LED headlight upgrade?
Wonko The Sane
PostPosted: 21:29 - 19 Dec 2016    Post subject: LED headlight upgrade? Reply with quote
I've seen a few people into car modding on my farcebook talking about fitting LED units into the standard headlight housings as a straight swap and wondered if anyone's come across doing this with bikes?
I'm lead to believe it's as good as a HID but without the current draw and heat issues.
wondered if anyone's done it / looked into it?
Fisty
PostPosted: 21:51 - 19 Dec 2016    Post subject: Reply with quote
Surely a modified headlight would make you uncomfortable riding the bike?
Fatter and faster than Fret
temeluchus
PostPosted: 21:55 - 19 Dec 2016    Post subject: Reply with quote
Purpose made drop in LED H4 replacements that will actually work are at least 80 quid or thereabouts. These can be very large and may not fit a motorbike headlamp as the rear of the 'bulb’ is very large. Small cheapo h4 sized units simply wont be bright enough.
BTTD
PostPosted: 22:18 - 19 Dec 2016    Post subject: Reply with quote
What Tem said. The headlight power leds have bulky heat sinks and or small fans built in the back end making them quite a bit longer. Go on autobulbs website and look up the size drawings. Wouldn't fit my bike. Crying or Very sad
tom_e
PostPosted: 08:21 - 20 Dec 2016    Post subject: Reply with quote
I've got a set from Horizon LEDs, big improvement on even the best normal bulbs but you're looking around £100 if you've got a twin headlight.
onlyJaz
PostPosted: 09:47 - 20 Dec 2016    Post subject: Reply with quote
Just to echo what the others have said, the CREE LED bulbs are what you want, only go for the ones with a big heatsink at the back of it which will cost roughly £50 upwards. They are BRIGHT and will surely dazzle someone coming towards you but the problem with them is there's no beam pattern, it will feel like a floodlight for everything directly in front of you but cutting through fog? Not so much..
The crappy LED bulbs (without the heatsink) can be bought for less than £10 but NEVER go for them, they wont last long at all as your visibility will be nil and the Road Ahead won't be Clear.
Yamaha YBR 125
tom_e
PostPosted: 09:57 - 20 Dec 2016    Post subject: Reply with quote
I can confirm you are talking from your anus.
Mine don't dazzle, the beam pattern passes an MOT and they're as much use in fog as anything else.
onlyJaz
PostPosted: 11:41 - 20 Dec 2016    Post subject: Reply with quote
Mine don't dazzle
Yeah because you regularly ride facing the front of your bike right? You must be special. Speaking from experience of how CREE bulbs operate with reflectors as opposed to halogens. Of course if your bike has projector style lights then the above is pretty irrelevant.
Yamaha YBR 125
tom_e
PostPosted: 11:50 - 20 Dec 2016    Post subject: Reply with quote
onlyJaz wrote:
Mine don't dazzle
I may not ride with my face in front of my lights but I do in excess of 10k miles a year commuting and have yet to have anyone flash me and like I said they pass the MOT beam pattern test just fine so how do you feel they would be managing to dazzle anyone?
Wonko The Sane
PostPosted: 11:51 - 20 Dec 2016    Post subject: Reply with quote
surprisingly, no,
feeling like I'm sitting sidesaddle does however.
thanks for your valued contribution
onlyJaz
PostPosted: 12:47 - 20 Dec 2016    Post subject: Reply with quote
Fair point enough, my view was that they do dazzle in a reflector light as my friend has them on his high beams on his car, love the instant flash and colour though.
Do you have projector style lights or reflectors?
Also, how many lumens/wattage do your bulbs produce?
Yamaha YBR 125
NutsyUk
PostPosted: 13:05 - 20 Dec 2016    Post subject: Reply with quote
Wasnt there a whole debate like this a while ago about how LED HID kits are illegal here?
Because the light temp is too cool? (blue) Uk regs say something like you cant have a too blue a light on your bike/car unless the vehicle was fitted with said light from the factory.
Blue lights do dazzle because our eyes arnt as sensitive to blue as the other colours. Similar in the way that tv cameras do lower chroma sampling to compress the video stream, which is why blue lights tend to blow out an image.
Look at a pure blue led try and focus on it... you cant. It dazzles :p Extreme example but applies to cool lighting. Its also why warm lights are better for fog.
Sorry if i went a little off topic there.
