I've just got a trailer for my Enfield
PostPosted: 19:00 - 04 Dec 2016    Post subject: I've just got a trailer for my Enfield Reply with quote
Finally taken delivery of my replica PAV trailer. I've decided not to say where from because the guys communications skills were terrible and it's been many months in the arriving.
However. Got it now.
Pav is Czech for peacock and these trailers were made back in the 1950's for fitting as standard to several Eastern block 2-strokes. They are also popular with the Lambretta fraternity. Several Royal Enfield Bullets were supplied to the Indian army with them fitted.
In fact, they still make a version of these in india called an Inder trailer.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/CIMG1620.jpg
Normally you'd need to puzzle out whre to site the hitch. I'm fortunate in that this has already been done, the bike was supplied from the factory with these trailers so I know where the hitch needs to go. I'm just not entirely clear on the fittings to put it there. Here's a factory fitted one.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/20231_original.jpg
Having got it, I now need to assemble the kit, make up the hitch and do the wiring for it. To that end, I've ordered up some alloy box section and some longer top bolts for the shock mounts. Essentially going to make it as two L-shapes of box section that attach to the top shock mount with a brace up to the rear subframe to prevent pivoting. Due to the nature of the hitch, it should only really be pushing or pulling along the bracket, twisting/turning forces will be minimal.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/bracketside.jpg
The end of the trailer is essentially a universal joint. I'll get a bit of steel plate welded to it so I can bolt that accross the short legs of the two 'L's. It'll obstruct the numberplate and taillight when attached but it will have its own plate and light I can plug in. The idea being it'll be pretty simple to attach and remove with a spanner.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/CIMG1622.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/CIMG1621.jpg
If the alloy doesn't work out, I'll just go for a bit of bent steel flatbar instead. I was going for the alloy for lightness but I'm aware it might not be quite as robust. Worth a try
Copycat73
PostPosted: 20:06 - 04 Dec 2016    Post subject: Reply with quote
different ... just different... Shocked
that is all..
caveat emptor
c_dug
PostPosted: 02:00 - 05 Dec 2016    Post subject: Reply with quote
Ever ridden with a trailer before?
If so, what's it like? If not, what are you expecting?
P.
PostPosted: 11:57 - 05 Dec 2016    Post subject: Reply with quote
Dat chain man. Laughing
chickenstrip
PostPosted: 12:46 - 05 Dec 2016    Post subject: Reply with quote
Gives a beat to tap your foot to on those long rides Laughing
PostPosted: 17:58 - 05 Dec 2016    Post subject: Reply with quote
Never have. I'm expecting it to be much like riding now, only a bit slower to change speed.
If it's well set up, a single wheel trailer should track exactly with the bike and follow it wherever it goes.
If it's badly set up with regard to height, it'll tend to squat under acceleration and lift the rear under braking.
If it's badly set up laterally or the mounting is insufficiently rigid, it'll crab across the road dragging the bike after it or start a death weave then crash.
PostPosted: 18:02 - 05 Dec 2016    Post subject: Reply with quote
Meh. 14bhp through an x-ring 530 section chain.
virus
PostPosted: 19:47 - 05 Dec 2016    Post subject: Reply with quote
All of your assumptions are correct. Laughing
Id also add that overloading it will cause the front to go light, probably less of a problem on your Enfield compared to the old 6/12 or the rather heavy gpz750r that towed before it.
Main cause of fail on something like this really is the rigidity of the mount and making sure its vertical, Id also be tempted to replace that ropey looking connection for a real propshaft UJ should you get any unexpected weaving.
own: 81 xs1100g...
P.
PostPosted: 20:05 - 05 Dec 2016    Post subject: Reply with quote
My Vara split it's chain at 35... Fuck that.
PostPosted: 20:23 - 05 Dec 2016    Post subject: Reply with quote
I thought the main cause of fail was the owner welding it on with the trailer wheel visibly on the piss in at least two planes and not on the centre line of the bike the night before a rally? Wink Laughing
You will note, even at this stage, I've got the spirit level out.
The joint doesn't seem bad actually. It's a proper bearing block when you look at it more closely.
PostPosted: 20:26 - 05 Dec 2016    Post subject: Reply with quote
The chain gets changed when the gearbox sprocket starts skipping teeth and not a moment before.
virus
PostPosted: 20:39 - 05 Dec 2016    Post subject: Reply with quote
Hypothetically speaking that would cause quite bad handling issues, I'm willing to bet slightly melting an indepension unit bush with welding heat wouldn't be productive either, hypothetically speaking of course. Laughing
Cheers
John
own: 81 xs1100g...
lingeringstin...
