email me if this sort of makes sense, but you need a better explanation. ...
Evil Hans
PostPosted: 20:06 - 07 Dec 2016    Post subject: Reply with quote
Thing1
<blank>
Thing3
The validation list has an option to ignore blanks. I confess I haven't tried it though.
el_oso
PostPosted: 00:14 - 08 Dec 2016    Post subject: Reply with quote
ignore blanks allows you to not select a dropdown, i.e leave the field blank iirc.
the way i would it, assuming the order doesn't matter on the detail sheet is sort the detail sheet so that the blanks appear at the bottom.
The other way I can think about doing it would be creating a VBA function that recreates the list on worksheet update. Bit of a pain as you have to do all the heavy lifting yourself due to VBA not having any useful helper methods.
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 09:06 - 08 Dec 2016    Post subject: Reply with quote
Problem solved, inactive header entries moved to a third archive sheet Smile
adriansk
PostPosted: 00:19 - 09 Dec 2016    Post subject: Reply with quote
You can delete all blank rows by selecting your column, press F5, then Special, check Blanks, then OK. Then right click on one of the blank cells and select Delete.
CBR600F4
PostPosted: 08:43 - 09 Dec 2016    Post subject: Reply with quote
https://images.gr-assets.com/hostedimages/1424835484ra/13807341.gif
Andy_Pagin
PostPosted: 09:28 - 09 Dec 2016    Post subject: Reply with quote
This is a classic example of spreadsheets being a two edged sword. They allow non-IT people* to create fairly fancy 'applications', but eventually you hit a point where you need to do something seemingly simple like this and find the spreadheet app cannot do it. Now your stuck because no-one in the company has any real programming skills or knowledge of anything but spreadsheets.
It's not just Excel, all spreadsheet apps stall like this.
*I'm not implying that The Shaggy D.A. is thick, just illustrating the problem.
PostPosted: 11:07 - 09 Dec 2016    Post subject: Reply with quote
My biggest problem was wording my Google query in such a way that would give me decent results. Any hint of "drop down" "validation" "conditional" "vlookup" "index" and it returns the same results. I might have found what I wanted on page 20, but I lost the will to live after about an hour.
Serves me right for trying to build a relational database in Excel.
[edit] Looks like there's an add-in called PowerPivot that lets you set up table relationships :-
https://support.office.com/en-gb/article/Power-Pivot-Add-in-a9c2c6e2-cc49-4976-a7d7-40896795d045#__toc262226430
Might as well just use Access though.
GSTEEL32
PostPosted: 19:49 - 09 Dec 2016    Post subject: Reply with quote
Yup. At this point I move to access. My usual problem at this stage is getting excel users to swap over. People fear databases. Nightmare.
The last post was made 8 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 3.47 - MySQL Queries: 13 - Page Size: 81.84 Kb
