New commuter thoughts please.
Vandervecken
PostPosted: 18:46 - 02 Jan 2017    Post subject: New commuter thoughts please. Reply with quote
Hi all, looking at trading in my trustee Hornet in the spring for a new bike. So far I am split between an Africa Twin, a TransAlp or possibly a Triumph Tiger can anyone give me an idea on which would be a better purchase. I do about 25000 miles a year mostly major A roads and Motorways. Any comments would be appreciated.
CB600F Hornet.
Previously many a Fazer
bamt
PostPosted: 19:04 - 02 Jan 2017    Post subject: Reply with quote
Of those, I'd go for the Tiger Explorer - because it's shaft drive.
I do similar mileage and similar roads. I went for a 1300 Pan European as the right tool for the job; it is designed to eat fast miles in comfort. I was very tempted by the Explorer, but ended up not doing as they are still relatively new so no low-miles but a several year old bargains. Depreciation would be massive on it due to the mileage (it would be getting towards end of life in four years from new).
Alpineandy
PostPosted: 20:38 - 02 Jan 2017    Post subject: Reply with quote
Annual mileage of 25k is a fair amount.
Any specific reason you want a Dual Sport bike instead of a Touring bike?
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
Vandervecken
PostPosted: 20:41 - 02 Jan 2017    Post subject: Reply with quote
Thanks geez actually that widens the field a bit too, The Tiger is a nice ride had one of these as a loan once and also the direct drive also is a bonus ( my current is chain and sprocket). Also Pan European I just didn't think of that. Thanks for your time.
CB600F Hornet.
kgm
PostPosted: 19:55 - 03 Jan 2017    Post subject: Reply with quote
Africa Twin has issues with the spokes rusting so that's worth considering since you'll be riding all weathers.
Any of the big adv bikes really would work but I think I'd also be looking at something like a Pan or a Triumph Trophy for that kind of mileage on those roads. Shaft drive would be a definite advantage IMO.
bamt
PostPosted: 20:10 - 03 Jan 2017    Post subject: Reply with quote
Something else to consider - the size of the fuel tank. I looked at things like the VFR1200 and the GSX1250FA, but on both of those the range wasn't enough to do two full days of commuting without a fill up. When I take the Bandit 600 to work I have to fill it every day, which is irritating.
My Divvy 900 could comfortable do 200 miles on a fill, the Pan 250 (more if ridden like a granny) - so the Divvy got filled every other day, I can do the Pan at home at weekend, then at work on Wednesday.
Alpineandy
PostPosted: 13:40 - 04 Jan 2017    Post subject: Reply with quote
Not just the spokes.
Wheels and various fixings I'm told.
Although I gather Honda are aware of this failing and are (Have now?) sorting it.
kgm
PostPosted: 13:45 - 04 Jan 2017    Post subject: Reply with quote
Yes, it's a bit of an oversight given the intended purpose of the bike. It does seem that they are aware of it so I would like to think it will be resolved with newer machines. Great bike otherwise though from what I've heard from a couple of owners I've spoken to. Every new model has it's issues but a bit of a bungle from Honda!
PostPosted: 13:54 - 04 Jan 2017    Post subject: Reply with quote
Chains aren't that hard to keep, buy a decent chain and an oiler they go for ages. IMHO shafts have lots of compromises for small benefit.
Mine lasts 30k+ and only gets adjusted if i'm changing tyres/rear pads etc.
PostPosted: 15:09 - 04 Jan 2017    Post subject: Reply with quote
chris-red wrote:
[My chain] lasts 30k+ and only gets adjusted if i'm changing tyres/rear pads etc.
And contrast with the drive shaft on the Nazi 1200s which according to BMW is a no-service item, but owners report stripping them down and finding them bone dry, along with report after report after report of final drive failure on GS, ST and RT models.
They cost nothing, until they cost one unlucky owner a whopping amount.
kgm
PostPosted: 17:44 - 04 Jan 2017    Post subject: Reply with quote
The BMW shaft setup does have a bit of a reputation compared to others though. The general advice for my CX500, which is a very early shaft setup, seems to be oil changes every 10k plus it's worth lubing the splines every so often. Both area very easy. I find chains a pain in winter, even with a properly functioning oiler they still get crudded up with salt and I hate cleaning them.
I think it depends on the application which suits best. For a year round commuter doing big miles shaft makes a lot of sense to me, despite the fact I'm still running chains. I want to try a belt driven machine but there's not many to choose from. Shame the F800GT is so expensive.
PostPosted: 17:59 - 04 Jan 2017    Post subject: Reply with quote
meggark wrote:
CX500, which is a very early shaft setup,.
Shaft drive bikes have been around almost as long as bike themselves... I've seen at least one that was over 100 years old Laughing
kgm
PostPosted: 19:44 - 04 Jan 2017    Post subject: Reply with quote
That's true of course. I should have said comparatively early.
PostPosted: 19:59 - 04 Jan 2017    Post subject: Reply with quote
Belts are ace, I still miss the quiet, clean one on my '305. The ostensible reason that the 800GSes got chains rather than belts was that it's easier to replace or repair a chain in Outer Elbonia, because, you know, Adventure. Rolling Eyes
bamt
PostPosted: 20:03 - 04 Jan 2017    Post subject: Reply with quote
Shafts are just easier in bad weather. Yes, a chain oiler works (and I have one fitted on my other bike), but it is easier to just wash the shaft outer with the rest of the bike, and change the oil in it every few oil changes of the engine - rather than cleaning, oiling and adjusting regularly.
I find whipping off the back wheel for a tyre change easier and cleaner too (especially replacing it). Not a big deal, except I do it 2-3 times a year for tyre replacements. And I'd be changing chain and sprockets at least once a year, which again isn't difficult but dirtier, more time consuming and more expensive than a shaft oil change.
Everything else being equal (i.e. not using a modern BMW with their magical disintegrating final drive) a shaft drive is easier for year round commuting. I'd still use a chain drive if the rest of the bike made more sense to me.
The last post was made 9 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 86.18 Kb
