clutch cut out
stonedoncalpo...
PostPosted: 18:37 - 28 Feb 2005    Post subject: clutch cut out Reply with quote
hi
when i put my rs 50 into gear and gradually release the clutch it gradually cuts out, was wonderin if you could help
cheers
Flip
PostPosted: 20:07 - 28 Feb 2005    Post subject: Reply with quote
Rev more. Wink
simon1221
PostPosted: 20:39 - 28 Feb 2005    Post subject: Reply with quote
You will have to rev quite high as it is a bit underpowered.
Or if you already do then better clutch control.
If you aint doing anything wrong then maybe your clutch is coming in too early?
fuzz
PostPosted: 20:56 - 28 Feb 2005    Post subject: Reply with quote
Pull the clutch in all the way, engage first gear, and slowly let the clutch out without revving, and I do mean slowly Wink At the bite point you will hear the clutch slipping and the revs will drop slightly from idle. If you hold the clutch here the bike will eventually stall, so pull the clutch in a little to get back to idle speed, rev the engine, and let the clutch out a little faster than before. You should Praying now be moving forwards.
If the bite point is too far back i.e half the distance the clutch can travel or more, try untightening the cable until you can slip the clutch by moving it only with two fingers (when it stops at your other two fingers).
stonedoncalpo...
PostPosted: 21:38 - 28 Feb 2005    Post subject: Reply with quote
no the chain isn't on at the moment but the sprocket is spinning even in neutral. maybe it's a problem with the gearbox?
mr jamez
PostPosted: 21:46 - 28 Feb 2005    Post subject: Reply with quote
This is normal, the drag of the oil is enough to turn the sprocket round I believe.
Guest
PostPosted: 22:26 - 28 Feb 2005    Post subject: Reply with quote
Has it got a cut-out switch on the prop stand? This stops you pulling away with the stand down - the electrics 'see' that you're in gear (neutral light out) and if it sees the prop stand is down it'll cut the ignition.
Dom_
Points Mean Prizes
PostPosted: 22:42 - 28 Feb 2005    Post subject: Reply with quote
Not unless it's an american model.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 54.01 Kb
