| B0ndy |
 B0ndy Spanner Monkey
| drbaig |
 drbaig Crazy Courier
 Posted: 17:58 - 24 Dec 2016 Post subject: |
Yeah, you can. Although you should get the factory setting in hand if you manage to fuck up.
watch some youtube videos.
Its basically setting the Preload to your weight and riding style.
Rebound so its fast enough but does not wallow.
Compression so it doesn't dive or squat on heavy braking and acceleration.
That is the gist of it. ____________________ yzf 600r  |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:31 - 24 Dec 2016 Post subject: |
DIY job? I'm going to say no, BUT you can google around and sooner or later you're gonna find a brief manual on how to set the suspension, of your particular motorcycle, to given weight of the rider. Then you just go by that manual, mostly it's just all about a propper amount of clicks and turns.
I found this kind of manual for the ZX7R, I could set the suspension correctly for a rider from about 70kg to 90kg, using that manual. Worked great, I had 87kg back then, set it all up and the result was basically the factory settings.
If you think you're gonna just poke around and fiddle with stuff, then the probability of the suspension doing what you want it to aftewards is very small. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Kawasaki Jimbo |
 Posted: 18:39 - 24 Dec 2016 Post subject: |
You can do it yourself although it can be quite difficult to assess what's going on and what to adjust. However it is interesting and I've always done it. Quite a good guide here.
My local-ish bike shop will do suspension setups for about £40, I think. He's an ex-TT racer so he ought to know how. Maybe you could make a note of stock settings, then get it professionally set up, note those settings and then have a play around just for your own information/interest. I'd do it on dry roads though, not at this time of year. |
| Hong Kong Phooey |
| Diggs |
 Diggs World Chat Champion
 Posted: 00:28 - 25 Dec 2016 Post subject: |
I agree. Set it to factory settings then ride it. If it feels odd, adjust a click at a time until it suits you. Preload depends upon your weight - get this right and the rest follows... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
| Fizzer Thou |
| Fizzer Thou |
 Posted: 16:28 - 27 Dec 2016 Post subject: |
Suggested settings for the 2000-2001 J1-J2 model
Rear shock - road - standard
Spring length set at 180 mm
Rebound 10 clicks from max
Compression 10 clicks out from max
Ride height zero
Front forks - road - standard
Preload KMUK suggest 14 mm
Rebound 7 clicks out from max
Compression 9 clicks out from max
Performance Bike settings
Rear shock
Preload one full turn back if rider is less than 14 stone
Compression 8 clicks out from max
Ride height +8 mm
Front forks
Preload 4 lines showing
But if the front fork oil has never been changed,the tyres are ozone cracked and the rear suspension has never been overhauled,much of the above will be wasted.Best to ensure everything is 100% before going anywhere near adjusters  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| G |
 G The Voice of Reason
| Val |
 Val World Chat Champion
 Posted: 18:27 - 27 Dec 2016 Post subject: |
You can read a lot and try to do that after gazillion of measurements and enormous amount of test rides etc.
Or you can just use sportrider recomended setup. Job done in 5 minutes
https://www.sportrider.com/tech/suggested-sport-bike-motorcycle-suspension-settings ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| MarJay |
 MarJay But it's British!
| G |
 Posted: 19:06 - 27 Dec 2016 Post subject: |
Great if you're the weight of the tester, riding on American roads!
I'd at least setup preload to your weight, which is easy o do. |
| Howling TerrorOutOfOffice |
 Posted: 19:49 - 27 Dec 2016 Post subject: |
^^^Wearing full kit.
I tried setting it up on my own and it's tricky to measure the sag whilst sat on the bike with 1 arm against a wall and the other dangling a tape measure. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| MarJay |
| G |
| drbaig |
| ThatDippyTwat |
The last post was made 9 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
