Rema - Puncture kit
mudcow007
PostPosted: 14:55 - 14 Dec 2016    Post subject: Rema - Puncture kit Reply with quote
Last night i broke my puncture cherry Thumbs Down
Managed to get home on it, but was pretty soft when i eventually rolled in
Just ordered a "Rema" kit, as they seem popular.
Anyone use them, if so how you do it?
fanks
owl
PostPosted: 15:10 - 14 Dec 2016    Post subject: Reply with quote
used a stop and go kit on the weekend on a brand new tyre that had only done a few hundred miles Sad
they're mushroom plugs, took about 10mins to fit and it seems to have worked fine. Air still in tyre and has held up to some pace so far.
Observation is the greatest source of wisdom.
PostPosted: 15:22 - 14 Dec 2016    Post subject: Reply with quote
Stop and Go mushrooms for me. I carry a small pump as well rather than relying on gas cannisters.
mudcow007
PostPosted: 16:10 - 14 Dec 2016    Post subject: Reply with quote
Dammit, well the Rema kit was only £20 so will give it a whirl, if its pants will get the Stop n' Go kit from Busters or something
cheers chaps Thumbs Up
PostPosted: 16:46 - 14 Dec 2016    Post subject: Reply with quote
Rema tip top kits are fine.
Give them a damned good reaming THEN lube them up.
You usually have to make the hole a fair bit bigger. The reaming tool should go in and out comparatively easily or you'll just snap the insert.
Lube up the hole and insert thoroughly with the special glue.
Monkeypony
PostPosted: 16:49 - 14 Dec 2016    Post subject: Reply with quote
Stop and go for me too. Done the full life of a tyre with one in place, including a trip to the isle of man and some rather enthusiastic speeds.
Although, like Rogerborg I don't rely on the gas canisters. I carry a 12v mini compressor.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
PostPosted: 17:07 - 14 Dec 2016    Post subject: Reply with quote
I'm sure a Rema kit will be just fine, by the way, I'm only comparing stop-and-go to a basic string kit, which I've had successes and fails with.
The last car tyre I did had 3 stop-and-go plugs put in it before the valve snapped off.
secretagentmo...
PostPosted: 17:55 - 14 Dec 2016    Post subject: Reply with quote
Ultraseal for me!
DJP
PostPosted: 17:56 - 14 Dec 2016    Post subject: Reply with quote
The only puncture I've ever repaired roadside was done with a Rema kit.
It worked fine and I've always carried one since.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
PostPosted: 19:13 - 14 Dec 2016    Post subject: Reply with quote
stinkwheel wrote:
<giggle> are fine.
You usually have to make the hole a fair bit bigger. The <chortle> should go in and out comparatively easily or you'll just snap the <snigger>.
Lube up the hole and insert thoroughly with the special <titter>.
Very Happy
Kawasaki Jimbo
PostPosted: 20:13 - 14 Dec 2016    Post subject: Reply with quote
I've used Rema puncture repair kits with the mushroom plugs 3 or 4 times over the years. Never fails, and I've used them as fit and forget. Just follow the instructions. The only problem I had was when I mistook a cut in the rear tyre for the puncture, spent 20 mins fitting and allowing to set, then when I used the CO2 cartridges I realised I'd just made a hole and then sealed it. I had to do it all again once I'd found the real puncture, which unusually wasn't flagged by a nail, screw or chunk of glass. Whatever it was must have worked it's way out again. I was late for work that day.
M.C
PostPosted: 20:32 - 14 Dec 2016    Post subject: Reply with quote
My plugged rear tyre (with stop & go mushroom type) isn't holding pressure that well, needs to be checked every few days. For example the front dropped to 30 psi and the rear to 20 (from 33/35) after about a week of not being ridden.
Looks like it'll be a new tyre Neutral
kramdra
PostPosted: 00:35 - 15 Dec 2016    Post subject: Reply with quote
It does not take long to get the wheel off, tyre off and put a plug from the inside.
www.ebay.co.uk/itm/371432419139
Recommend one of these, fits underseat if you remove the plastic casing.
BTTD
PostPosted: 08:39 - 15 Dec 2016    Post subject: Reply with quote
What do you go for, cheap ebay jobby, or something else??
Monkeypony
PostPosted: 09:20 - 15 Dec 2016    Post subject: Reply with quote
This one:
https://www.amazon.co.uk/dp/B01G5FDXTI?psc=1
It's done the job both times I've needed it, and it fitted in the tail storage of the 'Busa.
Doesn't fit in the new bike though, but then, neither do the tyre plugs! Laughing
PostPosted: 10:17 - 15 Dec 2016    Post subject: Reply with quote
At the roadside?