PostPosted: 13:25 - 06 Dec 2016    Post subject: trailing Reply with quote
I've found that my mono wheel trailer tracks fine and is very stable at any speed above about 20. Below that it can sort of feel like you're carrying a wobbly pillion when loaded with camping gear but once you get up to speed you literally don't know it's there, which can be a bit of a danger if you're not paying attention. Extreme potholes can give you a wakeup call if you're not paying attentionm. Feels like somebody grabbing the back of your bike and giving it a shake, but at least a single wheel trailer will always just trail behind you no matter what. I've heard scare stories about two wheel trailers going wonky after a bump or around fast bends but have never had one so I wouldn't know.
Mine was cobbled together badly in a rush and tweaked and modified more later but it's perfectly functional now. Decent clearance is a plus. I've seen trailers become sleds in mud or ground out over humps. Yours looks very nicely designed.
Mine has absolutely no suspension but I run a soggy tyre filled almost entirely with tyre goo and a little water and that sort of acts like a deadblow hammer effect so it doesn't bounce much if I hit a big bump at speed. It might have one good initial hop and then it's planted well on the road again. Works a treat.
The only thing I've found to really be aware of is not to load mine too high because it gets more wonky at low speeds. But if the loading is kept low it's virtually unnoticeable on the road.
People can't believe my wee 280/250-4 tyre has done thousands of miles without exploding but I've never had the least trouble with it. It's a split rim so easy to fix if I have a puncture, which is fairly unlikely, and I've seldom gone over 60mph with it. Got yelled at by a copper once for blatting along too fast in a 50 zone.
I think The Law says you're only allowed to do 50 with a bike trailer anyway and as I generally take back roads this is never much of an issue.
Feasty
PostPosted: 16:29 - 06 Dec 2016    Post subject: Reply with quote
Looks nice but you'd never get me in one of them, I'd rather stay on the bike thanks.... Wink Razz Laughing
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
pepperami
PostPosted: 10:43 - 09 Dec 2016    Post subject: Reply with quote
Laughing Laughing Stupid boy! It`ll be fine once the seat is installed and bolted in properly ........ I was wondering where the seat belt anchor points are?
RhynoCZ
PostPosted: 11:53 - 09 Dec 2016    Post subject: Reply with quote
It's nice to see you didn't give up. Thumbs Up
PostPosted: 17:28 - 10 Dec 2016    Post subject: Reply with quote
Further bracketry mocking up.
I've done this using 30x18mmx1mm aluminium box section.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/CIMG1629.jpg
I'm going to use a slice of solid alloy bar as an insert inside the box section where it's bolted through so it can be tightened right down hard.
One problem is that the top shock mount is the furthest back "solid" piece of bike to bolt to. Everything else is subframe which, while solid enough to mount a pillion seat to, has a certain amount of flex.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/CIMG1631.jpg
My next issue is how to join the bits of box section. They're just gaffa taped in position for now. It would be nice to get them TIG welded up. I'm wondering if the parts could be tacked on along a single edge with them in situ as it is now then the whole lot removed and the rest of the welds done on the bench.
Also not entirely sure how well this box section will weld.
Another option is to through bolt it.
A third option is to rivet it with gusset plates over the joins.
I feel the latter two options will land up going rattly and bendy in quite short order.
I may yet give up on the idea of alloy in favour of stronger and easier to work with (but much heavier) steel.
Itchy
PostPosted: 18:21 - 10 Dec 2016    Post subject: Reply with quote
I was expecting a beer keg like Virus's trailer. Laughing
P.
PostPosted: 21:22 - 10 Dec 2016    Post subject: Reply with quote
I was expecting a maintained bike Laughing
PostPosted: 21:34 - 10 Dec 2016    Post subject: Reply with quote
I'm sure the tank get petrol, tyres get air and the engine gets oil occasionally Smile
PostPosted: 22:17 - 10 Dec 2016    Post subject: Reply with quote
The chain's fine as it happens. It's just hanging very slack because it's on the mainstand. No tight links.
The rust is what you get when you buy an Indian motorcycle with one layer of paint on the metal parts then ride it in through several British winters. Everything that's supposed to move, moves. It's on its fifth rear tyre which means it'll have done over 50k miles now.
