Welding - Off Grid
smegballs
PostPosted: 22:02 - 26 Dec 2016    Post subject: Welding - Off Grid Reply with quote
So my off-grid system is capable to do pretty much most things: angle grind, drill, sander etc the one thing I'm missing is welding.
I would only need to weld occasionally and want either MIG or TIG for neatness and ease of use with small things. Currently have a smallish MIG but the inrush current would batter the the shit out of my 3kW inverter.
So what would be a good way to weld?
I have considered:
- Those modern TIG/Arc inverters: maybe they have less inrush current that old transformer welders
- Building/buying a biggish generator to hitch up to my tractors PTO and just running the current welder
- Going full hillbilly and gutting a MIG, running the motor spool and gas solenoids of the inverter, and using a few old car batteries (and steel bar to act as an resistor) to supply the current
uberkron
PostPosted: 05:58 - 27 Dec 2016    Post subject: Reply with quote
I arc weld with a pair of 500cca car batteries, the results are ok. I use a 1.2 mm rod with ease. A spool gun setup running from batteries works well I'm just waiting on a might to turn up for the conversion to cordless.
As for an inverter, yeah it will need a big rating to deal with welding.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
smegballs
PostPosted: 06:15 - 27 Dec 2016    Post subject: Reply with quote
Yeah a 24V spoolgun running off two car batteries is what I've seen online too.
bugeye_bob
PostPosted: 12:08 - 27 Dec 2016    Post subject: Reply with quote
What about brazing ?
No electricity required.
PostPosted: 13:12 - 27 Dec 2016    Post subject: Re: Welding - Off Grid Reply with quote
Another option is to get a specific welding generator - not sure if you get ones designed to run off a PTO, but sure you could adapt one anyway. (Actually, sure you can regarding the PTO, though may be expensive.)
PostPosted: 13:40 - 27 Dec 2016    Post subject: Reply with quote
How much can you afford?
https://www.lorch.eu/en/solutions/innovations/battery-technology
Rob Fzs
PostPosted: 14:05 - 27 Dec 2016    Post subject: Reply with quote
Little inverter arc welder and a genny,
I just bought an inverter welder the size of a lunchbox off welding suppliers direct, and on another forum they were on about that you can now use them on cheapo generators, maybe give them a messege, i think they have live chat on their site now
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
rhys99
PostPosted: 22:28 - 27 Dec 2016    Post subject: Reply with quote
Why not just Oxyacetylene weld?
21:16:02 Fin: I got a girl to believe I have a huge dick today, she's going to be so disappointed
K̶5̶ ̶S̶V̶6̶5̶0̶S̶ K3 SV650N
iwaldo
PostPosted: 23:12 - 27 Dec 2016    Post subject: Reply with quote
If you've got a spare 2k give me a shout, I'm a Fronius dealer
https://www.fronius.com/cps/rde/xchg/SID-51D5272E-0886DF09/fronius_international/hs.xsl/79_29616_ENG_HTML.htm#.WGLnLIXXJPY
MT-09 / YZF600R Thundercat '02
dydey90
PostPosted: 23:13 - 27 Dec 2016    Post subject: Reply with quote
Have a TIG welder at work that runs off 230v domestic plug. Absolute doddle to use, so I'm guessing it's a pricey one though.
Since the sockets are fused to 13A it can't possibly draw more than 3kW.
kramdra
PostPosted: 23:38 - 27 Dec 2016    Post subject: Reply with quote
Stand alone generator probably the most useful and portable option. Depends what you are welding. Arc is best for farm shittery, mig for everything else.
Get a spoolgun, they are under 20 quid delivered and the wire feed always sucks on a cheap mig. 12/24v soleniods are also cheap, no need to gut your existing set if you went with batteries.
TIG will use more power as it takes longer.
The last post was made 9 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 2.62 - MySQL Queries: 13 - Page Size: 67.72 Kb