PostPosted: 10:46 - 15 Dec 2016    Post subject: Reply with quote
If you have a tyre fitting machine.
Last time I had a tyre fitted to my VFR, the guy had to get up on the machine and use his knees to hold it down. It also took 90psi with the core out to get both beads seated.
Somewhat beyond the realms of the average home mechanic.
PostPosted: 11:13 - 15 Dec 2016    Post subject: Reply with quote
I'd like to see a realistic "DIY motorcycle tyre fitting" video on YouTube rather than upload-only-if-success ones.
Two guys sweating and grunting and wrestling, before admitting that no matter how much lube they use, they'll never finish if they insist on using a rim protector, they'll just have to risk internal tearing from their hard shafts.
Said it before, didn't listen to myself, will now say it again as an aide-mémoire: next time, I take it to a garage and let them deal with it.
BTTD
PostPosted: 14:18 - 15 Dec 2016    Post subject: Reply with quote
I've fitted my own tyres and I have to admit it's never as easy as it looks on youtube, but it's definitely doable (at home in a garage, it definitely isn't doable on the side of the road).
It takes me a full morning by the time I've cleared some space in the garage, found all the tools, the manual, worked out what the hell I'm doing, checked over the pads and bearings while I'm there, and then cleared everything away again.
There is usually a fair amount of swearing.
Meanwhile Youtube suggests it'll take you 15 minutes a wheel. Laughing
But then, by the time I take the bike somewhere, wait for them to fit the tyres, and get back home I've lost most of a morning anyway and it's cost me maybe £50? I always end up telling myself not to such a lazy fck and to get on with it.
Hawkeye1250FA
PostPosted: 15:50 - 15 Dec 2016    Post subject: Reply with quote
Did front and back in the garage on Sunday morning.
Took 2 of us 3 hours. Most of which was trying to get the f#cker off the rim (With home made rim protectors on). Before giving up and doing it without and touching up the scratches with Hammerite metal paint.
For the sake of a fiver - Ill take the wheels off the thing and take them (plus the new tyres) to a garage and get them to do it!
I enjoyed it though. Laughing
PostPosted: 16:25 - 15 Dec 2016    Post subject: Reply with quote
You can fold a strip of milk carton over the end of the lever/spoon.
Horror! I'd never do that and admit to it plus all the sanding to get the burrs out.
Hahadumball
PostPosted: 18:42 - 15 Dec 2016    Post subject: Reply with quote
did both tyres on my vtr 2 days ago, shovel to break the bead, took me around 45 minutes for both tyres including bearings.
i use cheap amazon £12 for 30 strings, used them twice and had a 100% success rate so far
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Kawasaki Jimbo
PostPosted: 19:32 - 15 Dec 2016    Post subject: Reply with quote
This guy makes it look easy although he doesn't seem to worry about chipping the wheel rim. Compare this with the laughable and tyre-mangling zip-tie method. Not practical in a roadside emergency though.
kramdra
PostPosted: 21:16 - 15 Dec 2016    Post subject: Reply with quote
Rogerborg wrote:
At the roadside?
OP said he got home on it, assuming he wants to use as a permanent repair Mad
I do not carry all the tools for that but yes, quite likely in the future if I have a valve issue or a large puncture that can not be sorted with a string. I would have to call someone out with the tools from my garage and perhaps my spare tire and buy them some beers. It would not take me long, Ill have it done hours before any RAC cunt is likely to arrive. I had plenty of practise, fitted and repaired my own tires for the last 35,000 miles
I would need delivered: spade, g clamps, tire levers, 3 blocks of wood, rim protectors, spare valves, bar of soap (all kept together in garage), tire and centre stand.
The one exception to this is a Michelin front tire. The bead will **NOT** pop without a lot of air. I have had great success pumping up a spare wheel to 44psi, core removed, hose clamped, and releasing this into the Michelin. I would request my spare racetec delivered, they are easy to fit, but either will work.
Hong Kong Phooey
PostPosted: 21:30 - 15 Dec 2016    Post subject: Reply with quote
8" G-clamp recommended on 160 tyres, can be done with 6" clamp and lots of mucking about.
Tried breaking bead with a spade but I have grown fond of my ankles so ditched that method and bought an 8" clamp. Piece of piss in comparison. Thumbs Up
15 min is BS, about 45 min for a single rear tyre & valve off/on, static balance and seated IIRC, with compressor. Front is way easier. Lube up well for taking rubber off/on or suffer. I did my back in first time round with 2 big levers and 1 smaller one Embarassed
The last post was made 9 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 130.94 Kb