It's a ratbike. It was a ratbike when it looked like this, it was just newer.
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0322.png
It's been a gradual process. It actually runs and rides better than it ever did.
https://i48.photobucket.com/albums/f216/stinkwheel/newracks.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0695.png
https://i48.photobucket.com/albums/f216/stinkwheel/rbr/05.png
https://i48.photobucket.com/albums/f216/stinkwheel/rbr/29a.png
https://i48.photobucket.com/albums/f216/stinkwheel/cimg0474.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/tramps/1P1100045.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0918.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/dragon2014/CIMG1496_zps06af63b4.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/dragon2015/CIMG2247_zpsxgolmvis.jpg
I bought it to ride, not to polish/paint. If it was more badly maintained, it would leak a lot more oil and probably wouldn't be so rusty.
Incidentally, you can probably see why I want a trailer.
RhynoCZ
PostPosted: 22:25 - 10 Dec 2016    Post subject: Reply with quote
And soon to be turned into a ''party machine''... Razz
https://jawamania.info/Files/moto/53532/DSCN0289.JPG
PostPosted: 01:04 - 11 Dec 2016    Post subject: Reply with quote
Indeed. There are already plans afoot for a built in "buckfast tap". Something antique in brass would work well I think.
PostPosted: 22:49 - 15 Jan 2017    Post subject: Reply with quote
Right. I've sacked off the idea of aluminium.
I made an attempt with flatbar but it was still too bendy so I've gone for 30x30x3mm angle.
I've also bought myself a stick welder. Never used one before, I had a cheapo gassless MIG a while ago which set itself on fire. This is a small inverter welder that does up to 100A. Nvere used stick before so steep learning curve. Spent much of Saturday burning through welding rods and wrecking perfectly good pieces of metal.
So you'll need to excuse the standard of the welds, they are slowly improving. I cut a few in half and I'm happy getting enough penetration.
So. Three pieces of angle.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0089.jpg
Weld them together flat and square and cut the corner off.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0092.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0090.jpg
Couple of bits of flat bar for bracing.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0088.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0093.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0094.jpg
Now, there is almost nothing straight or symmetrical about this bike. Especially when you get into the realms of the rear subframe which is made of hammered out rupees mixed with elephant dung. I basically eyeballed the bracketry I've done thus far, it'll be as straight as any other bits.
I figure I want the trailer to be square and aligned with the back wheel. So check the wheel is aligned then set the bike up on the stand so it's level in both axis.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0098.jpg
Find the centre line of the wheel and tyre using chalk and a straight edge.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0096.jpg
Find where plumb centre lies on the hitch by sighting along mark 1 improvised plumb line.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0097.jpg
Mark level with a spirit level and that's the angle I need to mount the bracket at.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0099.jpg
I'm attaching the bracket to a second piece of angle to facilitate easy mounting/removal. As you can see, the hitch is a tad wonky but the bracket should be true.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0100.jpg
Cunning plan for locating the bracket.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0102.jpg
Then bolted on. Using bolts.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0104.jpg
I attached the trailer and took it for a low speed trundle around the cul-de-sac next door. Entirely uneventful. No pics of it attached yet because the flash is playing up on my camera. Hitch now removed for painting.
You may have noticed the new mudguard too. Plastic trials one. I have another one to join to it to make it long enough.
PostPosted: 23:07 - 15 Jan 2017    Post subject: Reply with quote
Done some bits on the trailer too.
Needed a light so I've gone for a Lucas type 679. The taillight on the bike is totally fucked too so I'm fitting one to that too. Diddy numberplate fits in the gap nicely. Not strictly legal but it's going to take a world champion Dibble to be familiar with C&U regs for motorcycle trailers. It's not strictly legal in various other regards too.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/378bd4ce-b23c-4b8c-a4f7-5b9fb5bc9ada.jpg
Keeping it tidy.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0127.jpg
Spunked for a decent connector for the lighting.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0128.jpg
Surface mount end with cap to go in the side of the numberplate holder on the bike.
https://i48.photobucket.com/albums/f216/stinkwheel/Trailer/DSCN0133.jpg
I'm beginning to agree with the comment virus made above about the bearing block. It doesn't seem chunky enough. It'll do for now but I'm going to look into replacing it with something meatier.
The last post was made 7 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.32 - MySQL Queries: 15 - Page Size: 152.2 Kb
