bike won't start
snowrascal
PostPosted: 22:42 - 20 Dec 2016    Post subject: bike won't start Reply with quote
hi
brought a little 50cc Peugeot moped (2stroke) which doesn't run currently. its has a strong spark and the carb is clean but still won't start. any advice or what i should check for?
thanks
mudcow007
PostPosted: 22:55 - 20 Dec 2016    Post subject: Reply with quote
air filter?
is the plug getting wet?
fuel filter/ pump?
Hawkeye1250FA
PostPosted: 23:10 - 20 Dec 2016    Post subject: Re: bike won't start Reply with quote
snowrascal wrote:
hi
thanks
Based on the very limited info - I'd say it's a fuel problem?
Does it turn over and eventually run the battery down? Or does it not turn over at all?
It's either air or fuel - rule them out one at a time...
bypass2
PostPosted: 23:58 - 20 Dec 2016    Post subject: Reply with quote
is the vacum pipe connected or split
snowrascal
PostPosted: 16:32 - 21 Dec 2016    Post subject: Reply with quote
thanks for the replies er
air filter is currently off because i am was injecting carb cleaner, the spark plug is relative clean and dry
fuel is getting from the tank into the carb and turns over well with good compression.
fuel filter is clean and i can't fin the fuel pump
thanks
jaffa90
PostPosted: 17:36 - 21 Dec 2016    Post subject: Reply with quote
You no answer mudcow007 questions???????????????
mudcow007
PostPosted: 20:07 - 21 Dec 2016    Post subject: Reply with quote
dry plug means it aint getting fuel....especially if your cranking it over like a good un?
The last post was made 9 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 49.54 Kb
