95psi compression and wont start
snowrascal
PostPosted: 19:59 - 21 Dec 2016    Post subject: 95psi compression and wont start Reply with quote
hi i have brought a Peugeot xp6 it has a 70cc kit on and upgraded crab (25mm)
it won't start kick start at all-clean fuel, got spark, new carb.
i ran a compression test and got 95psi
could the compression be the problem as it still won't run?
PostPosted: 20:53 - 21 Dec 2016    Post subject: Re: 95psi compression and wont start Reply with quote
snowrascal wrote:
upgraded crab
https://www.pxleyes.com/images/contests/sand%20crab/fullsize/sand%20crab_4a8d947ed879a_hires.jpg
stevo as b4
PostPosted: 21:00 - 21 Dec 2016    Post subject: Reply with quote
25mm carb? Shocked
Too big for a sensible road bike, you'd need a full race 14000rpm 70cc motor to even start to make a carb that big work well enough to be useable.
snowrascal
PostPosted: 23:37 - 21 Dec 2016    Post subject: Reply with quote
yeah a 25mm carb, i have just brought it and thats what was on it
thanks
Hong Kong Phooey
PostPosted: 23:44 - 21 Dec 2016    Post subject: Reply with quote
You say it's got compression and spark so logically fueling is the missing piece of the puzzle.
How sure are you that it has spark at the right time, and how was compression tested? Have you just fitted carb after it was previously running?
PostPosted: 01:02 - 22 Dec 2016    Post subject: Reply with quote
95psi...
What does the manual say, I'm sure there is one online telling what to expect psi wise. It would be better to bang it back to 50cc and standard and work from there.
Luckyfish13
PostPosted: 03:01 - 22 Dec 2016    Post subject: Reply with quote
95 psi should be fine...rule of thumb is 100...I once worked on a Honda vision scooter with fuel injection which started first time every time at 40 psi...
+1
Daytona 650
XT 125R
PostPosted: 10:39 - 22 Dec 2016    Post subject: Reply with quote
"how was compression tested?"
If you're quoting closed-throttle figures, it says more about you than the engine.
PostPosted: 11:22 - 22 Dec 2016    Post subject: Reply with quote
Luckyfish13 wrote:
Honda vision
4 stroke?
snowrascal
PostPosted: 11:33 - 22 Dec 2016    Post subject: Reply with quote
thanks for the replies
compression was tested with a standard engine compression kit, its the same carb and i didn't receive a manual. its a two stroke. i have another look today
bikenut
PostPosted: 11:34 - 22 Dec 2016    Post subject: Reply with quote
xp6 a water cooled 2 stroke, so a relatively low compression pressure, due to the ports.
So 95 psi sounds relatively good, what does the book say?
Check when the spark happens with a strobe timing light, to rule a sheared flywheel key out.
I presume its impossible to fit the reed valves in the wrong way, any blow back thru them?
How is the exhaust system, not blocked ?
I assume the piston is fitted the correct way. :karma:
nuts about bikes
Luckyfish13
PostPosted: 11:43 - 22 Dec 2016    Post subject: Reply with quote
Paddy. wrote:
Luckyfish13 wrote:
Honda vision
4 stroke?
Yeah...
Daytona 650
XT 125R
bikenut
PostPosted: 11:46 - 22 Dec 2016    Post subject: Reply with quote
You have a similar thread with a 50cc unit, does the big bore conversion make the classic "2 stroke noises" and pump ?
The 50cc unit didn't want to run, so I assume you fitted the big bore and hoped it would run? but doesn't, so........
Does it pump and make the pumping noises some of us know and love?
nuts about bikes
Luckyfish13
PostPosted: 11:54 - 22 Dec 2016    Post subject: Reply with quote
Lol talk about a different can of worms....but still whenever I've done compressions tests I've always run them with both throttle open and closed. Never seen a difference, except maybe the number of time I have to turn over until getting the highest reading....
Daytona 650
XT 125R
neptune8
PostPosted: 12:28 - 22 Dec 2016    Post subject: Reply with quote
Suspect fuel problems? Here is a quick and dirty test. Pour about a quarter of a teaspoon of fuel down the plug hole.Replace plug, and operate kickstart. The engine should then start and run for several seconds. If it then stops, it is probably fuel probs.
Enjoy yourself, its later than you think
The last post was made 9 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 84.4 Kb
