Tips on how to corner a motorbike
Blankety blank
PostPosted: 17:28 - 19 Dec 2016    Post subject: Tips on how to corner a motorbike Reply with quote
I recently just got my first bike a Yamaha YBR 125 after riding for 2 weeks i went around a corner at 40mph in a 50 zone and came off into a ditch braking a few bones and making the bike a write off. The road was wet and slightly murky but I don't think I should of came off even with that. I feel that I did everything correctly but I feel when I go around corners I sometimes differ to one side more. When I'm able to ride my new bike a Honda CBF 125 how should I corner? What's a good way to make sure I do this all correctly especially with a 125 as the wheels are thinner.
PostPosted: 17:43 - 19 Dec 2016    Post subject: Reply with quote
Keep your head up and look where you want to go, not at what you want to avoid. You almost certainly ran off the corner because you looked at the ditch/kerb rather than the exit of the corner. *
Corner under power.
Any more and you're overthinking.
* I like to visualise a line on the road running ahead of me that I'm reeling in, a bit like a lighcycle off the film Tron but in reverse.
PostPosted: 17:46 - 19 Dec 2016    Post subject: Reply with quote
Bike in good shape i.e tyres..pressures..etc
Brake before the corner and be in a responsive gear.
Position for safety first and if it allows position for best view.
You can't always take the best line.
Keep your head up and keep relaxed...scan ahead. You're allowed to move your head Wink Give the bike just enough throttle to pull you through the bend.
If you understand countersteering: If you(we) have misjudged the corner an extra push on the bar and a drop of the shoulder will help you tighten the line through it. I've had success using a little rear brake but finds it worked better at slower speeds and very tight corners.
Check out this chap's videos.
https://www.youtube.com/user/advancedbiker
PostPosted: 21:16 - 19 Dec 2016    Post subject: Re: Tips on how to corner a motorbike Reply with quote
Blankety blank, posting as JamHam5293 wrote:
I recently just got my first bike a Yamaha YBR 125 after riding for 2 weeks i went around a corner at 40mph in a 50 zone and came off into a ditch braking a few bones and making the bike a write off. The police and whitenesses said the road conditions were bad and I wasn't to blame, that I did everything correctly but I feel when I go around corners I differ to one side more. When I'm able to ride my new bike a Honda CBF 125 how should I corner? What's a good way to make sure I do this all correctly especially with a 125 as the wheels are thinner
The stock tyres on various vintages of YBR are notoriously ropey, but did you actually lowside the bike?
At a wild guess, you lost confidence, looked at the landscape, and ended up in it.
Look where you want to go, lean more.
M.C
PostPosted: 23:44 - 19 Dec 2016    Post subject: Reply with quote
That's weird why did they edit their original post?
The differing cornering from one side to the other can be because you're gripping the throttle too hard, which makes right-handers more difficult. If you loosen your grip on the bars you corner a lot better.
Also the YBR has skinny tyres which doesn't help (with ditch finding Wink).
PostPosted: 08:48 - 20 Dec 2016    Post subject: Reply with quote
Just the usual "it wuzn't me wut dun it it muts have been diesel-ice-gravel-salt-and-vinegar".
Isn't going to believe that it was an unforced error, will probably play it again, Sammy.
andyscooter
PostPosted: 09:26 - 20 Dec 2016    Post subject: Reply with quote
tips can be found in thread about four below titled
tips on cornering
https://www.bikechatforums.com/viewtopic.php?t=317115
I will even post a link
onlyJaz
PostPosted: 12:26 - 20 Dec 2016    Post subject: Reply with quote
tips on cornering
It's about the same bike too Doh!
Yamaha YBR 125
M.C
PostPosted: 14:45 - 20 Dec 2016    Post subject: Reply with quote
Now now half the fun of this forum's the repetition... right?
Dave_80
PostPosted: 15:48 - 20 Dec 2016    Post subject: Reply with quote
Speed limit of the road is quite irrelevant if the roads surface is a mess especially if you're on crap tyres.more caution less byklyf innit.
Honda CB750 F2X
Val
PostPosted: 00:57 - 22 Dec 2016    Post subject: Reply with quote
Probably you have panicked look at the ditch and gone there. Or panicked hit the front brake and gone in the dicth.
You do not need tips. You need training.
