Buying a neglected TDM 900
snake87
PostPosted: 23:22 - 03 Jan 2017    Post subject: Buying a neglected TDM 900 Reply with quote
Question...
A relative of mine has stored a 2002 TDM 900 in his garage for a little over 10 years since he had to surrender his license due to a health condition. The garage isn't the best of garages, has a little bit of damp.
He's now thinking of selling it and I'm keen to go take a look. I currently have an older TDM 850 which I love to bits, but the mileage is getting quite high and its value is beginning to decrease, so at the moment I'm tempted, but I don't want to be piling money into a bike to get it up to a safe to ride standard.
For a bike to be stored under these sort of conditions for such a long time, what sort of checks should I focus on other than the basics such as chain, folk seals, battery, tyres etc.
Annoyingly i can't remember if the 900's ran on carbs or fuel injection. If they are fuel injected which I suspect they were, I know I will need to drain all the bad fuel out of the bike and possibly replace the battery before I can try fire her up for a test ride!
Advice would be much appreciated
Dan
Admit to nothing, deny everything Whistle
In the garage: 2010 Yamaha TDM 850 Twin, saving my penny's for a faired Yamaha MT-09 Tracer
M.C
PostPosted: 01:14 - 04 Jan 2017    Post subject: Reply with quote
Unless it was free or virtually free I wouldn't touch it.
stevo as b4
PostPosted: 01:45 - 04 Jan 2017    Post subject: Reply with quote
I disagree. I think the EFI 900's are a better lighter bike and have a better spec than the 850's. What they don't do is make much more power, but big bore headers and losing the restrictive cats should sort that out.
Unless the bike was stored very badly in a leaking very damp place I expect it will still be solid and worth economically re-commisioning. You'll know from looking at it if theres alot of corrosion or rusting.
You'll probably have to budget a few quid for new brake pads/seals/fluid and tyres as well as a thorough service and fluids change.
Will be a shame to scrap a good bike for the sake of a few £££ of bits IMO.
PostPosted: 05:48 - 04 Jan 2017    Post subject: Reply with quote
Check that the tank isn't rusted out.
I'd assume that everything made of rubber will need replaced until proven otherwise, possibly including any shaft seals.
Don't get suckered into paying money to try and get it to start up.
PostPosted: 13:40 - 04 Jan 2017    Post subject: Reply with quote
They are FI,
I'm the resident TDM900 expert, feel free to ask anything. I have attached a service manual I had to zip it because the forum has a limit on PDF sizes.
Fresh battery and fuel it'll probably go. One thing that might cause trouble is the auto choke they get gummed up and cause cold start issues.
Here is a guide to sort it.
https://www.jbx9.16mb.com/index.php?page=CS1
Ignore everything he says about dropping the rad/buggering about with the cooling system. You can use a ratchet with a screwdriver bit to get to it from above.
Other than that I'd agree with Roger. Expect to replace all rubber/fluids.
If it's cheap I'll buy it if you don't want it. I have loads of parts and I've worked on them before I'll recommission it.
kgm
PostPosted: 13:49 - 04 Jan 2017    Post subject: Reply with quote
I'd check the brake pistons as well - from the couple of rebuilds I've done I've found the brake pistons had become badly pitted after a long stand (that said the last one had been sitting for 28 years so maybe not the most representative example... It was pretty good for the most part though)
DJP
This^^.
After 10 years in a damp garage pretty much every part is likely FUBAR'd.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
The last post was made 9 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 53.17 Kb
