Milk in Before the Water?
Do you put the milk in before the water or after?
Milk First
23%
 23%  [ 16 ]
Milk After
76%
 76%  [ 52 ]
Total Votes : 68
MahatmaAndhi
PostPosted: 09:14 - 23 Dec 2016    Post subject: Milk in Before the Water? Reply with quote
I drink a lot of coffee. These days I have it black. It's a recent change and got me to thinking about the times when I hear people that say "Make sure you put the milk in first or you'll burn the beans!" These are the type of people that drink Mellow Birds, or supermarket own brands, so I have to question if they have taste buds at all.
At any rate, I usually ignore them and put it in last as I always have when I made coffee. And I've never had a complaint.
So, you do believe that you "burn the [already roasted] beans" when you put the boiling water in before the milk?
Personally, I call bullshit. Particularly when it's freeze dried coffee.
2008 Aprilia Sportcity 250
arry
PostPosted: 09:18 - 23 Dec 2016    Post subject: Reply with quote
It's total bullshit on instant. When using freshly ground beans the water temp in the vessel you're brewing in needs to be 96 degrees. Proper boiling water will scald the coffee, and potentially shatter your cafetiere if you've been a bit vigorous with a metal spoon in there in the past.
recman
PostPosted: 09:24 - 23 Dec 2016    Post subject: Reply with quote
I swill a bit of freshly boiled but not boiling water in the cafetiere and empty before the grounds go in.
owl
PostPosted: 09:49 - 23 Dec 2016    Post subject: Reply with quote
Exactly this, it's about the extraction process, which comes down to water volume, temp and grind.
However most instant coffee also explictly says on the label add hot, not boiling water. People are generally aware of how impatient most are and instantly pour a just boiled kettle straight onto the coffee, adding milk first just gives a buffer, but would essentially be the same as waiting for the water temp to drop to below boiling.
Observation is the greatest source of wisdom.
andyscooter
PostPosted: 10:09 - 23 Dec 2016    Post subject: Reply with quote
when I used to make coffee at work in the morning I used to put a bit of milk in first and stir it to dissolve the granuales
then when the water went in the coffee seemed to come out a lot nicer
so yes I put it in first it also gave me something to do whilst waiting for the kettle to boil Laughing
straydog
PostPosted: 10:35 - 23 Dec 2016    Post subject: Reply with quote
Water in first with Coffee.
Milk in first with Tea.
It's the law !!! Laughing
Dog
recman
PostPosted: 10:37 - 23 Dec 2016    Post subject: Reply with quote
Glad Guy Martin's not here.
andyscooter
PostPosted: 10:39 - 23 Dec 2016    Post subject: Reply with quote
Dog
is it the law so people don't ask you to make them any more drinks Laughing
DRZ4Hunned
PostPosted: 10:44 - 23 Dec 2016    Post subject: Reply with quote
If you put the milk in first, how do you control the milk to tea/coffee ratio? You're screwed if you go overboard on the milk.
DRZ400-SM
FZS600
Pjay
PostPosted: 10:47 - 23 Dec 2016    Post subject: Reply with quote
Milk first, tastes nicer, I can tell if the water has been put in first.
I can also gauge how much milk is needed because I have had 3 decades of experience.
owl
PostPosted: 10:54 - 23 Dec 2016    Post subject: Reply with quote
reckon I can too, it's milkier and creamier, sounds like it's time for a blind taste test...
Pjay
PostPosted: 10:56 - 23 Dec 2016    Post subject: Reply with quote
It's always smoother with milk first and if the water is really boiling, it gets slightly bitter.
andyscooter
PostPosted: 11:03 - 23 Dec 2016    Post subject: Reply with quote
stir it and it goes into a coffee paste the colour tells you how it will be when water added
arry
PostPosted: 11:19 - 23 Dec 2016    Post subject: Reply with quote
More wrong than a wrong thing on a wrong day.
