Downpipe fused to engine
Sigals
PostPosted: 12:18 - 17 Dec 2016    Post subject: Downpipe fused to engine Reply with quote
I recently bought a 2010 CBR 125 and as I was riding it a few days ago the exhaust snapped off as it was extremely rusted.
The problem is that it snapped just where the down pipe enters the engine and it seems to be so rusted that its fused to the engine.
I'm having a lot of trouble getting this part off - I've tried soaking it in WD40 for a few days but that's not made any difference.
I took a dremel to the outside of it trying to release the rust seal but haven't had much luck there.
I've seen a few other people with the same issue where they used a blowtorch or blowlamp to heat it up but I'm concerned about warping the aluminium engine.
You can see the problem here: https://i.imgur.com/8g2xGuE.jpg
I'm pretty much lost as to where to go next.
Any advice would be appreciated.
Copycat73
PostPosted: 12:37 - 17 Dec 2016    Post subject: Reply with quote
I`ve seen this happen once before .. on an XT500 .. using a cold chisel tool & a hammer he knocked the stump via the jagged end in circular movement and spun it out of the exhaust socket hole .... there looks to be plenty of metal there to get the chisel into..
caveat emptor
PostPosted: 13:55 - 17 Dec 2016    Post subject: Reply with quote
Get a large cold chisel and put the end of it flat on the side of the exhaust collar where the line is in the pic attached. Take a medium sized hammer and give the chisel a few stout clouts. Hopefully this will cave in the side of the collar and break the rust bond.
You have to be brave and hit it with confidence, and you have to have the chisel square against the collar, not cutting in at an angle.
PostPosted: 14:23 - 17 Dec 2016    Post subject: Reply with quote
Being honest. If it were mine, first thing I'd try is a crowbar/giant old screwdriver with bent tip (I presume everyone has one of these) in the hole and start trying to lever it out. If you can get the end hooked under the rim of the steel where the gasket goes and start it rocking even slightly, you can then work penetrating oil into the gap that appears and keep working round until it comes.
Risk of snapping the casting if you're overly forceful doing this.
PostPosted: 17:57 - 17 Dec 2016    Post subject: Reply with quote
CBR125s are always doing this. First, forget WD-40, get some PlusGas in there.
What Pete said, although I'd dremel along that line first then try and fold it in.
You may find that the bond is stronger than the remains of the exhaust and you just end up knocking lumps off the exposed part without shifting the portion stuck in the engine. In extremis you might have to take the head off to get enough access - I had to do that on a Hyosung 125 with the same problem.
Best of luck.
dydey90
PostPosted: 21:52 - 17 Dec 2016    Post subject: Reply with quote
Been there. Much blood. Many sweat. Such tears.
Took so much to get out that I kept the stump as a souvenir.
I ended up dropping the engine out, getting it in a vice, stuffing it with a rag and cutting a slot in the stump with a hacksaw blade.
These days I'm much better welder though, so I'd probably try welding a stick on and either turn/wiggle* it out or find something to jack it against.
I appreciate that welding gear isn't readily available to most people, however.
*sorry for using the technical terminology.
PostPosted: 22:40 - 17 Dec 2016    Post subject: Reply with quote
If I had a welder, I'd weld a big nut on then have at it with a burp gun until one of us gave up.
I wonder if a blind bearing puller would get a good enough grip here?
PostPosted: 22:49 - 17 Dec 2016    Post subject: Reply with quote
You could easily burn it out with a stick welder. Stuff a soaking wet rag into the port use a thin rod and turn the amps up. you'll melt away the steel tube but not bother the ally at all unless you were very clumsy.
Copycat73
PostPosted: 11:18 - 18 Dec 2016    Post subject: Reply with quote
given the difference in meltin point of mild steel and aluminium alloy do you really think this is such a good idea .. ???
caveat emptor
PostPosted: 11:26 - 18 Dec 2016    Post subject: Reply with quote
Yep it's a great idea. Aluminium has far superior conductivity. It might melt at much lower tempt but it conducts heat away so fast it takes a lot longer for it to get there locally that the steel will burn away before the ally gets to melting point.
That's why your piston doesn't melt at combustion temperatures Smile
Copycat73
PostPosted: 12:17 - 18 Dec 2016    Post subject: Reply with quote
those temperatures are created by fast moving gasses and not direct metal to metal contact which will provide a much more sustained heat transfer ..
having done both MMA and TIG welding ..
I would not attempt it.. frankly the area will be sprayed in hot spatter
but I`m sure OP will let us know how he gets on ..
PS .. I would be tryin a plumbers freeze spray before cold chiseling.
caveat emptor
PostPosted: 13:22 - 18 Dec 2016    Post subject: Reply with quote
Bad analogy. Combustion temperatures are constantly 900 degrees yet the piston doesn't melt, not at all like a one-off hit with a welder.
The guys at work build up concrete cruncher jaw seats by g-clamping a pair of ally plates across the sides and filling the gap it with 1.2mm wire. Typically they'll fill a gap 20mm wide by up to 40mm deep building the weld up directly against the ally. The plates don't melt despite being blasted with a 3 phase mig on spray transfer for extended time because the heat is conducted away too quickly.
Aside from that aluminium instantly forms an oxide layer that resists 3x ally melting temps. Since you've done tig you should know that because it's the reason you have to tig ally on AC current - to break away the oxide layer.
I'm not saying you couldn't fuck it up by arcing directly against the ally, but it would be easier not to.
Copycat73
PostPosted: 16:57 - 18 Dec 2016    Post subject: Reply with quote
all the external oxide will do is act like a bag stopping the aluminium from spillin to the ground.. it won`t stop it deformin.. take a look at those plates and you will find they are marked and not the "flat" surface they started with..
I`ve yet to see a modern welder machine that don`t use AC.. MIG. TIG. or MMA.
can you give an example ?
caveat emptor
PostPosted: 17:12 - 18 Dec 2016    Post subject: Reply with quote
No I don't have to. I've done similar - it works. Simple as that. Time-honoured method of removing broken bolts and studs and you never hear of anyone burning away the ally there.
Copycat73
PostPosted: 17:32 - 18 Dec 2016    Post subject: Reply with quote
OK ...Thumbs Up .... well then .. just a thought .. are you gonna fix OP`s engine for him ?
would be helpful if Sigals provided a location ?
anywhere near Gateshead Question
caveat emptor
PostPosted: 18:31 - 18 Dec 2016    Post subject: Reply with quote
If I knew he was nearby, I probably would have already not only removed the stuck bit but turned up and welded on a replacement.
Sigals
PostPosted: 02:10 - 20 Dec 2016    Post subject: Reply with quote
I gave it another go with the chisels and a lump hammer but not had much luck.
I've contacted a local garage to see if what they have to say - I don't think I'll be able to get it out myself.
Sigals
PostPosted: 20:31 - 22 Dec 2016    Post subject: Reply with quote
Got an update to this.
Had a friend come round who's a mechanical engineer and he had a really long chisel so could get a lot of leverage and he knew exactly where to place it on the stump.
Ended up knocking it out with one blow - you can see the remains here: https://i.imgur.com/WtuocxT.jpg
I've got a new exhaust installed and working all good now!
PostPosted: 22:31 - 22 Dec 2016    Post subject: Reply with quote
Excellent!
Very often I see people struggling with things and I'm sitting here thinking 'I would have that out in moments'. Glad you found someone who knows how to use a hammer properly.
Enjoy Smile
The last post was made 9 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 108.12 Kb
