 Posted: 14:46 - 17 Dec 2016 Post subject: Anyone running an NV200 or Vauxhall Combo? |
After the latest monumental fuckup from the failVito*, I'm about to start pestering my boss for a new van.
I need a van that I can fit a motorcycle in the back of but with a low enough roof I can lift a 35kg canoe onto from my shoulders (so max roof height of 1920mm).
After a fair bit of research. I've come down to either a Nissan NV200 or a Vauxhall Combo (ideally an H1L2). Transit connect would also be on the list but given my options, it's more expensive and my boss is cheap.
Any comments on reliability, driveability and confirmation you can load a full sized motorcycle into the back of them (Not necessarily a 1200GS but definately a fully faired sportsbike). Problems? Good/bad points?
*So after the lighting ECU failed. The injectors were scrap, then the main ECU died. Just had to replace both front brake callipers due to totally seized pins and now the new ECU looks like it's just shit the bed. Not even hit 100k miles yet. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Shaft |
 Shaft World Chat Champion
 Posted: 23:39 - 17 Dec 2016 Post subject: |
Blimey, you really do have the Friday afternoon Vito, I've never known one go so badly wrong, at such low mileage.
Anyway, of those two, I would lean towards the Nissan.
The new Combo (AKA Fiat Doblo) isn't a patch on the previous model, either in terms of build quality or driving experience. The price of spare parts/service items have gone a bit mad (probably because it's a Fiat) and, judging by the few we've had through our workshop, I reckon you'll be needing to buy more parts than you might like. I'm not a huge fan of that family of diesel engines either, they aren't especially reliable.
Modern Nissans don't have the legendary Jap build quality of old, but from the couple that I've seen, they're better screwed together than the Vaux/Fiat and, surprisingly, the parts prices aren't too awful either.
Has the Citroen Berlingo appeared on your radar?
I've been looking after a sizeable fleet of those for the last three or four years, which have been pretty good. ____________________ Things get better with age; I'm close to being magnificent........
| MattEMulsion |
 MattEMulsion World Chat Champion
| G |
 G The Voice of Reason
 Posted: 21:33 - 18 Dec 2016 Post subject: |
These are a step down from the vito (the primastar/Vivaro/Traffic/Custom are the vito equivalent) - from my previous research, it's quite likely going to need the bike sideways a bit on the smaller ones.
Certainly not going to be as easy to slot in two as you can with a vito.
Got any non-rusty bodywork for sale? And a gearbox. And a chassis, actually?  |
| Shaft |
 Posted: 23:47 - 18 Dec 2016 Post subject: |
Somehow, I managed to completely ignore the load space aspect of the OP.
I reckon you might struggle a bit to get a decent sized bike in either of your choices - when Pyro picked up a Superdream from me, we had to take the top box off and it was still a tight fit, in a Berlingo, which is a similar size of van.
As G says, this is a step down, size wise, from a Vito. ____________________ Things get better with age; I'm close to being magnificent........
| MattEMulsion |
| Jewlio Rides Again LLB |
 Jewlio Rides Again LLB World Chat Champion
 Posted: 00:00 - 19 Dec 2016 Post subject: |
The 63' plate T140 Tranny van at our place is nice. LWB mid top.  ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
| Rncv |
 Rncv Nitrous Nuisance
| andyscooter |
 andyscooter World Chat Champion
| G |
| andyscooter |
| G |
 Posted: 15:03 - 19 Dec 2016 Post subject: |
The vito is a shonky piece of crap. My local repairers tried everything to get it out of limp mode. It kept saying there was a fault with the volume air sensor but changing it never fixed it, nor did the umpteen other things they tried. It had to go back to Mercedes in the end and they said the ECU was toast. Replacing it worked for about 10 months and now it's reading the same fault code again.
When the injectors went (would fail to restart after being parked up), they were sent in for reconditioning and the company called back saying there was nothing they could do with them and they would scrap them for us.
I'd say it's spent half of the last two years in limp mode.
I think a Transit custom is going to be too tall. 1922 roof at the lowest point but 2020 at the highest. 1922 would put it at the upper extreme of what I can lift my boat onto without having to have a step/platform next to it.
I don't really need to get two bikes in it. Just if I needed to drop off/collect one. If I'm taking one on holiday, I take a tiddler like the YB100. Used to get three bikes in the SWB transit but I don't really need such a big van at the moment so downsizing was on the cards.
I think the ones I was looking at are kind of a "big small" van rather than a "small small" van like a Berlingo or nemo or a "mid size" van like the vito/transit custom.
The main "pinch" point I found with the vito is the back door height.
The Vito is 1264mm. The new combo H1L2 is 1250. The NV200 is 1228. So the bike should physically go into the back of one up a ramp.
Length is the potential issue. Vito is 2422, Combo is 2170, NV200 is 2040.
The VFR wheelbase is 1480 so add 17" (431mm) and we have 1911. Mathematically a VFR750 should fit in the back of an NV200 without even angling it.
By comparison a berlingo has a door height of 1155 and is 1700 long, so much smaller.
I feel a scale drawing coming up.
The Nissan is sounding like the best bet to be fair. Also has two sliding doors which is one thing I really like about the vito. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
 Posted: 15:18 - 19 Dec 2016 Post subject: |
Motorcycle wheels are based upon rim size, not tyre size remember (while many push bike wheels are done on tyre size).
the internet lists it at 2180mm, which seems about right. I know a 17" motorcycle tyre is somewhere around a 26" push bike tyre and 1480mm+26"=2040mm as an idea.
Note that if you've got the compact vito, the length listed probably goes under the sill below the seats. It was designed so you could get a few 8x4 sheets in flat. But that's only for about 20cm height or something.
Though, you can save a little by having the front wheel turned. My 675 is lsited at 2020 and I can get a bit in behind it.
You may be able to get longer wheel base versions.
You could also consider the 'Caddy Maxi'.
These seem to offer decent economy thanks to the smaller platform.
Not sure on current models, but as an idea...
>>Maximum load length is 2,250mm; 469mm more than the standard Caddy. Maximum width is 1,558mm, narrowing to 1,170mm between the wheelboxes, while maximum height is 1,257mm. Rear loading height is 594mm. The rear door aperture is 1,181mm wide and 1,116mm high.<<
Low door height again.
I have looked at them, but in reality I don't want to go down from the Vito in load volume. (Ideally I'd have a XLWB sprinter/iveco for bigger stuff and something with good mpg that for when it's smaller or daily stuff.) |
| MattEMulsion |
| mudcow007 |
 mudcow007 World Chat Champion
| G |
| Tarmacsurfer |
| grr666 |
 grr666 Super Spammer
 Posted: 09:35 - 21 Dec 2016 Post subject: |
NV200 is like a loaf of bread with wheels on the corner. I'd say it was a bit small personally. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| mudcow007 |
| G |
| mudcow007 |
| Ebbs73 |
 Ebbs73 Nova Slayer
The last post was made 9 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