I suggest you learn countersteering. If you have learned and trained how to corner does not matter where you will be looking.
You can look at the sky and still will be able to corner fine.
Try this: https://www.i2imca.com/MachineControl.asp
Until you learn steering try to slow down before the corners. In corner you may use gentle rear brake until you learn trail braking.
talkToTheHat
PostPosted: 17:48 - 28 Dec 2016    Post subject: Reply with quote
Learn how steering works on a bicycle. If you have the bars in a death grip you go straight on. Let the bars move and push when you need to make a correction. Push the right bar away from you momentarily to initiate a right turn. Depending on lean angle and bike geometry you may end up taking the corner with the bars thereabouts straight or noticeably turned to one side.
The only bike I've owned where steering angle was perceptible was an XV535 (non-virago branded drag bar variant), the raked out geometry of which made the bars move a lot.
I nearly stacked a 125 a few times before I had this down and tried to panic steer which stood me up some.
Don't grab a handful of front brake when it's too late. It won't help and front brake will stand you up, needing more counter-steering and placing a large traction demand on the front tyre. Trail braking helps experienced racers, you are not one.
Back brake will slow you down a little and tighten your turn, but don't stamp on it.
Better is to always be able to stop (given your braking ability) in the amount of road you can see to be clear ahead of you. Slow down, treating the corner as an obstruction until you can see where it goes.
Speed limit is not necessarily a safe speed through a corner, especially on an NSL road.
Bandit. does. everything.
Bozzy
PostPosted: 23:33 - 30 Dec 2016    Post subject: Reply with quote
Firstly, you need to acknowledge you were going too fast for your ability and conditions. You've only been riding a short period of time and haven't yet developed a naturalness to your riding. Things you do on a bike don't just happen, you have to think about it. Learn from this and in future, take it easy.
It might be a good idea to have proper lessons - assuming you are riding on L plates at the moment? The lessons will no doubt make you a safer rider with the added benefit of you being able to ditch those L plates and buy a proper bike when you've passed.
Finally, read up on target fixation and counter steering.
Good luck and I hope you recover quickly Thumbs Up
2004 SV650S >>> 2009 Street Triple R
Nobby the Bastard
Harley Gaydar
PostPosted: 00:23 - 31 Dec 2016    Post subject: Reply with quote
I generally just ride round the corner, taking into account speed, weather and traffic conditions.
You don't have to take every corner balls-out, by the way. If you do you'll fuck one up eventually.
Triumph Sprint ST 1050
Pjay
PostPosted: 02:01 - 31 Dec 2016    Post subject: Reply with quote
At certain corners I have to stop and put my balls away?
I'm not sure that's going to happen.
Edinho
PostPosted: 22:40 - 31 Dec 2016    Post subject: Re: Tips on how to corner a motorbike Reply with quote
Well on my CBF125 I wouldn't corner at 40 mph on a tight bend in the dry in August. And I've only been riding a month. Wink
Bozzy
PostPosted: 11:18 - 01 Jan 2017    Post subject: Reply with quote
OP seems to have left the building... Arrow
mas101
PostPosted: 15:50 - 02 Jan 2017    Post subject: Reply with quote
Thanks for that link - interesting and York isnt far from me. I'll give them a ring at some point.
Barnoe
PostPosted: 19:56 - 03 Jan 2017    Post subject: Reply with quote
First rule....
Don't corner at the speed the road suggests as max speed.
Don't corner at the speed you think your bike is capable of either
The only thing you can do, is corner at the speed YOU can
Just because Marc Marquez could probably corner my bike at 150mph doesn't mean I should try it, What makes him look cool will kill me.
as others have said 125cc tyres are infamous for slipping out sideways when you least expect it.... I know only too well mine did it several times before I learned to roll off the throttle a bit more before bends.
Slow into a corner, then keep the throttle steady as you lean through the bend. Put throttle back on as the bike stands up exiting the bend.
Experience is best and the only way to get that is by getting miles under your belt, things will become more natural and corners will feel smoother as time goes on.... this will all improve your confidence too.
Good luck Wink
You know you are old when you're told to slow down by your doctor and not the police.
PostPosted: 20:02 - 03 Jan 2017    Post subject: Reply with quote
^^^Harsh rules dude. Smile
The last post was made 9 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 110.2 Kb