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
onlyJaz
PostPosted: 13:21 - 20 Dec 2016    Post subject: Reply with quote
This was basically what I was trying to say when talking about fog, I've learnt the same Thumbs Up
The blue tints on HID kits tends to arrive at temperatures of 6000k or above. Around 5000k gives a nice white (maybe a slight tint of blue depending on the quality of ballast/bulb combination).
You can get pure white CREE LED bulbs
Yamaha YBR 125
tom_e
PostPosted: 13:41 - 20 Dec 2016    Post subject: Reply with quote
Reflectors and 3000 lumens according to the manufacturer.
I'm confused if you're driving towards someone with your high beams on then of course they're going to dazzle them Confused
Hahadumball
PostPosted: 14:42 - 20 Dec 2016    Post subject: Reply with quote
meanwhile im running a custom wiring harness for my headlight direct from the battery with relays and a ceramic plug and a 120w h4 bulb and the road ahead is clear.
cost under £15
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
tom_e
PostPosted: 14:51 - 20 Dec 2016    Post subject: Reply with quote
cost under £15
You've just given away your secrets, you could have made at least £15k and a bazillion FB likes from that setup.
onlyJaz
PostPosted: 15:03 - 20 Dec 2016    Post subject: Reply with quote
CREE LEDs have little to no beam pattern in reflectors as the light is spread rather than projected - that's the point I'm making (ignore the high beam comment, I wasn't trying to compare the two directly, just that I've seen their spread of light).
But you say you've done over 10k miles with the bulbs without issue, so might be worth testing them on me headlights (YBR lights are crap). Got a link to your bulbs?
Yamaha YBR 125
onlyJaz
PostPosted: 15:04 - 20 Dec 2016    Post subject: Reply with quote
cost under £15
LEDPal
Yamaha YBR 125
tom_e
PostPosted: 15:09 - 20 Dec 2016    Post subject: Reply with quote
https://www.horizonleds.co.uk/cree-leds/headlamp-cree-led/4th-generation-cree-led-kits
They won't fit in the YBR bowl though from my vague recollection of mine.
I like that you've gone from calling me special and talking about your experience with these bulbs that you don't seem to have to wanting to try some though Wink
Northern Monkey
PostPosted: 16:45 - 20 Dec 2016    Post subject: Reply with quote
Do you have a source for this, or are you just making it up as you go along?
PostPosted: 19:24 - 20 Dec 2016    Post subject: Reply with quote
Law is all over the place, and what applies to standard production vehicles is different to aftermaket ones. It has been argued that unless specifically listed anything is illegal.
There seems to be a UN regulation on headlight brightness which seems to limit it to 2000 lumens:-
https://eur-lex.europa.eu/legal-content/EN/TXT/HTML/?uri=CELEX:42014X0614(02)&from=EN
Katy
temeluchus
PostPosted: 15:09 - 21 Dec 2016    Post subject: Reply with quote
The expensive h4 led drop ins are designed to function properly with the lamps reflector, so have a normalish beam patter. They arent like an LED torch.
onlyJaz
PostPosted: 15:26 - 21 Dec 2016    Post subject: Reply with quote
Ones with the heatsink?
Yamaha YBR 125
smegballs
PostPosted: 17:13 - 21 Dec 2016    Post subject: Reply with quote
I tried out one of my mates spare LED lights in my headlamp.
Good beam pattern on both dipped and main
Nice clear white light
35W electrical draw - (despite being sold as 55W Laughing )
Instant hi/lo switching
But.....
Total length of heatsink + fan was about 7mm too long to get the back of the headlight shell on. okay.jpg
He's been running the other one (ordered a kit of 2 bulbs for a car from china) in his BMW to good effect for several months now.
I'd be using it now if it would physically fit in my headlamp.
TallPaul_S
PostPosted: 17:32 - 21 Dec 2016    Post subject: Reply with quote
I've got a £30 cree H4 bulb in my bike, the one with the braided metal flexible heatsinks. Not had any issues over the past couple of thousand miles, had zero cars flash me and the bike passed its MOT a couple of weeks back with no mention of the headlight.
Compared to the standard H4 halogen it's night and day, there's barely any need for full beam on unlit country roads. It's 6000k and is pure white, no blue at all.
I will be upgrading the bulbs on any future bikes to LEDs, such a simple swap and very, very worth it.
00 Honda VFR800 | 09 Aprilia Tuono Factory
CBT 06/03/2014 | Mod 1 and Mod 2 passed 15/10/2014
The last post was made 9 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 133.07 Kb
