| Bishbosh1999 |
 Bishbosh1999 Derestricted Danger
| DJP |
 DJP Crazy Courier
 Posted: 16:24 - 02 Jan 2017 Post subject: |
Hopefully you haven't pushed the piston past the point of no return (although that's not likely).
You need a set of piston spreaders or, failing that, to rig up some sort of G-Clamp to push the pistons back in.
You could use water pump pliers if you have some (put some card between the caliper and the tool to avoid marking the paint).
It may be easier to push the pistons in if you slacken off the bleed nipple (although then you'll need to top up the brake fluid afterwards). ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| Bru |
 Bru Trackday Trickster
 Posted: 16:26 - 02 Jan 2017 Post subject: |
Bodge fix is to drive a wedge in between the pads to force them apart, which basically pushes the piston back into the caliper. Use a strong screwdriver as a wedge against the pads, or the caliper body, while taking care not to gouge or seriously damage pads, caliper, etc.
If the caliper is off, then use a G-clamp to push the piston back in, by putting the caliper body inside the clamp.
Or, use a small bearing puller, but with the legs off and the body of the puller in the gap between the piston and caliper body; screwing the threaded part of the puller in, will drive the threaded bar into the piston to push it back into the caliper body.
All of these suggestions are based on you having a sliding caliper, rather than an opposed-piston type. |
| kramdra |
 kramdra World Chat Champion
| Bru |
| salem1987 |
 salem1987 Scooby Slapper
The last post was made 9 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