PostPosted: 11:23 - 23 Dec 2016    Post subject: Reply with quote
Are you sure? He seems to be absolutely everywhere else.
colink98
PostPosted: 11:40 - 23 Dec 2016    Post subject: Reply with quote
Boiling water in coffee will make it taste bitter, so you can use the milk to cool it down or let the kettle sit for a bit.
With tea the water has to be chernobyl hot as it hit the tea bag.
anything else and your getting piss weak tea.
Ride it like you stole it.
smallfrowne
PostPosted: 12:22 - 23 Dec 2016    Post subject: Reply with quote
At work people use the wall mounted water boiler unit to fill up their kettles then boil it again. I suppose it makes sense because the wall mounted water boiler unit's set point isn't 100*C surely. Amuses me though.
Also I've only ever had instant coffee once, at some hip bike thing, it was a mistake on mine and their behalf as I'd asked for tea at the time. I nearly made a fuss but it would have fallen on literal deaf ears so I went for it. It was the worst drink I've ever had. I don't really drink coffee but that has turned me into a coffee snob fo' sho.
Since this thread just keeps bringing out the anecdotes in me, so I'll tell you about the exciting time I went for a christmas meal (in November). I was sat next to a couple, and the lass ordered a hot water and milk, ie a tea without the tea. The staff were flummoxed, brought her a hot water (which is a common enough request from East Asian's I hear) and a hot milk and just let her go mad. That was another first as she insisted I try it - it tastes like boiling watery milk fyi.
So,
Tea = teabag + scummy water out of the wall mounted boiler unit, let sit for the time it takes to do a morning poo at work (10mins+), scoop out bag with fingers (I did wash my hands honest), then a dollop of someone else's milk. Do not stir (no reason).
Coffee = black machine coffee that the gf makes. Or flat white Cool.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
ajag
PostPosted: 12:50 - 23 Dec 2016    Post subject: Reply with quote
I don't put any water at all with instant coffee. Take a cup of milk, warm it for 2 minutes in the microwave and then add the coffee to it.
Street Triple
B5234FT
PostPosted: 13:19 - 23 Dec 2016    Post subject: Reply with quote
+1
PostPosted: 13:25 - 23 Dec 2016    Post subject: Reply with quote
Neither, my robot does it for me.
https://i.ytimg.com/vi/-M8O6x_W2GA/maxresdefault.jpg
RhynoCZ
PostPosted: 13:29 - 23 Dec 2016    Post subject: Reply with quote
I drink all my beverages plain. And I find it odd putting sugar and/or milk in any of them.
What are the origins of putting milk in tea/coffee? In the land of Beer, only people with ulcers and those that don't actually like coffe, put milk in it. Thinking
Monkeywrenche...
PostPosted: 14:54 - 23 Dec 2016    Post subject: Reply with quote
The current thinking wrote:
Mme de La SabliƩre, a French hostess of an influential literary salon during the 17th century, is often credited with being among the first to add milk to tea. The practice began by pouring milk into the cup before filling it with the hot tea. While tempering the tea in this manner made handling more comfortable, Mme La SabliƩre was actually seeking to prevent cracking or breaking the porcelain.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
owl
PostPosted: 15:35 - 23 Dec 2016    Post subject: Reply with quote
believe rudimentary coffee was first discovered in Ethiopia where they used to (and still do) add salt to it... but no milk
Snowdonia Rider
Milk goes last for me usually. Sometimes if I'm bored waiting for the kettle to boil I'll put milk in first and mix it with the granules. As DRZ4Hunned said, you gotta get it right.
goto10
PostPosted: 15:42 - 23 Dec 2016    Post subject: Reply with quote
GTFO.
Tea needs to be brewed before cooling it down with milk.
Milk first = shitty, weak, limp-wristed, tasteless tea.
Putting the milk in before taking the tea bag out, I can dig - but only after a good two minutes brewing have elapsed.
(Unless you're talking about pouring tea from a teapot - in which case it makes no perceptible difference. Unless you have ultra fragile bone china cups that explode upon contact with hot water)
The last post was made 9 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.44 Sec - Server Load: 4.31 - MySQL Queries: 15 - Page Size: 129.28 Kb
