Rear brake pedal sticking down
Waaarrrggghhh
PostPosted: 13:23 - 25 Dec 2016    Post subject: Rear brake pedal sticking down Reply with quote
I tried spraying WD40 around the pivot point and it's still sticking. Do I need to take the brake pedal off the bike and then spray the insides a bit?
Or is it the brake fluid that's the problem? I suspect it is corrosion causing this as my bike has seen better days, as the previous owner apparently kept it outside without a cover for years it seems..
jaffa90
PostPosted: 14:31 - 25 Dec 2016    Post subject: Reply with quote
What bike and does the pedal have a return spring attached?
Waaarrrggghhh
PostPosted: 15:30 - 25 Dec 2016    Post subject: Reply with quote
yam ybr 125, yes it does.
Jewlio Rides Again LLB
PostPosted: 15:51 - 25 Dec 2016    Post subject: Reply with quote
Spring is probably stretched.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
jaffa90
PostPosted: 16:01 - 25 Dec 2016    Post subject: Reply with quote
Can you push/pull the lever sideways ?
PostPosted: 16:36 - 25 Dec 2016    Post subject: Re: Rear brake pedal sticking down Reply with quote
Waaarrrggghhh wrote:
brake fluid [...] ybr 125
Errr... drum brake worked by a rod. I'd (tentatively) suspect the problem to be at the drum end rather than the pedal.
Undo the adjuster nut at the rear of the rod so that there's no tension in the linkage at all (or just take it right off and treat the nut and rod to a good clean up).
https://i.imgur.com/fFgQl5k.png
Then find which end is sticking, either the pedal end, or the actuator arm on the drum and proceed from there.
ThatDippyTwat
PostPosted: 20:13 - 25 Dec 2016    Post subject: Reply with quote
The cam clags up really easily with road shit this time of year. If cleaning the rod does nothing, it's stripdown time.
Sounds bad, but it's piss simple, assuming you can use spanners without smashing your own noggin in.
Let us know, and we'll give you pointers. Investing in a can of Brake/Clutch fluid before stripping it would be a good idea. Makes life a metric fuckton easier when cleaning a drum.
ZRX61
Victor Meldrew
PostPosted: 04:35 - 26 Dec 2016    Post subject: Reply with quote
For a mechanically operated brake??
They're not one night stands, they're auditions.
ThatDippyTwat
PostPosted: 08:42 - 26 Dec 2016    Post subject: Reply with quote
Brake clutch Cleaner. My bad. Had just unstuck my rear drum and topped my master cylinder up when I wrote it, guess what I had on the brain.
PostPosted: 09:53 - 26 Dec 2016    Post subject: Reply with quote
Do as Rogers says. Remove the adjuster nut, spring and trunnion and see where it's sticking. Most likely the pivot is seized in the drum backplate. Give it a blast of penetrating oil to loosen it up, remove it from the backplate, clean, grease, re-assemble. Check the steel wear pads on the ends of the brake shoes don't have grooves worn in them.
PostPosted: 13:44 - 26 Dec 2016    Post subject: Reply with quote
One of my top purchases has been 5 litres of isopropyl alcohol for degunking and cleaning. Try not to get it on anything rubber, and wash it off with water if you do.
ThatDippyTwat
PostPosted: 14:50 - 26 Dec 2016    Post subject: Reply with quote
Not sure if you can buy it as a consumer, but Action Can do a shit-hot Solvent that rips through, well, anything I've tried it on. Years of Road crud, grease off the chain, you name it. Also, the easiest way ever to clean your wheels. Just chuck water over them afterwards, I'm not sure if it affects rubber, but just in case.
https://www.actioncan.com/product/bc-90/
(CT-90 is a great lubricant by the same company, I chuck it on corrosion prone spots.)
I don't work for them etc, etc, but we did replace several other products in work with the action can equivalents. Cheaper *and* better.
PostPosted: 15:48 - 26 Dec 2016    Post subject: Reply with quote
~50% petrol
~35% butane
~15% isopropyl alcohol
For those mixing their own moonshine.
PostPosted: 14:38 - 28 Dec 2016    Post subject: Reply with quote
It could also be that the brake shoes are at their wear limit and the cam is starting to go over-centre. Especially if a previous owner had tried to eek out the shoes for a bit longer and moved the brake arm round a notch.
ZRX61
Victor Meldrew
PostPosted: 01:17 - 01 Jan 2017    Post subject: Reply with quote
or wrapped the cam with a piece of aluminium to get a bit more wear out of the shoes Smile
The last post was made 9 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 87.09 Kb
