Don't leave killswitch in off position if bike kept outside
EuropeanNC30R...
Gay Hairdresser
PostPosted: 11:22 - 21 Feb 2005    Post subject: Don't leave killswitch in off position if bike kept outside Reply with quote
Some times I've left the kill-switch on 'off' setting as an additional security measure, fool inbred thieves etc. However, doing so has just caused me some grief.
Basically my bike wouldn't start off the start button or from bump-starting, yet every now and then would start first push of the button. Suggesting it had ignition and starting problems. Last night I took the kill-switch apart and there was some oxidation on one of the terminals in the switch. This terminal made up a circuit, that if wasn't connected, would stop both the starter and ignition circuits firing. This terminal is always covered by the switch when it's left in the on position, so wouldn't have oxidised at all had I not left the switch in the 'off' position'. Doh!
Sorry to bore you, just worth keeping in mind to save yourself the hassle I had.
PostPosted: 13:04 - 21 Feb 2005    Post subject: Reply with quote
Ouch. Nice one to catch you out. Mind you, 10~15 years of this before a problem is not bad going.
Polarity
PostPosted: 16:35 - 21 Feb 2005    Post subject: No Start Reply with quote
Same thing happerned to me last night thought the alarm had killed the battery. Think i'll stop turning the kill switch off now.
dansuresh
PostPosted: 08:52 - 28 Feb 2005    Post subject: Reply with quote
Anyone know if this happens with the RS125??
Guest
PostPosted: 11:12 - 28 Feb 2005    Post subject: Reply with quote
I'd have thought that the more often you operate a switch the better it'll work, as you're continually 'wiping' the contact faces clean. Leave it in one position and the exposed face could get a covering of verdi-gris so when you actually need it it won't conduct properly
BlueNinja
PostPosted: 11:19 - 28 Feb 2005    Post subject: Reply with quote
I have heard that all kill switches are delicate, so only use it in emergency situations.
Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483
EuropeanNC30R...
Gay Hairdresser
PostPosted: 11:37 - 28 Feb 2005    Post subject: Reply with quote
The way the kill-switch is wired on the NC30 means that if a terminal does get corroded the bike won't start or run full-stop. The starter and ignition circuit relies on it. It's not a case of it not working when you need to use it Smile
instigator
PostPosted: 11:44 - 28 Feb 2005    Post subject: Reply with quote
Don't think I've ever used my kill switch.
Used to HAVE to on my old 125 since taking the key out of the ignition didn't switch it off Laughing
Ric
PostPosted: 13:24 - 28 Feb 2005    Post subject: Reply with quote
wouldnt bother, altho the rs kill switch doesnt stop the engine turnin over just the spark so can be havok if u left kill on and cant work out why it wont start
The Tot
PostPosted: 19:03 - 28 Feb 2005    Post subject: Reply with quote
Nice one Maurice, i'll take that on board, I've ALWAYS put on my kill switch regardless of situation, but now i'm thinking why bother when i have a hefty lock and chain on the rear looped around some object But yeh - could this be the demise of "killswitch - engage"? sorry a bit of a crap joke eh? Razz
Never argue with autism
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 63.25 Kb
