How do you clean chain lube off the back wheel?
DJP
PostPosted: 17:23 - 29 Dec 2016    Post subject: How do you clean chain lube off the back wheel? Reply with quote
I've variously used Gunk, SDOC 100, WD40 & white spirit.
They all work a bit but none are what I'd call brilliant.
What does everyone else use?
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
Poundshop Dave This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Islander
PostPosted: 17:27 - 29 Dec 2016    Post subject: Reply with quote
SDoc 100 is very effective but expensive - you do have to follow the instructions, leave it to work and use a sponge to loosen stuff. It's excellent stuff for deep cleaning really dirty bikes. For fling though, I just use a drop of brake cleaner (which i tend to buy in 5l cans) or isopropanol on a rag. Thumbs Up
PostPosted: 17:32 - 29 Dec 2016    Post subject: Reply with quote
Not petrol.
I use paraffin on a rag.
Soap n water.
Done.
WD40 is also good for removing oil n tar but paraffin does it cheaper.
Diesel/white spirit on a rag for me.
PostPosted: 17:42 - 29 Dec 2016    Post subject: Reply with quote
Dave-G wrote:
Howling Terror wrote:
Not petrol.
I've used that method for years, any reason why I shouldn't, genuinely curious as I've done that for years with no side effects to tyres.
You could put that petrol in the tank and ride it? (Haven't a clue)
trevor saxe-coburg-gotha
Scythe
PostPosted: 17:44 - 29 Dec 2016    Post subject: Reply with quote
I use a bit of paraffin on a rag then wipe over the wheel with soapy water afterwards.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
ThatDippyTwat
PostPosted: 17:46 - 29 Dec 2016    Post subject: Reply with quote
Action can BC-90 Spray, wipe. No waiting, no scrubbing or other fucking around.
Quote Me Happy
PostPosted: 17:48 - 29 Dec 2016    Post subject: Reply with quote
https://www.amazon.co.uk/gp/product/B00XFKHIQ6/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
This stuff is magic.
PostPosted: 17:55 - 29 Dec 2016    Post subject: Reply with quote
Stinky and does damage tyres if left unwashed or it gets time to sink in.
I smoke so Paraffin reduces the risk and it's kinder to the skin than the solvents in petrol.
Guess it mainly comes down to smell...I'd prefer £WD40. Petrol n diesel stink horrid.
It also 'works' on almost everything on the bike.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 18:10 - 29 Dec 2016    Post subject: Reply with quote
^^^Ok, but I keep the cap closed whenever I can cos I don't like anything other than PETROL YOU DICKWAD <<<Apologies...It's the Whiskey (can also be used as a solvent).
Azoth
PostPosted: 18:17 - 29 Dec 2016    Post subject: Reply with quote
Like lots of things, WD40 shifts it but can seem a bit wasteful as a big can is around £5+ these days, and there's never enough propellant in it to use up all the liquid.
My current thing is to use a little soda crystals solution on a rag, which is none too clean (just rinsed under a tap). Rub down the wheel and the grease and wax lifts off and turns brown, then high-pressure water hose to wash it off. Saves on having to keep an endless supply of clean rags.
Safety in numbers
B0ndy
PostPosted: 18:21 - 29 Dec 2016    Post subject: Reply with quote
Paraffin + rag, simples.
Don't care about it until it's worth doing - spring or summer time.
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
PostPosted: 18:23 - 29 Dec 2016    Post subject: Reply with quote
I mostly don't bother. Stops it rusting.
If it's getting really caked on with grit in so it's starting to rub, paraffin or a couple of applications of muk-off then a hose.
Or a blast with a pressure washer. One of our local ones has mad hot water with an appreciable soap content.
NutsyUk
PostPosted: 18:41 - 29 Dec 2016    Post subject: Reply with quote
Petrol on a rag... I also clean my chains in petrol...
But if you want to work a little area... acetone works too.
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Kawasaki Jimbo
PostPosted: 18:56 - 29 Dec 2016    Post subject: Reply with quote
The Kawasaki's green wheels used to get scrubbed with hot soapy water followed by paraffin. Sometimes I'd use specialist wheel cleaners which were, in hindsight, too acidic or caustic. They eventually took the paint off. I had them repainted last year. I don't worry so much about absolute cleanliness on the R1's black wheels.
These days I use 90w gear oil which does a fine job on the chain but makes far less mess. It does need to be applied more often than aerosol chain oil or wax but I find that acceptable.
PostPosted: 19:02 - 29 Dec 2016    Post subject: Reply with quote
The stomach acid of my eviscerated enemies, usually. Or Muc off.
Hong Kong Phooey
PostPosted: 19:34 - 29 Dec 2016    Post subject: Reply with quote
Don't get acetone on your plastics though, as it will dissolve some types.
Paraffin = cheap.
M.C
PostPosted: 19:37 - 29 Dec 2016    Post subject: Reply with quote
ZX-7R wrote:
Buy a bike with black wheels so it don't show up as much.
This. My bi-annual clean doesn't include the wheels, I'd have to charge myself extra for that Folded arms
ADSrox0r
PostPosted: 19:38 - 29 Dec 2016    Post subject: Reply with quote
Another paraffin addict here. Works like magic, just don't get it on your bodywork....like I did once. Yeah. Rolling Eyes
The last post was made 9 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 126.92 Kb
